Didn't you notice in my sig it shows my uptime and what game I was playing last?
You can get a gamertag for your rig at gameex.com
So I just brought a 2nd cab to do up during Xmas holidays. I was wondering if I am able to use GameEx on two machines at the same time?
Nice! A little cosmetic work and she'll make a great gift!
Have you considered building a bartop?
I have but with my new job it's hard to find the time to do anything! It's definitely something I will look into.
  • 1 month later...
  • 1 month later...
Added some LED Strips to the 2nd Arcade now Working on a 3rd arcade.
Also anyone got any tips for fixing up the wooden look on the 3rd arcade. I want to keep the wooden theme but There's few deep scratches
which I am unsure if I can sand down and touch up with something?
post-23175-0-07782800-1389681181_thumb.j
post-23175-0-63359900-1389681202_thumb.j
Unless you are working with a totally smooth surface, I would either sand down the existing wood and restain/seal it or replace it as was suggested. Most laminates have a thermal adhesive that activates with a heat gun and you shouldn't need to worry about air bubbles too much if that is the route you choose.
Yeah its the one on the left. the problem is with sticking laminate on, is both sides have same wooden look.
And I don't think I could cut the bends very well.
But sanding then staining sounds like a plan.
Would I need to fill in the cuts with anything before sanding and staining?
Thanks for the help guys.
You should be able to pick up some wood filler for some of the deepest cuts or gouges. You may have to be a little creative with a set of wood stain "markers" to kinda blend in the the grain a little. I think it is very doable and you will probably like the outcome much better than laminate.
Make sure you get the markers that have a tapering round point instead of the broad heads if possible. This will allow you to create variability in the grain widths.
