I thought this was originally an issue with my PC but it seems to only occur when tables are played through Pinball X front end? When a table starts the admin icon will appear in the top left of my DMD (Monitor 1) . If I close Pinball X and press start from the task bar the icon will disappear? I'm curious to why this should be when using Pinball X. If I launch the game using the game manager it doesn't happen neither does it happen if I launch a table in VP mame? Any idea why it's happening and secondly how I make it stop?
https://ibb.co/jdFRRk
You are going to need to provide us with a copy of your log.txt and pinballx.ini files. Please attach them in reply to this thread so that others can review and possibly help you troubleshoot the issue you are reporting.
If you are not sure where to locate these files, please click on the PinballX How to ask for help link in my signature. Thanks.
16:19:19.8  28/08/2017:  PinballX - Version 2.36
16:19:19.9  28/08/2017:  Windows 7 Professional Service Pack 1 64-bit (7.9GB)
16:19:19.9  28/08/2017:  Loading Settings
16:19:19.9  28/08/2017:  Initialize Component
16:19:19.9  28/08/2017:  Initialize Display
16:19:21.1  28/08/2017:  Loading PlugIns
16:19:21.2  28/08/2017:  Created DirectX BackGlass Window
16:19:21.2  28/08/2017:  Created DirectX DMD Window
16:19:21.2  28/08/2017:  Created DirectX Topper Window
16:19:21.3  28/08/2017:  Hiding Cursor
16:19:21.3  28/08/2017:  Hiding Taskbar
16:19:21.4  28/08/2017:  CPU:  AMD Athlon(tm) X4 860K Quad Core Processor
16:19:21.4  28/08/2017:  GPU 1: NVIDIA GeForce GTX 1050 Ti
16:19:21.4  28/08/2017:  Displays: 3
16:19:21.4  28/08/2017:  Load Game List
16:19:21.4  28/08/2017:  Loading Database: Pinball FX2
16:19:21.4  28/08/2017:  Loading Database: Visual Pinball
16:19:21.4  28/08/2017:  Loading Database: VP9
16:19:21.4  28/08/2017:  Loading Database: VP9 Physmod5
16:19:21.5  28/08/2017:  Finding and matching artwork and videos
16:19:22.4  28/08/2017:  Loading Game Statistics and Scores
16:19:22.4  28/08/2017:  Main display running full screen windowed.
16:19:22.5  28/08/2017:  Loading Surfaces
16:19:22.7  28/08/2017:  Finished Loading Surfaces
16:19:22.7  28/08/2017:  Initialize Audio
16:19:22.8  28/08/2017:  Set Keyboard Controls
16:19:22.8  28/08/2017:  Initialize Joystick
16:19:22.9  28/08/2017:  8 Joysticks Attached
16:19:22.9  28/08/2017:  Started
16:20:29.2  28/08/2017:  Launch System
16:20:29.2  28/08/2017:  Waiting for threads
16:20:29.6  28/08/2017:  Disposing display
16:20:33.8  28/08/2017:  C:\Visual Pinball\VPinballX.exe /play -"C:\Visual Pinball\Tables\VPX\Indiana Jones (Stern 2008).vpx"
16:20:39.5  28/08/2017:  Found PinMAME ROM: pinball.nv
16:20:39.5  28/08/2017:  Setting DMD position
16:21:00.2  28/08/2017:  Hidden Visual Pinball Editor Window
16:21:53.7  28/08/2017:  Exit System Control Pressed
16:21:56.7  28/08/2017:  Created DirectX BackGlass Window
16:21:56.8  28/08/2017:  Created DirectX DMD Window
16:21:56.8  28/08/2017:  Created DirectX Topper Window
16:21:56.8  28/08/2017:  Main display running full screen windowed.
16:58:02.5  28/08/2017:  Exiting
16:58:02.5  28/08/2017:  Showing Taskbar
16:58:02.6  28/08/2017:  Unhiding Mouse Cursor
16:58:02.6  28/08/2017:  Disposing Plugins
16:58:02.6  28/08/2017:  Saving Settings
16:58:02.6  28/08/2017:  Bye
