Hi Everyone,
I have an interesting situation.  I have been using PinballX and VP992 working great. I decided to reformat my computer, and set up with the same settings for VP and PinballX that I had prior to the reformat.  For some reason, I can't launch any tables from PinballX.  It gets to the loading screen and then bounces me right back to the Wheel screen.  I can fire up the tables directly from Visual Pinball, so I know they work.  What files could be preventing PinballX from firing up VP tables?
Running Windows 10 Pro with all updates applied including the latest NVidia GeForce drivers.
Any help would be appreciate.
Thanks,
Jason
Hi Jason, you may want to provide copies of your pinballx.ini and log.txt files for review. Thanks!
Thanks for getting back to me.  It ended up being that "File Matching Enabled" was set to "No" under "General Settings" during the initial setup.  Once that was set to "Yes", everything fired up just fine.
Thanks!
Jason
