(inside)
(stainless steel)
SPECIFICATIONS:
CPU
AMD Athlon 64 3200+
RAM
GeIL 512MB DDR PC3200
HDD
Seagate 80Gb, 8Mb cache, NCQ, SATA
Motherboard
ASUS A8N-VM CSM
- GeForce 6150 onboard
- Dual VGA out (DVI-D & RGB)
- HD audio onboard
Monitors
2 x Samsung 172X - 8ms (1280x1024)
Network
Netgear WPN111 Wireless USB Adapter
802.11G (108Mbps MIMO Tech)
Sound
Sony Xplod amp - 50W RMS per channel
4 x 4" Sony Xplod 30W RMS speakers
Volume - 100k Log dual gang pot
Cooling
2 x Antec 120mm Red Fans
Zalman ZM-NB47J Northbridge Heatsink
Anodised aluminium air vents
Input
16 x 30mm Pushbutons
Sanwa Joysticks
Electronic coin mechanism
Ultimart I-PAC 2
Stand
1.6mm 304 grade stainless steel
50mm square tubing
Brushed finish
Top
19mm solid pine - dark oak finish
16mm MDF base
Glass
6mm toughened safety glass
Thanks,
It took me about 2 months of spare time.
I got together all the PC hardware, then did up some plans - aiming for minimal size, but still around standard cocktail table hieght:
I made the cab, then did CAD drawings for the frame, and sent the top off to have the glass cut.
Doing it in stages took a long time, but everything fits nicely.
With 2 monitors, 8kg steel and about 3kg glass it's not going to move if you bump it, but I'm sure it's lighter than a standard cocktail table (or standup).
No female influence - just after something practical and classy...
  • 1 month later...
Me being the lazy person I am, got sick of emptying the coin box every time i needed more credits, so I built a RFID scanner kit, and mounted it under the table top so I just have to pass an RFID tag on my keyring past it for credits.
I marked where the scanner is by placing another surface protector between the glass and the table top.
It's not needed, but I hooked the output up to a relay that's connected to my IPAC. The "clunk" of the relay sounds a little like dropping a coin in...
The only problem is that the output is designed to activate a doorstrike, and stays on for 5 seconds. Some games do not accept it as a coin (software anti-stringing or something...)
The processing of the 40-bit RFID tags is done by an 8bit 10mhz Atmel AVR microcontroller (itself worth $2), which can be reprogrammed with a serial programmer (about $50). I've downloaded the code used (as it was kindly provided by the makers of the kit) and recompiled it with a 100ms delay - which is how long the electronic coin slot closes it's output for. Now I just need to get the programmer and reprogram the AVR...
Tags come in credit card size, keyfob style, and mini dot size.
Here's a close up of the mini dot one:
I think I'll get an ash tray, and hide one under a felt lining underneath it...
