I had GameEx working like a charm and than it just oneday wouldn't load.  Here are my ini and log files.  I don't know what the problem can be I uninstalled the version and than re installed it and still get a black screen.  Any ideas?"  Thanks
GameEx.ini
I had a similar problem Draco told me to disable touchscreen which got enabled sonehow and everything came back!!
Sent from my SM-J320P using Tapatalk
He is correct. Your gameex.ini file shows EnableTouchScreen=True. Edit the gameex.ini file manually and change it to False and Save, or make the change via Setup Wizard. Report back if this solves the issue. Thanks!
Thanks everyone, Turning touch screen off seemed to have worked.   I got it to work but it seems to have eliminated all my emulators I had set up.  Oh well at least Mame works
Check your gameex\config folder as there may be a backup copy with your configurations for your emulators.
