Hey Meshflesh, would you please attach your GameEx.ini file as well? You can find it in the GameEx\CONFIG folder.
Also, a screenshot of the error message that appears on your screen may help.
Thanks.
Thanks.
thank you redDog. I attached a screenshot of the error screen that pops up and attached the ini file
GameEx.ini
Please try deleting all the .png image files in the GameEx\Data folder. Also a reboot. If not a change of theme.
I can also see your running in 4k resolution. That could be something to do with it. Although GameEx has been known to work.
  • 1 month later...
