Hello :D
I just started using GameEx. It runs very well. However, I am having problems with my roms. According to the other posts on the message board, I turned off "OnlyWorkingRoms, VerifyRoms, and GameFilterOn." with those adjusted, I still cannot play: X-Men vs SF, MSH vs SF, Marvel vs Capcom and a few others. When I try to play those games, the screen goes black (I assume loading), but then comes back to the game selection screen. If you guys know a way to remedy this situation, please let me know. Thank you.
P.S. I am using GameEx version 1.01 and for MAME, it is version 0.104(mame32p.exe).
Hello :D
The games work fine when playing them through mame only?
Yes they do. This is my first time with a frontend program. What needs to be done in order for me to play them all under Game Ex?
I'm getting ALMOST the exact same problem as you.
But in my case, I don't even see the games you mentioned in GameEx. All my filters are turned off and everything. I see them just fine in MAME when I run it solo, but in GameEx they don't even show up.
Anybody have any idea what could be causing this?
