I can load my visual pinball tables into full screen if I don't use pinballx.  When using pinballx, the table won't load into full screen.  It appears that it loads the table into a "non" windowed resolution of 1024x768 which results in me seeing black areas on the top and bottom of the playfield.
I set pinballx to full screen and none windowed in the settings.  Am I missing something?  I checked my "ini" file and set it to 1920x1080, which is consistent with my monitor resolution.  Also, the pinballx application itself runs in full screen.  Any help would be greatly appreciated.  I have read many posts regarding issue this but nobody offered a solution.  Thanks again.
