Hi,
I'm becoming crazy with this situation. I have a cabinet with ipac2 board, which I programmed two buttons for volumedown and volumeup. When I use in pinballx they works as expected. Same behavior when I use them in Visual Pinball. But, when I use volumedown in a emulator (visual pinball or future pinball), launched from pinballx, the effect is the same that esc key. The emulator exits and pinballx comes in  front.
I suppose I'm doing something wrong but I have checked keys and there is not any place where volumedown appears as esc key in pinballx.
Thank you for your help!
Usually when asking for help we need to see a copy of your pinballx.ini and log.txt files. Click on the PinballX How to ask for help link in my signature for instructions on how to locate the files and attach the files in reply to this thread. Thanks!
Thanks, Draco.
th
this is my pinballx.ini:
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
FullScreenWindowed=False
[BackGlass]
monitor=1
x=0
y=0
width=1920
height=1080
AutoPositionB2S=True
UseB2S=False
[DMD]
monitor=2
x=0
y=200
width=1366
height=365
AutoPositionPinMAME=True
HidePinMAME=False
UsePinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
OneClickLaunch=False
EnableDefaultFilters=True
[Audio]
StreamVolume=50
SampleVolume=50
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=174
volumeup=175
credit=53
plunger=40
[JoyCodes]
quit=
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
Plunger=
[Text]
Line1=Juego gratuito
Line2=Pulsa start
Featuring=Presentando
Tables=Mesas
PlayGame=Jugar
Instructions=Instrucciones
Information=Informacion
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Salir
ReturnToGame=Volver al juego
Return=Volver
Exit=Salir
Shutdown=Apagar
All=Todas las mesas
[FuturePinball]
WorkingPath=F:\Games\Future Pinball\BAM
TablePath=f:\Games\Future Pinball\Tables
Executable=FPLoader.exe
Parameters=/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender /stayinram
LaunchBeforeEnabled=True
LaunchBeforeWorkingPath=f:\Games\Future Pinball
LaunchBeforeExecutable=FutureDMD.exe
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=False
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterExecutable=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=False
MouseClickFocus=True
LaunchBeforeParameters=table="[TABLEFILE]" Close=1
FPRAMPath=f:\Games\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=f:\Games\Visual Pinball
TablePath=f:\Games\Visual Pinball\Tables
Executable=VPinball993.exe
LaunchBeforeEnabled=false
LaunchBeforeWaitForExit=True
LaunchAfterWaitForExit=True
AutoConfigure=False
NVRAMPath=C:\Visual Pinball\VPinMAME\nvram
EnableFullScreenExclusiveHack=True
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=False
WorkingPath=
Executable=
Paramaters=
HideWindow=False
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[Internal]
lastwheelcachematchsize=-1123
lastselected=007 James Bond (Gottlieb 1980)007 James Bond (Gottlieb 1980)VisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Mesas
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff0000
[System_3]
WorkingPath=C:\Visual Pinball
Executable=VPinballx.exe
NAME=Visual Pinball X
SystemType=1
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=18
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,478
WindowLocation=709,153
[Plugin_1]
Enabled=False
Name=FutureDMDStats.dll
[Plugin_2]
Enabled=False
Name=PlugInLED.dll
[Plugin_3]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_4]
Enabled=False
[General]
Language=Spanish
[Plugin_5]
Enabled=False
Name=Xpadder Plugin.dll
[Topper]
monitor=2
and my log:
21:39:09.3  26/04/2017:  PinballX - Version 2.33
21:39:12.6  26/04/2017:  Windows 7 Ultimate Service Pack 1 64 bits (7,892578125GB)
21:39:12.6  26/04/2017:  Loading Settings
21:39:12.6  26/04/2017:  Initialize Component
21:39:12.6  26/04/2017:  Initialize Display
21:39:12.7  26/04/2017:  Loading PlugIns
21:39:13.9  26/04/2017:  Created DirectX BackGlass Window
21:39:13.9  26/04/2017:  Created DirectX DMD Window
21:39:14.0  26/04/2017:  Hiding Cursor
21:39:14.0  26/04/2017:  Hiding Taskbar
21:39:14.1  26/04/2017:  CPU:  Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
21:39:14.1  26/04/2017:  GPU 1: NVIDIA GeForce GTX 750 Ti
21:39:14.1  26/04/2017:  Displays: 3
21:39:14.1  26/04/2017:  Loading Font
21:39:14.1  26/04/2017:  Load Game List
21:39:14.1  26/04/2017:  Loading Database: Future Pinball
21:39:14.1  26/04/2017:  Loading Database: Visual Pinball
21:39:14.2  26/04/2017:  Finding and matching artwork and videos
21:39:16.0  26/04/2017:  Loading Game Statistics and Scores
21:39:16.1  26/04/2017:  Loading Surfaces
21:39:16.3  26/04/2017:  Finished Loading Surfaces
21:39:16.3  26/04/2017:  Initialize Audio
21:39:16.4  26/04/2017:  Set Keyboard Controls
21:39:16.4  26/04/2017:  Initialize Joystick
21:39:16.4  26/04/2017:  4 Joysticks Attached
21:39:16.4  26/04/2017:  Started
21:39:19.9  26/04/2017:  Exiting
21:39:20.4  26/04/2017:  Showing Taskbar
21:39:20.4  26/04/2017:  Unhiding Mouse Cursor
21:39:20.4  26/04/2017:  Disposing Plugins
21:39:20.4  26/04/2017:  Saving Settings
21:39:20.4  26/04/2017:  Bye
Thank you!
Please update to version 2.34 and attach your files (lots of scrolling is killing my smartphone and thumb). Locate them and just drag them to the bottom of your reply to attach them.
Hi. I resolved it! I don't know but pinballx was taking volumedown as the esc button of a joystick. I deleted the esc button in joystick section and it works!
Thank you!!
