Hi All,
I'm running GameEx Arcade, and if Mednafen isn't the first emulator I run (I use it to play Turbogfx16) then it crashes when loading.  Any ideas why this is happening?  If need to share something just let me know. Thanks!!
Yes, please attach copies of your gameex.ini and log.txt files for review in reply to this thread. Can't do anything but guess without them.
Sure.
Spoiler
Error Log
14:19:03.0  7/15/2017:  Opening Configuration File
14:19:03.0  7/15/2017:  GameEx Arcade Edition: Version 14.81: Starting Log
14:19:03.3  7/15/2017:  Windows 10 Enterprise 64-bit
14:19:03.3  7/15/2017:  Aero running
14:19:03.3  7/15/2017:  Initializing Vista/Windows 7 volume control
14:19:03.3  7/15/2017:  Getting CPU and RAM info
14:19:03.3  7/15/2017:  AMD FX(tm)-8320 Eight-Core Processor, 32667MB
14:19:03.3  7/15/2017:  3.51Ghz - 8 Cores or CPU's
14:19:03.3  7/15/2017:  Running Randomize()
14:19:03.5  7/15/2017:  Loading PlugIns
14:19:03.5  7/15/2017:  Loaded Plugin:"LEDBlinky" Version 4.0.0 By Arzoo
14:19:08.5  7/15/2017:  PlugIn: "LEDBlinky" Initialized OK
14:19:08.5  7/15/2017:  Using Plugin System Version: 1.3
14:19:08.5  7/15/2017:  Checking for applications to Launch On Startup
14:19:08.5  7/15/2017:  Setting default net connection limit to 15
14:19:08.5  7/15/2017:  Running Misc startup tasks
14:19:08.5  7/15/2017:  Setting Menu types
14:19:08.5  7/15/2017:  Getting Configuration Values
14:19:08.5  7/15/2017:  Using Theme: Draconus
14:19:08.5  7/15/2017:  Checking for alternate Image Directory for Theme: Draconus
14:19:08.5  7/15/2017:  Launching HideOS.exe
14:19:08.5  7/15/2017:  Initialising Video/MNG DLL's
14:19:08.5  7/15/2017:  CPWizard enabled
14:19:08.6  7/15/2017:  Launching CPWizard: "C:\CPWizard\CPWizard.exe" -minimized
14:19:09.8  7/15/2017:  GameEx will check for media insertion (may affect performance)
14:19:09.8  7/15/2017:  Hiding Taskbar
14:19:09.8  7/15/2017:  Is Media Center running?
14:19:09.8  7/15/2017:  Checking/Creating LCD Registry values
14:19:09.9  7/15/2017:  Check Media Center Exit/Start Mode
14:19:09.9  7/15/2017:  Media Center Mode 2
14:19:10.1  7/15/2017:  Video previews on. Warning: Only recommended on modern systems
14:19:10.1  7/15/2017:  Custom Keyboard Input enabled: Getting custom codes
14:19:10.1  7/15/2017:  Custom Game Device Input enabled: Getting custom codes
14:19:10.2  7/15/2017:  Snap Delay set to: 7
14:19:10.2  7/15/2017:  Get other settings
14:19:10.2  7/15/2017:  Desktop set to Hide ICONS and set Background to Black
14:19:10.2  7/15/2017:  Set: Find emulator artwork on best match basis
14:19:10.2  7/15/2017:  SlikStik support enabled
14:19:10.2  7/15/2017:  Using DirectInput for keyboard input
14:19:10.2  7/15/2017:  Start work for Form
14:19:10.2  7/15/2017:  Getting Original Screen Size
14:19:10.2  7/15/2017:  Opening Database Connection
14:19:10.3  7/15/2017:  Initializing Component
14:19:10.3  7/15/2017:  MAME Path is: C:\Emulation\Emulators\Mame
14:19:10.3  7/15/2017:  MAME EXE file is: mame64.exe
14:19:10.4  7/15/2017:  ROM Path is: C:\Emulation\ROMs\Mame
14:19:10.4  7/15/2017:  Catver.ini is located at: D:\GameEx Arcade Edition\DATA\catver.ini
14:19:10.4  7/15/2017:  controls.ini is located at: D:\GameEx Arcade Edition\DATA\controls.ini
14:19:10.6  7/15/2017:  History.dat is located at: D:\GameEx Arcade Edition\DATA\history.dat
14:19:10.6  7/15/2017:  nplayers.ini is located at: D:\GameEx Arcade Edition\DATA\nplayers.ini
14:19:10.7  7/15/2017:  command.dat is located at: D:\GameEx Arcade Edition\DATA\command.dat
14:19:10.7  7/15/2017:  MAMEinfo.dat is located at: D:\GameEx Arcade Edition\DATA\mameinfo.dat
14:19:10.8  7/15/2017:  Snap Path is: C:\Emulation\Emulators\Mame\snap
14:19:10.8  7/15/2017:  Database Snap Path: Not Found
14:19:10.8  7/15/2017:  Background Snap Path: Not Found
14:19:10.9  7/15/2017:  AVI Snap Path is: C:\Emulation\Emulators\Mame\Video_AVI_HI_QUAL
14:19:10.9  7/15/2017:  Video theme Path is: C:\Emulation\Emulators\Mame\Video_Themes_MP4
14:19:10.9  7/15/2017:  Video background Path: Not Found
14:19:10.9  7/15/2017:  Flyer Path: Not Found
14:19:11.0  7/15/2017:  Cabinet Path is: C:\Emulation\Emulators\Mame\cabinets
14:19:11.0  7/15/2017:  Cabinet 3D Path is: C:\Emulation\Emulators\Mame\cabinets3d
14:19:11.0  7/15/2017:  Title Path is: C:\Emulation\Emulators\Mame\title
14:19:11.1  7/15/2017:  Title Path is: C:\Emulation\Emulators\Mame\logos
14:19:11.1  7/15/2017:  PCB Path: Not Found
14:19:11.1  7/15/2017:  Artwork Preview Path: Not Found
14:19:11.1  7/15/2017:  Panel Path: Not Found
14:19:11.1  7/15/2017:  Manual Path is: C:\Emulation\Emulators\Mame\manual
14:19:11.1  7/15/2017:  Icon Path is: C:\Emulation\Emulators\Mame\icon
14:19:11.2  7/15/2017:  Marquee Path is: C:\Emulation\Emulators\Mame\Marquee
14:19:11.3  7/15/2017:  Applying Language/Text
14:19:11.3  7/15/2017:  Text/Language: English
14:19:11.3  7/15/2017:  Loading Language/Text
14:19:11.3  7/15/2017:  Using Version 3 Themes Animations
14:19:11.3  7/15/2017:  Retrieving resolution setting
14:19:12.0  7/15/2017:  Using General Font: Segoe UI
14:19:12.0  7/15/2017:  Using Title Font: Segoe UI
14:19:12.0  7/15/2017:  GameEx will try to reduce CPU usage
14:19:15.7  7/15/2017:  Initialising Direct3D
14:19:15.9  7/15/2017:  Applying GameEx is Loading Image
14:19:15.9  7/15/2017:  Setting Resolution to 1920x1080 32 bit color
14:19:15.9  7/15/2017:  Creating Surfaces
14:19:16.2  7/15/2017:  Creating Primary Surface - Full Screen Mode
14:19:16.2  7/15/2017:  Creating Back Buffer
14:19:16.2  7/15/2017:  Loading graphic Surfaces
14:19:16.2  7/15/2017:  Display is running at: 1920x1080 32bit color, 60hz
14:19:16.3  7/15/2017:  Adapter: NVIDIA GeForce GTX 970
14:19:16.3  7/15/2017:  Max texture size: 16384x16384
14:19:16.3  7/15/2017:  Available texture memory: -24MB
14:19:16.3  7/15/2017:  Initialising Bass Audio Library
14:19:16.4  7/15/2017:  Creating Surfaces Misc and Dialogs
14:19:16.6  7/15/2017:  Creating Surfaces Volume
14:19:16.6  7/15/2017:  Creating Surfaces Arrows
14:19:16.6  7/15/2017:  Creating Surfaces GameEXlogo Text
14:19:16.6  7/15/2017:  Creating Surfaces Toolbar
14:19:16.6  7/15/2017:  Creating Surfaces Toolbar Controls
14:19:16.7  7/15/2017:  Creating Surfaces Backgrounds
14:19:16.7  7/15/2017:  Creating Surfaces GameEx Logo
14:19:16.7  7/15/2017:  Creating Surface Unselected
14:19:16.7  7/15/2017:  Creating Surfaces Snaps
14:19:16.7  7/15/2017:  Creating Surfaces Menu and List Bars
14:19:16.9  7/15/2017:  Creating Fonts
14:19:16.9  7/15/2017:  Creating Game Font
14:19:17.7  7/15/2017:  Creating Game Font Faded
14:19:18.6  7/15/2017:  Creating Title Font
14:19:18.6  7/15/2017:  Restoring Title Font From Cache
14:19:18.7  7/15/2017:  Creating Font Black
14:19:18.7  7/15/2017:  Creating Font Black Small
14:19:18.8  7/15/2017:  Fonts Created Succesfully
14:19:19.3  7/15/2017:  Initial Emulator Load
14:19:19.7  7/15/2017:  Loading Custom Emulators
14:19:19.8  7/15/2017:  Loading Emulator 1: [Console] Nintendo NES (Nestopia)
14:19:20.5  7/15/2017:  Loading Emulator 3: [Console] TurboGrafx 16
14:19:20.5  7/15/2017:  Loading Emulator 4: [Console] Sega Genesis
14:19:20.6  7/15/2017:  Loading Emulator 5: [Console] Nintendo SNES (ZSNES)
14:19:20.6  7/15/2017:  Loading Emulator 6: Nintendo N64
14:19:20.7  7/15/2017:  Loading Emulator 7: [Console] Sony Playstation (ePSXe)
14:19:20.8  7/15/2017:  Loading Emulator 8: [Console] Sega Dreamcast (nullDC)
14:19:20.9  7/15/2017:  Loading Emulator 9: [Console] Nintendo GameCube (Dolphin)
14:19:20.9  7/15/2017:  Checking if Steam enabled
14:19:20.9  7/15/2017:  Steam is installed correctly
14:19:21.1  7/15/2017:  Found Steam Base Install Folder: D:\\Program Files (x86)\\SteamLibrary
14:19:21.5  7/15/2017:  Found Steam Game: Castle Crashers. AppID=204360. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\CastleCrashers
14:19:21.6  7/15/2017:  Found Steam Game: Jet Set Radio. AppID=205950. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Jet Set Radio
14:19:21.6  7/15/2017:  Found Steam Game: Sonic Adventure™ 2 . AppID=213610. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Sonic Adventure 2
14:19:21.6  7/15/2017:  Found Steam Game: THE KING OF FIGHTERS 2002 UNLIMITED MATCH. AppID=222440. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\The King of Fighters 2002 Unlimited Match
14:19:21.7  7/15/2017:  Found Steam Game: THE KING OF FIGHTERS XIII STEAM EDITION. AppID=222940. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\King of Fighters XIII
14:19:21.8  7/15/2017:  Found Steam Game: Duke Nukem 3D: Megaton Edition. AppID=225140. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Duke Nukem 3D
14:19:21.8  7/15/2017:  Found Steam Game: Wolfenstein 3D. AppID=2270. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Wolfenstein 3D
14:19:21.9  7/15/2017:  Found Steam Game: Dragon's Lair. AppID=227380. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Dragon's Lair
14:19:21.9  7/15/2017:  Found Steam Game: Dungeons & Dragons: Chronicles of Mystara. AppID=229480. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Dungeons & Dragons HD
14:19:21.9  7/15/2017:  Found Steam Game: PAC-MAN Championship Edition DX+. AppID=236450. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\PAC-MAN Championship Edition DX+
14:19:21.9  7/15/2017:  Found Steam Game: Mortal Kombat Komplete Edition. AppID=237110. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\MortalKombat_KompleteEdition
14:19:21.9  7/15/2017:  Found Steam Game: DuckTales Remastered. AppID=237630. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\DuckTales Remastered
14:19:21.9  7/15/2017:  Found Steam Game: Angry Video Game Nerd Adventures. AppID=237740. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Angry Video Game Nerd Adventures
14:19:21.9  7/15/2017:  Found Steam Game: Space Ace. AppID=240340. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Space Ace
14:19:22.0  7/15/2017:  Found Steam Game: Dragon's Lair 2: Time Warp. AppID=240360. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Dragon's Lair II
14:19:22.1  7/15/2017:  Found Steam Game: Skullgirls. AppID=245170. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Skullgirls
14:19:22.1  7/15/2017:  Found Steam Game: LEGO® MARVEL Super Heroes. AppID=249130. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\LEGO Marvel Super Heroes
14:19:22.1  7/15/2017:  Found Steam Game: Shovel Knight: Treasure Trove. AppID=250760. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Shovel Knight
14:19:22.2  7/15/2017:  Found Steam Game: The Binding of Isaac: Rebirth. AppID=250900. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\The Binding of Isaac Rebirth
14:19:22.2  7/15/2017:  Found Steam Game: Double Dragon Neon. AppID=252350. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Double Dragon Neon
14:19:22.2  7/15/2017:  Found Steam Game: Ikaruga. AppID=253750. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Ikaruga
14:19:22.3  7/15/2017:  Found Steam Game: Gauntlet™ . AppID=258970. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Gauntlet
14:19:22.4  7/15/2017:  Found Steam Game: Danmaku Unlimited 2. AppID=280560. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\DanmakuUnlimited2
14:19:22.4  7/15/2017:  Found Steam Game: Blue Estate. AppID=305380. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Blue Estate
14:19:22.4  7/15/2017:  Found Steam Game: REVOLVER360 RE:ACTOR. AppID=313400. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\REVOLVER360REACTOR
14:19:22.4  7/15/2017:  Found Steam Game: LEGO® Star Wars™: The Complete Saga. AppID=32440. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Lego Star Wars Saga
14:19:22.4  7/15/2017:  Found Steam Game: Bejeweled 2 Deluxe. AppID=3300. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Bejeweled 2 Deluxe
14:19:22.4  7/15/2017:  Found Steam Game: Feeding Frenzy 2: Shipwreck Showdown Deluxe. AppID=3390. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Feeding Frenzy 2 Deluxe
14:19:22.4  7/15/2017:  Found Steam Game: Super Meat Boy. AppID=40800. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Super Meat Boy
14:19:22.4  7/15/2017:  Found Steam Game: Bit Blaster XL. AppID=433950. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Bit Blaster XL
14:19:22.4  7/15/2017:  Found Steam Game: Ultra Street Fighter IV. AppID=45760. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Super Street Fighter IV - Arcade Edition
14:19:22.4  7/15/2017:  Found Steam Game: VVVVVV. AppID=70300. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\vvvvvv
14:19:22.4  7/15/2017:  Found Steam Game: Sonic Generations. AppID=71340. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Sonic Generations
14:19:22.4  7/15/2017:  Found Steam Game: Jamestown. AppID=94200. Location:D:\Program Files (x86)\SteamLibrary\steamapps\common\Jamestown
14:19:22.4  7/15/2017:  Found Steam games. Steam enabled.
14:19:22.4  7/15/2017:  Checking if Origin enabled
14:19:22.4  7/15/2017:  Origin support is turned off in configuration.
14:19:22.4  7/15/2017:  Checking if Uplay enabled
14:19:22.4  7/15/2017:  UPlay support is turned off in configuration.
14:19:22.4  7/15/2017:  gamebase support enabled.
14:19:22.4  7/15/2017:  ERROR: Could not find gamebase path or gblanucher.exe
14:19:22.4  7/15/2017:  gamebase support disabled.
14:19:22.4  7/15/2017:  Attempting to load game list
14:19:24.9  7/15/2017:  MAME CMD options: -nowindow -joy -skip_gameinfo
14:19:27.2  7/15/2017:  Sound Disabled
14:19:27.2  7/15/2017:  Gamepad/Joystick disabled
14:19:27.2  7/15/2017:  Initialising DirectInput for Keyboard support
14:19:27.5  7/15/2017:  Loading Start Page
14:19:27.6  7/15/2017:  Initializing MCE Remote
14:19:27.7  7/15/2017:  Initialization OK! Starting GameEx!
14:19:27.7  7/15/2017:  Testing Main Loop Once: Processing Frame
14:19:30.9  7/15/2017:  Testing Main Loop Once: Main Loop ran successfully
14:19:31.5  7/15/2017:  Validating: Emulator_1: Snap Path: D:\RomFiles\Nintendo Art\Nintendo_NES\Snap
14:19:32.1  7/15/2017:  Validating: Emulator_1: Video Snap Path: D:\RomFiles\Nintendo Art\Nintendo_NES\Video_AVI_HI_QUAL
14:19:32.2  7/15/2017:  Validating: Emulator_1: Video Theme Path: D:\RomFiles\Nintendo Art\Nintendo_NES\Themes
14:19:32.4  7/15/2017:  Validating: Emulator_1: Video background Path: D:\RomFiles\Nintendo Art\Nintendo_NES\Background
14:19:32.5  7/15/2017:  Validating: Emulator_1: Control Panel Path: C:\Emulation\Assets\Nintendo NES\Controls
14:19:32.8  7/15/2017:  Validating: Emulator_1: Database: [Console] Nintendo NES
14:19:33.1  7/15/2017:  Validating: Emulator_1: Title Snap Path: C:\Emulation\Assets\Nintendo NES\Titles
14:19:33.1  7/15/2017:  Validating: Emulator_1: Logo Snap Path: D:\RomFiles\Nintendo Art\Nintendo_NES\Logos
14:19:33.2  7/15/2017:  Validating: Emulator_1: Box Art Path: D:\RomFiles\Nintendo Art\Nintendo_NES\box
14:19:33.3  7/15/2017:  Validating: Emulator_1: Cart Art Path: D:\RomFiles\Nintendo Art\Nintendo_NES\cart
14:19:33.3  7/15/2017:  Validating: Emulator_1: Manual Path: D:\RomFiles\Nintendo Art\Nintendo_NES\manual
14:19:33.4  7/15/2017:  Validating: Emulator_3: Snap Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\snap
14:19:33.7  7/15/2017:  Validating: Emulator_3: Video Snap Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\Video_AVI_HI_QUAL
14:19:33.8  7/15/2017:  Validating: Emulator_3: Video background Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\background
14:19:33.8  7/15/2017:  Validating: Emulator_3: Control Panel Path: C:\Emulation\Assets\NEC TurboGrafx CD\Controls
14:19:33.9  7/15/2017:  Validating: Emulator_3: Database: [Console] NEC TurboGrafx CD
14:19:34.0  7/15/2017:  Validating: Emulator_3: Title Snap Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\title
14:19:34.0  7/15/2017:  Validating: Emulator_3: Logo Snap Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\logos
14:19:34.1  7/15/2017:  Validating: Emulator_3: Box Art Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\box
14:19:34.2  7/15/2017:  Validating: Emulator_3: Cart Art Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\cart
14:19:34.5  7/15/2017:  Validating: Emulator_3: Manual Path: D:\RomFiles\TurboGrafx Art\NEC_TurboGrafx_16\Manual
14:19:34.8  7/15/2017:  Validating: Emulator_4: Snap Path: D:\RomFiles\Genesis Art\Sega_Genesis\snap
14:19:34.9  7/15/2017:  Validating: Emulator_4: Video Snap Path: D:\RomFiles\Genesis Art\Sega_Genesis\Video_MP4_HI_QUAL
14:19:35.0  7/15/2017:  Validating: Emulator_4: Video background Path: D:\RomFiles\Genesis Art\Sega_Genesis\background
14:19:35.0  7/15/2017:  Validating: Emulator_4: Control Panel Path: C:\Emulation\Assets\Sega Master System\Controls
14:19:35.1  7/15/2017:  Validating: Emulator_4: Database: [Console] Sega Master System
14:19:35.1  7/15/2017:  Warning: Emulator_4: Database Does not exist
14:19:35.1  7/15/2017:  Validating: Emulator_4: Title Snap Path: D:\RomFiles\Genesis Art\Sega_Genesis\title
14:19:35.1  7/15/2017:  Validating: Emulator_4: Logo Snap Path: D:\RomFiles\Genesis Art\Sega_Genesis\Logos
14:19:35.2  7/15/2017:  Validating: Emulator_4: Box Art Path: D:\RomFiles\Genesis Art\Sega_Genesis\box
14:19:35.2  7/15/2017:  Validating: Emulator_4: Cart Art Path: D:\RomFiles\Genesis Art\Sega_Genesis\cart
14:19:35.3  7/15/2017:  Validating: Emulator_5: Snap Path: D:\RomFiles\SNES Art\Nintendo_SNES\Snap
14:19:35.4  7/15/2017:  Validating: Emulator_5: Video Snap Path: D:\RomFiles\SNES Art\Nintendo_SNES\Video_MP4_HI_QUAL
14:19:35.4  7/15/2017:  Validating: Emulator_5: Video Theme Path: D:\RomFiles\SNES Art\Nintendo_SNES\Themes
14:19:35.4  7/15/2017:  Validating: Emulator_5: Control Panel Path: C:\Emulation\Assets\Nintendo SNES\Controls
14:19:35.4  7/15/2017:  Validating: Emulator_5: Database: [Console] Nintendo SNES
14:19:35.4  7/15/2017:  Validating: Emulator_5: Title Snap Path: D:\RomFiles\SNES Art\Nintendo_SNES\Title
14:19:35.4  7/15/2017:  Validating: Emulator_5: Logo Snap Path: D:\RomFiles\SNES Art\Nintendo_SNES\logos
14:19:35.4  7/15/2017:  Validating: Emulator_5: Box Art Path: D:\RomFiles\SNES Art\Nintendo_SNES\box
14:19:35.4  7/15/2017:  Validating: Emulator_5: Cart Art Path: D:\RomFiles\SNES Art\Nintendo_SNES\cart
14:19:35.5  7/15/2017:  Validating: Emulator_5: Manual Path: D:\RomFiles\SNES Art\Nintendo_SNES\manual
14:19:35.5  7/15/2017:  Validating: Emulator_6: Snap Path: D:\RomFiles\N64 Art\Nintendo_N64\snap
14:19:35.6  7/15/2017:  Validating: Emulator_6: Video Snap Path: D:\RomFiles\N64 Art\Nintendo_N64\Video_MP4_HI_QUAL
14:19:35.6  7/15/2017:  Validating: Emulator_6: Control Panel Path: C:\Emulation\Assets\Nintendo N64\Controls
14:19:35.7  7/15/2017:  Validating: Emulator_6: Database: [Console] Nintendo N64
14:19:35.8  7/15/2017:  Validating: Emulator_6: Title Snap Path: D:\RomFiles\N64 Art\Nintendo_N64\Title
14:19:35.8  7/15/2017:  Validating: Emulator_6: Logo Snap Path: D:\RomFiles\N64 Art\Nintendo_N64\Logos
14:19:35.8  7/15/2017:  Validating: Emulator_6: Box Art Path: D:\RomFiles\N64 Art\Nintendo_N64\Box
14:19:35.8  7/15/2017:  Validating: Emulator_6: Cart Art Path: D:\RomFiles\N64 Art\Nintendo_N64\Cart
14:19:35.8  7/15/2017:  Validating: Emulator_6: Manual Path: D:\RomFiles\N64 Art\Nintendo_N64\Manual
14:19:36.0  7/15/2017:  Validating: Emulator_7: Snap Path: D:\RomFiles\Playstation Art\Sony_Playstation\Snap
14:19:36.2  7/15/2017:  Validating: Emulator_7: Video background Path: D:\RomFiles\Playstation Art\Sony_Playstation\background
14:19:36.2  7/15/2017:  Validating: Emulator_7: Control Panel Path: C:\Emulation\Assets\Sony Playstation\Controls
14:19:36.3  7/15/2017:  Validating: Emulator_7: Database: [Console] Sony Playstation
14:19:36.3  7/15/2017:  Warning: Emulator_7: Database Does not exist
14:19:36.3  7/15/2017:  Validating: Emulator_7: Title Snap Path: D:\RomFiles\Playstation Art\Sony_Playstation\title
14:19:36.4  7/15/2017:  Validating: Emulator_7: Box Art Path: D:\RomFiles\Playstation Art\Sony_Playstation\box
14:19:36.4  7/15/2017:  Validating: Emulator_7: Cart Art Path: D:\RomFiles\Playstation Art\Sony_Playstation\cd
14:19:36.4  7/15/2017:  Validating: Emulator_7: Manual Path: D:\RomFiles\Playstation Art\Sony_Playstation\Manual
14:19:36.5  7/15/2017:  Warning: Emulator_7: MAPFile Does Not Exist
14:19:36.5  7/15/2017:  Validating: Emulator_8: Snap Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Snap
14:19:36.7  7/15/2017:  Validating: Emulator_8: Video Snap Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Video_AVI_HI_QUAL
14:19:36.8  7/15/2017:  Validating: Emulator_8: Video background Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Background
14:19:36.8  7/15/2017:  Validating: Emulator_8: Control Panel Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Sega Dreamcast\Controls
14:19:36.9  7/15/2017:  Validating: Emulator_8: Database: [Console] Sega Dreamcast
14:19:36.9  7/15/2017:  Validating: Emulator_8: Title Snap Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Title
14:19:36.9  7/15/2017:  Validating: Emulator_8: Logo Snap Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Logos
14:19:36.9  7/15/2017:  Validating: Emulator_8: Box Art Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Box
14:19:37.0  7/15/2017:  Validating: Emulator_8: Cart Art Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\CD
14:19:37.0  7/15/2017:  Validating: Emulator_8: Manual Path: D:\RomFiles\Dreamcast Art\Sega_Dreamcast\Manual
14:19:37.1  7/15/2017:  Validating: Emulator_9: Snap Path: D:\RomFiles\Gamecube Art\Nintendo_GameCube\Background
14:19:37.2  7/15/2017:  Validating: Emulator_9: Video Snap Path: D:\RomFiles\Gamecube Art\Nintendo_GameCube\Video_AVI_HI_QUAL
14:19:37.2  7/15/2017:  Validating: Emulator_9: Control Panel Path: C:\Emulation\Assets\Nintendo GameCube\Controls
14:19:37.3  7/15/2017:  Validating: Emulator_9: Database: [Console] Nintendo GameCube
14:19:37.3  7/15/2017:  Warning: Emulator_9: Database Does not exist
14:19:37.3  7/15/2017:  Validating: Emulator_9: Box Art Path: D:\RomFiles\Gamecube Art\Nintendo_GameCube\Box_3D
14:19:37.3  7/15/2017:  Validating: Emulator_9: Manual Path: D:\RomFiles\Gamecube Art\Nintendo_GameCube\Manual
14:19:55.1  7/15/2017:  Restoring Emulator from Cache: 1
14:19:55.3  7/15/2017:  Restoring Emulator Database From Cache: 1
14:19:55.4  7/15/2017:  Restoring Emulator from Cache: 3
14:19:55.5  7/15/2017:  No Database Data: 3
14:19:55.6  7/15/2017:  Restoring Emulator from Cache: 4
14:19:55.8  7/15/2017:  Restoring Emulator from Cache: 5
14:19:56.1  7/15/2017:  Restoring Emulator Database From Cache: 5
14:19:56.4  7/15/2017:  Restoring Emulator from Cache: 6
14:19:56.4  7/15/2017:  Restoring Emulator Database From Cache: 6
14:19:56.5  7/15/2017:  Restoring Emulator from Cache: 7
14:19:56.6  7/15/2017:  Restoring Emulator from Cache: 8
14:19:56.7  7/15/2017:  Restoring Emulator Database From Cache: 8
14:19:56.7  7/15/2017:  Restoring Emulator from Cache: 9
14:20:12.5  7/15/2017:  Running: cmd.exe /c C: Fusion.exe -md -fullscreen "D:\RomFiles\Genesis\Splatterhouse 3 (USA).zip"
14:20:12.7  7/15/2017:  Shutting down display
14:20:13.2  7/15/2017:  Also Launching: "C:\Emulation\Emulators\Fusion\Gen.exe"
14:20:19.9  7/15/2017:  Escape Pressed, exiting emulator
14:20:20.4  7/15/2017:  Exiting Game
14:20:20.4  7/15/2017:  Closing Process
14:20:21.9  7/15/2017:  Writing Stats
14:20:22.0  7/15/2017:  Plugin: Game Exit
14:20:22.0  7/15/2017:  Plugin: Process Commands
14:20:22.0  7/15/2017:  Refreshing Keyboard
14:20:22.2  7/15/2017:  Initialising Audio
14:20:22.3  7/15/2017:  Restoring Window
14:20:22.4  7/15/2017:  Reinitializing Graphics System
14:20:23.2  7/15/2017:  4  4
14:20:23.3  7/15/2017:  TRUE
14:20:23.5  7/15/2017:  Reloading Game Info Page
14:20:23.8  7/15/2017:  Returning to GameEx
14:20:31.4  7/15/2017:  21 Consecutive Exceptions Occured
14:20:31.4  7/15/2017:  Object reference not set to an instance of an object.
14:20:31.5  7/15/2017:     at GameEx.GameEx.MainForm.i(Boolean A_0, Boolean A_1)
14:20:31.5  7/15/2017:     at GameEx.GameEx.MainForm.df()
14:20:31.5  7/15/2017:  Trying reinitialising the display after sleeping for 4 seconds
14:20:31.5  7/15/2017:  Exception count will be dropped to 15
14:20:36.5  7/15/2017:  3  3
14:20:40.8  7/15/2017:  --**--
14:20:40.8  7/15/2017:  21 Consecutive Exceptions Occured: Exiting
14:20:40.8  7/15/2017:  Closing database connection
14:20:40.9  7/15/2017:  First Exception:
14:20:40.9  7/15/2017:  Object reference not set to an instance of an object.
14:20:40.9  7/15/2017:     at GameEx.GameEx.MainForm.i(Boolean A_0, Boolean A_1)
14:20:40.9  7/15/2017:     at GameEx.GameEx.MainForm.df()
14:20:40.9  7/15/2017:  Last Exception:
GameEx.ini
I figured this out.  It is because I retitled the Start Title in setup to remove the "NEC" in the title.  It crashed because it couldn't find the media to show.
  • Draco1962 changed the title to [RESOLVED] Mednafen Crashes
  • Draco1962 locked this topic
