I'm stuck and frustrated...help please rocketlauncher/PinbalX & PC games
Ok, ive manged to work out everything with pinballX but for the life of me i cannot get rocket launcher and PinballX working for lauching PC games
this is the error i get
Cannot find \Databases\PC Games\PC Games.xml
I have created a XML for rocketlauncher
setup rocketlauncher and can run the games from the launcher (red rocket) button
created game manager menu and populated
pointed the rocketlauncher to a bat file as shortcut fails.
What am i missing? pls help
thx
Can you attach copies of your pinballx.ini and log.txt files in reply to this thread?  Thanks.
Unfortunately I do not run Rocketlauncher from PinballX. The error image you posted looks like a Rocketlauncher error message to me, or at least I have not ever seen one like it from PinballX.
I would ask the RocketLauncher people, that's most certainly not a PBX issue.
Ok thanks both for replying...
is there another way to launch PC games from PinballX?
im looking at windows store games:
crossy road
disney crossy road
these a great games for children and suite my pinball/arcade hybrid.
thx
brit
Have you considered running GameEx Arcade and PinballX both on the same machine? You may find some options with GameEx a little easier to manage.
7 minutes ago, 32assassin said:
rocket launcher and PinballX don't get along nicely.
I tried to use it because I don't like to have multiple media folders for all the VP versions.
http://www.rlauncher.com/forum/forumdisplay.php?59-PinballX
but that's another story,   a "Database Not found" error is usually generated when you don't set a default front-end on your Rocketlauncher Settings.
thanks, yes this is what i have read and i have changed and tried all sorts.....frustrating.
ive even build a vmware windows 10 build and put pinballX and Rocketlauncher on it with nothing else and same error. im sure its just s pointer somewhere to the XML.
thanks for replying!
no but sorta defeats the objective to have one system, and my kids use it so want it super easy....:-)
i know if can be done as a TerryRed has done this....and a few others....hoping they will chime in and help
so....i have made progress....i can get the games to startup: crossy road.the xml error is no longer.
I changed the folder structure and it worked for some reason.
 only thing is pinballX is still there.....when the game loads...
onwards and upwards....
