pisuke Posted October 5, 2017 Share Posted October 5, 2017 hi . i use mame ui 64 0.188 for my mame roms. i ve configured in option controller enable mouse input controller mapping ..paddle and dial and trackball setted to mouse using for example 1000 miglia i can use spinner setted as wheel 270 to play the game correctly. when i start mame from gameex i ve no possibility to use the spinner in the tab control... what is the problem ? thanks GameEx.ini log.txt MAMEUI.ini mame.ini mame.ini Link to comment Share on other sites More sharing options...
pisuke Posted October 6, 2017 Author Share Posted October 6, 2017 no one had this problem? Link to comment Share on other sites More sharing options...
pisuke Posted October 6, 2017 Author Share Posted October 6, 2017 resolved added this command in mame -nowindow -joy -mouse -skip_gameinfo Link to comment Share on other sites More sharing options...
Draco1962 Posted October 6, 2017 Share Posted October 6, 2017 Thanks for reporting back with your solution. I am sure someone would have been able to answer at some point. Glad you got it sorted out! Link to comment Share on other sites More sharing options...
