wrd1972 Posted June 29, 2017 Share Posted June 29, 2017 Trying to customize these fields. Is it possible? Thanks Link to comment Share on other sites More sharing options...
Draco1962 Posted June 29, 2017 Share Posted June 29, 2017 Please provide your definition of customizable. Do you mean "Can you change the verbiage?" or "Can you remove them from view?" or any other question that better defines what you are asking. Thanks! Link to comment Share on other sites More sharing options...
Tom Speirs Posted June 29, 2017 Share Posted June 29, 2017 Some more detail would help but as an overview you have two options. As a registered user (which you are) you can use the Menu Editor. Another option is to set the text/language to custom and change the text. Link to comment Share on other sites More sharing options...
stigzler Posted June 29, 2017 Share Posted June 29, 2017 You could do both (change labels and menus) via the Custom menu function: Programs>GameEx>Configuration>Custom Menus 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted June 29, 2017 Share Posted June 29, 2017 6 hours ago, stigzler said: You could do both (change labels and menus) via the Custom menu function: Programs>GameEx>Configuration>Custom Menus Is my tutorial out of date now? Be brutal, and i will fix it. Link to comment Share on other sites More sharing options...
Draco1962 Posted June 30, 2017 Share Posted June 30, 2017 Well, are we talking GameEx or Arcade? Does the Custom Menu option work with AE? When we are given too little information or explanation of what the end-user is requesting it sets people wanting to help in a myriad of directions and makes for a more confusing resolution. Link to comment Share on other sites More sharing options...
DazzleHP Posted June 30, 2017 Share Posted June 30, 2017 1 minute ago, Draco1962 said: Well, are we talking GameEx or Arcade? Does the Custom Menu option work with AE? When we are given too little information or explanation of what the end-user is requesting it sets people wanting to help in a myriad of directions and makes for a more confusing resolution. Just my tutorial that i added like 5 years ago. Is it irrelevant or not? Link to comment Share on other sites More sharing options...
Draco1962 Posted June 30, 2017 Share Posted June 30, 2017 55 minutes ago, DazzleHP said: Just my tutorial that i added like 5 years ago. Is it irrelevant or not? I believe your tutorial is still relevant as relates to GameEx proper, but not AE as the Custom Menus application is not included with AE. 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted June 30, 2017 Share Posted June 30, 2017 I appreciate your frankness! Always. Coming back from a while, I'm not too familiar with the AE version. I'm thinking i should acquaint myself with it Link to comment Share on other sites More sharing options...
RedDog Posted June 30, 2017 Share Posted June 30, 2017 4 hours ago, Draco1962 said: Well, are we talking GameEx or Arcade? Does the Custom Menu option work with AE? When we are given too little information or explanation of what the end-user is requesting it sets people wanting to help in a myriad of directions and makes for a more confusing resolution. No, Custom Menus do not work with GameEx Arcade. I tested it some time back. 1 Link to comment Share on other sites More sharing options...
Draco1962 Posted June 30, 2017 Share Posted June 30, 2017 7 hours ago, RedDog said: No, Custom Menus do not work with GameEx Arcade. I tested it some time back. Yeah, I already knew the answer to this. Just an example of why we need the users to tell us what version of GameEx they are using and more detail of what they are asking. As you can see, we are, as of this post, 10 posts past the OP with responses going in several directions due to the lack of detail presented in the OP. Link to comment Share on other sites More sharing options...
stigzler Posted June 30, 2017 Share Posted June 30, 2017 On 29/06/2017 at 4:04 PM, wrd1972 said: Trying to customize these fields. Is it possible? Thanks Unfortunately, you cannot customise the font outlines or drop-shadows at the moment. However, Evo will contain many font customisation options... Link to comment Share on other sites More sharing options...
wrd1972 Posted July 1, 2017 Author Share Posted July 1, 2017 Sorry for delay guys. Been busy as Hell recently. I am speaking to "Gameex". To clarify, I want to remove line items from that menu. And revise the descriptions to something else also. For example, I want to change "MAME" to "Arcade games". I am also want to remove "multimedia" & "More games and programs" I poked around in the custommenu.ini but have not yet accomplished the items above. Someone mentioned a tutorial to do this. Could I please get a link? Thanks for all the assistance guys. Attached is the screen shot of the start menu currently being used. Link to comment Share on other sites More sharing options...
Draco1962 Posted July 1, 2017 Share Posted July 1, 2017 Always check the FAQ, Guides, and Other Useful Information section for these user-made tutorials. We have a Wiki as well that, while a little out of date with recent Setup Wizard changes, still contains info on where to make Text changes as well as where to go to Enable/Disable Features. Link to comment Share on other sites More sharing options...
stigzler Posted July 1, 2017 Share Posted July 1, 2017 On 29/06/2017 at 5:53 PM, stigzler said: You could do both (change labels and menus) via the Custom menu function: Programs>GameEx>Configuration>Custom Menus This guy made a good suggestion... 1 Link to comment Share on other sites More sharing options...
Draco1962 Posted July 1, 2017 Share Posted July 1, 2017 5 minutes ago, stigzler said: This guy made a good suggestion... Yes he did. 1 Link to comment Share on other sites More sharing options...
