I'm very new to Pinball X, and I want to know how to make lists or groups to sort Tables more easily. I'm not sure what makes lists or groups different, though.
Basically, I want to be able to sort Tables by Year, or by Manufacturer, or even both. I'd like to be able to choose a Manufacturer, and then seeing a list of Tables by that Manufacturer sorted by Year. Can anybody help me out?
It would also be nice if some extra graphics could be added to each Table on the selection screen. The white text on a mostly black background feels a bit boring to me.
There is not much in the way of sorting available in PinballX. Something like the sorting you are requesting would require a feature request. PinballX is only designed to handle a finite number of games.
Lists are your lists of tables (games) for a system. The default list for a system is part of "All Tables". Additional lists for the same system can be selected from the table launch/information screen (available after clicking select).
Groups allow you combine several lists from different systems into one selected list on the launch/information screen.
While the document here is a little dated, it covers pretty much what you need to get started.
I downloaded that already, and the documentation file looks unfinished. I'm not sure where to get the complete file.
You downloaded the pdf under Zeenon's post and it appears unfinished? That is the complete file. Not sure if you are looking at the correct file there.
