Hello! I'm getting excited about GAMEEX, however I'm having problem with Model2 / model 3 emulator. The game does not open. What may be set up wrong? I could not find a solution in the search.
Thanks for any help.
GameEx.ini
First of all, your Model 2 and Model 3 emulators are not enabled:
Model 3
UseModel2=False
Model2PATH=D:\Emuladores\Sega Model2
ShowModel2=False
Model 3 -
ShowModel3=False
UseModel3=False
Model3PATH=D:\Emuladores\Sega Model3
Model3Options=-fullscreen -res=1920,1080
Do you have the Model 2 and Model 3 emulators installed? Generally, for Sega Model 3 path is going to read "C:\Emulators\Supermodel"
So please install the emulators if you haven't done so, then enable them in the appropriate section in GameEx Setup Wizard.
Next, launch GameEx and select Update List, and let it run. Try again to launch a game when this finishes and report back. Thanks.
Draco1962, I did exactly as you said and everything worked, but when adding the emulators by the "GameEx Setup Wizard", "Emulator Selection" the emulator is not entering the game, I added the DEMUL and when selecting the game the gameex is idle, however pressing "Home" it returns the selection of the games.
Any reason why you are not using the integrated Sega Model 2 and Model 3 support?
Load Setup Wizard and enable both via Custom. Then Update List. You can then see them in your list of games.
