Download and install 2.41. It has Game Manager support now for PBFX3 which was omitted in 2.40.
I download and install 2.41 but i've the same problem with PBFX3 steam... i can't take launch directly the table... i launch the game and i start on the menu... klz25z not work too
I split this into its own thread.
Please attach copies of your pinballx.ini and log.txt files for review. Also pr9vide a copy of your pinball fx3.xml file. Please do not copy and paste in your reply. Thanks.
That's why I decided to just leave a wifi adapter connected to my pincab. I don't have visual pinball or future pinball at this point. Just PBA and now PBFX3, and trying to disable that steam is offline message every time I booted the cab was baffling me so I gave up.
My cab is in rehab currently so I just downloaded 2.41 on one of my laptops. I cannot get PBX to launch tables either. They do launch in Steam.
Part of my log file:
C:\Program Files (x86)\Steam\steamapps\common\Pinball FX3\steam.exe -applaunch 442120 "-table_MARVEL_IronMan"
15:17:04.4  9/28/2017:  The system cannot find the file specified
15:17:04.4  9/28/2017:     at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
15:17:04.4  9/28/2017:     at System.Diagnostics.Process.Start()
15:17:04.4  9/28/2017:     at PinballX.Main.q()
Pinball FX3.xml
PinballX.ini
Not entirely the issue, but I did notice that some of the file names between FX2 and FX3 changed. STARWARS_EPISODE_7.xxx is now STARWARS_EPISODE7.xxx
I also emailed Zen studios support so if I get a good answer I'll let you know.
Question I have regarding non-cabinet mode (i.e. using the Grid system). In Pinball FX2 the grid was fairly simple to master with some practice. In Pinball FX3, the UI grid is divided by table classification (i.e., Zen originals, Women of Power, Star Wars, Marvel, etc.) and if someone has a large collection, the sections are collapsed horizontally until you go over to that section. I am at work so can't provide a video or screen captures to demonstrate). How do you calculate the grid in this type of display?
i use irotate and the  tables at the botton after scrolling to them, there is no grid number for them.
