Anyone know how to stop this when trying to escape to pinballx
It's probably as easy as a check box just don't know
I have this set correctly and it works with FX 2 and ultra
The issue also happens when I launch vpx on its own
With Visual Pinball  I think you get that every time, at least I do.  I only use it for troubleshooting tables and testing so I have never dove into figuring out how to remove it, it does not happen inside of PinballX even though that is enabled in VP, for me anyway.
When you escape visual pinball that's what it does... Try hitting the Q on the keyboard twice..... not sure what you mean by escape to Pinballx..
I have a similar problem, but only when I am using a "custom" type system to launch visual pinball. If your system type is set to "Visual Pinball" then the pinballx "Exit simulation" button should work.
Also, you shouldnt map that "exit simulation" button elsewhere I think, so if you use ESC you must disable the ESC key in VP settings first.
You also map ESC twice, that is not a good idea. Use a specific button for "exit simulation" and you should be fine
