Having some trouble with getting anything to launch from game ex.  I have all my emulators set up and working.  They open the games etc..  but when I try to launch from game ex I can't get any of them to work.  I have set up all the paths and the on I am working on right now is Nestopia.  It verifys with no problem.  It starts to open Nestopia and load rom but gives me an error that a file can't be found.  I looked at the log file in nestopia and this is what I got
Language: loaded "english.nlg" version 1.41.1-0.0.1
Direct3D: initializing..
Direct3D: enumerating device - name: AMD Radeon HD 6570, GUID: D7B71EE2-2419-11CF-AE72-0905BEC2C535, index: 1
Direct3D: dynamic textures: supported
Direct3D: texture bilinear filtering: supported
Direct3D: max texture dimensions: 16384x16384
Direct3D: scanline effect: supported
Direct3D: vsync on every second refresh: supported
Direct3D: vsync on every third refresh: supported
Direct3D: found 15 display modes
Direct3D: supported monitor frequencies: 59hz, 60hz
Direct3D: creating HAL device #0
Direct3D: entering 1280x1024x32 60hz window mode
Selection of video adapter with ordinal "0" was ignored as it is already selected.
DirectSound: initializing..
DirectSound: enumerating device - name: Primary Sound Driver, GUID: unspecified
DirectSound: enumerating device - name: Speakers (Realtek High Definition Audio), GUID: 25835794-A88B-4239-8F69-1F9345EA3E94
DirectSound: enumerating device - name: Realtek Digital Output (Realtek High Definition Audio), GUID: 3821B326-B05D-49F4-AFE8-3E0C4F59B0FA
DirectSound: creating device #0
DirectInput: initializing..
DirectInput: enumerating device - name: Logitech Dual Action, GUID: 0B9E2850-CB52-11E6-8001-444553540000
DirectInput: enumerating device - name: USB Gamepad , GUID: CB677750-C467-11E6-8001-444553540000
DirectInput: enumerating device - name: Twin USB Gamepad      , GUID: C9B18B60-E39F-11E6-8001-444553540000
DirectInput: enumerating device - name: Twin USB Gamepad      , GUID: C9B18B60-E39F-11E6-8002-444553540000
DirectInput: found 4 attached joystick(s)
Timer: performance counter present (2278600 hz)
Kaillera: found "kailleraclient.dll" version 0.9
Launcher: database file "launcher.xml" not present
Database: 2894 items imported from internal DB
The only thing I can find is the Launcher file is missing.  How would I go about fixing that.  Thanks
Hi Ragnar,
Please post your GameEx.ini and log.txt files (attachments would be preferred). They can be found in the GameEx/CONFIG and GameEx/LOG directories. I use nestopia and it works just dandy.   :)
The first thing to check is that your GameEx config matches the pathing and file names of the emulator and roms. Please also post the paths to your Nestopia executable and roms. For example:
E:\Emulation\Nintendo_NES\Nestopia-1.41.1-(unofficial-x86)\nestopia.exe
E:\Emulation\Nintendo_NES\Roms
Next, what format are your rom files in (ie are the extensions .nes or .zip)?
I think if you search for " Launcher: database file "launcher.xml" not present" you will find your answer on various sites regarding this error for Nestopia and a solution.
tried looking for a solution can't find one specific,  but here is the log file cant find the ini file.  Sorry  I am looking at just the emulator 1 nes.  The rest are all screwed up yet.  Mame doesn't even open.  Anyway thanks for the help
11:53:56.8  1/27/2017:  Opening Configuration File
11:53:56.8  1/27/2017:  GameEx: Version 14.70: Starting Log
11:53:57.0  1/27/2017:  Windows 10 Pro 64-bit
11:53:57.0  1/27/2017:  Aero running
11:53:57.0  1/27/2017:  Initializing Vista/Windows 7 volume control
11:53:57.1  1/27/2017:  Getting CPU and RAM info
11:53:57.1  1/27/2017:  Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz, 8191MB
11:53:57.1  1/27/2017:  2.33Ghz - 4 Cores or CPU's
11:53:57.1  1/27/2017:  Running Randomize()
11:53:57.1  1/27/2017:  Loading PlugIns
11:53:57.1  1/27/2017:  Checking for applications to Launch On Startup
11:53:57.1  1/27/2017:  Setting default net connection limit to 15
11:53:57.1  1/27/2017:  Running Misc startup tasks
11:53:57.1  1/27/2017:  Setting Menu types
11:53:57.1  1/27/2017:  Getting Configuration Values
11:53:57.1  1/27/2017:  Using Theme: Default - Media Center - Background V1
11:53:57.1  1/27/2017:  Checking for alternate Image Directory for Theme: Default - Media Center - Background V1
11:53:57.1  1/27/2017:  Using Images from theme: Default - Media Center V1\MEDIA\
11:53:57.2  1/27/2017:  Launching HideOS.exe
11:53:57.2  1/27/2017:  Initialising Video/MNG DLL's
11:53:57.2  1/27/2017:  GameEx will check for media insertion (may affect performance)
11:53:57.2  1/27/2017:  Hiding Taskbar
11:53:57.2  1/27/2017:  Is Media Center running?
11:53:57.2  1/27/2017:  Checking/Creating LCD Registry values
11:53:57.2  1/27/2017:  Check Media Center Exit/Start Mode
11:53:57.2  1/27/2017:  Media Center Mode 2
11:53:57.3  1/27/2017:  Video previews on. Warning: Only recommended on modern systems
11:53:57.3  1/27/2017:  Snap Delay set to: 4
11:53:57.3  1/27/2017:  Get other settings
11:53:57.3  1/27/2017:  Desktop set to Hide ICONS and set Background to Black
11:53:57.3  1/27/2017:  Set: Find emulator artwork on best match basis
11:53:57.3  1/27/2017:  Start work for Form
11:53:57.3  1/27/2017:  Getting Original Screen Size
11:53:57.3  1/27/2017:  Opening Database Connection
11:53:57.5  1/27/2017:  Initializing Component
11:53:57.5  1/27/2017:  MAME Path is: C:\emulation\Emulators
11:53:57.5  1/27/2017:  MAME EXE file is: mame.exe
11:53:57.5  1/27/2017:  Cannot Find Mame.exe
11:53:57.5  1/27/2017:  Searching for MAME executable..
11:53:57.5  1/27/2017:  Cannot find MAME executable.
11:53:57.5  1/27/2017:  ROM Paths are: C:\GameEx\DEMO;C:\GameEx\DEMO\MAME
11:53:57.5  1/27/2017:  Loading Controls.ini map file
11:53:57.6  1/27/2017:  Applying Language/Text
11:53:57.6  1/27/2017:  Text/Language: English
11:53:57.6  1/27/2017:  Loading Language/Text
11:53:57.6  1/27/2017:  Using 3D Alpha Blended Animations.
11:53:57.6  1/27/2017:  Retrieving resolution setting
11:53:57.6  1/27/2017:  Error Loading Font: HandelGothic BT
11:53:57.6  1/27/2017:  Using General Font: Arial
11:53:57.6  1/27/2017:  Using Title Font: Arial
11:53:57.6  1/27/2017:  GameEx will try to reduce CPU usage
11:53:57.7  1/27/2017:  Initialising Direct3D
11:53:57.8  1/27/2017:  Applying GameEx is Loading Image
11:53:57.8  1/27/2017:  Setting Resolution to 1280x1024 32 bit color
11:53:57.9  1/27/2017:  Creating Surfaces
11:53:58.1  1/27/2017:  Creating Primary Surface - Full Screen Mode
11:53:58.1  1/27/2017:  Creating Back Buffer
11:53:58.1  1/27/2017:  Loading graphic Surfaces
11:53:58.1  1/27/2017:  Display is running at: 1280x1024 32bit color, 60hz
11:53:58.1  1/27/2017:  Adapter: AMD Radeon HD 6570
11:53:58.1  1/27/2017:  Max texture size: 16384x16384
11:53:58.1  1/27/2017:  Available texture memory: -15MB
11:53:58.1  1/27/2017:  Initialising Bass Audio Library
11:53:58.2  1/27/2017:  Creating Surfaces Misc and Dialogs
11:53:58.3  1/27/2017:  Creating Surfaces Volume
11:53:58.3  1/27/2017:  Creating Surfaces Arrows
11:53:58.3  1/27/2017:  Creating Surfaces GameEXlogo Text
11:53:58.3  1/27/2017:  Creating Surfaces Toolbar
11:53:58.3  1/27/2017:  Creating Surfaces Toolbar Controls
11:53:58.4  1/27/2017:  Creating Surfaces Backgrounds
11:53:58.4  1/27/2017:  Creating Surfaces GameEx Logo
11:53:58.5  1/27/2017:  Creating Surface Unselected
11:53:58.5  1/27/2017:  Creating Surfaces Home & Exit
11:53:58.5  1/27/2017:  Creating Surfaces Snaps
11:53:58.5  1/27/2017:  Creating Surfaces Menu and List Bars
11:53:58.8  1/27/2017:  Creating Fonts
11:53:58.8  1/27/2017:  Creating Game Font
11:53:58.8  1/27/2017:  Creating Game Font Faded
11:53:58.9  1/27/2017:  Creating Title Font
11:53:58.9  1/27/2017:  Restoring Title Font From Cache
11:53:59.0  1/27/2017:  Creating Menu Font
11:53:59.3  1/27/2017:  Creating Font Black
11:53:59.4  1/27/2017:  Creating Font Black Small
11:53:59.5  1/27/2017:  Fonts Created Succesfully
11:53:59.7  1/27/2017:  Initial Emulator Load
11:53:59.8  1/27/2017:  Loading Custom Emulators
11:53:59.8  1/27/2017:  Loading Emulator 1: Nintendo NES
11:53:59.8  1/27/2017:  Loading Emulator 2: Nintendo SNES
11:53:59.8  1/27/2017:  Loading Emulator 3: Nintendo N64
11:53:59.8  1/27/2017:  Loading Emulator 200: Nintendo NES
11:53:59.9  1/27/2017:  Checking if Steam enabled
11:53:59.9  1/27/2017:  Steam support is turned off in configuration.
11:54:00.0  1/27/2017:  Checking if Origin enabled
11:54:00.0  1/27/2017:  Origin support is turned off in configuration.
11:54:00.0  1/27/2017:  Checking if Uplay enabled
11:54:00.0  1/27/2017:  UPlay support is turned off in configuration.
11:54:00.1  1/27/2017:  MAME CMD options: -nowindow -joy -skip_gameinfo
11:54:00.1  1/27/2017:  Initialising DirectInput for Gamepad support
11:54:00.1  1/27/2017:  Using Device Logitech Dual Action
11:54:00.1  1/27/2017:  Using Device USB Gamepad
11:54:00.1  1/27/2017:  Using Device Twin USB Gamepad
11:54:00.2  1/27/2017:  Using Device Twin USB Gamepad
11:54:00.2  1/27/2017:  Loading Start Page
11:54:00.3  1/27/2017:  Initializing MCE Remote
11:54:00.3  1/27/2017:  Initialization OK! Starting GameEx!
11:54:00.3  1/27/2017:  Testing Main Loop Once: Processing Frame
11:54:00.6  1/27/2017:  Testing Main Loop Once: Main Loop ran successfully
11:54:04.2  1/27/2017:  Validating: Emulator_1: Snap Path: C:\Emulation\Emulators\Nestopia\snap
11:54:04.2  1/27/2017:  Validating: Emulator_1: Video Snap Path: C:\Emulation\Emulators\Nestopia\video
11:54:04.2  1/27/2017:  Validating: Emulator_1: Control Panel Path: C:\Emulation\Assets\Nintendo NES\Controls
11:54:04.2  1/27/2017:  Validating: Emulator_1: Database: [Console] Nintendo NES
11:54:04.2  1/27/2017:  Validating: Emulator_1: Title Snap Path: C:\Emulation\Emulators\Nestopia\title
11:54:04.2  1/27/2017:  Validating: Emulator_1: Box Art Path: C:\Emulation\Emulators\Nestopia\box
11:54:04.2  1/27/2017:  Validating: Emulator_1: Cart Art Path: C:\Emulation\Emulators\Nestopia\cart
11:54:04.2  1/27/2017:  Validating: Emulator_1: Manual Path: C:\Emulation\Emulators\Nestopia\manual
11:54:04.2  1/27/2017:  Validating: Emulator_2: Snap Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\SNAP
11:54:04.2  1/27/2017:  Validating: Emulator_2: Video Snap Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\Video
11:54:04.3  1/27/2017:  Validating: Emulator_2: Database: [Console] Nintendo SNES
11:54:04.3  1/27/2017:  Validating: Emulator_2: Title Snap Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\TITLE
11:54:04.3  1/27/2017:  Validating: Emulator_2: Box Art Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\BOX
11:54:04.3  1/27/2017:  Validating: Emulator_2: Cart Art Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\Cart
11:54:04.3  1/27/2017:  Validating: Emulator_2: Manual Path: C:\Users\Walker\Downloads\Nintendo_SNES_GameEx_System_Pack\MEDIA\Nintendo SNES\\-Matched-\Manual
11:54:04.3  1/27/2017:  Validating: Emulator_3: Snap Path: C:\GameEx\DEMO\N64\video
11:54:04.3  1/27/2017:  Validating: Emulator_3: Database: [Console] Nintendo N64
11:54:04.3  1/27/2017:  Validating: Emulator_3: Title Snap Path: C:\GameEx\DEMO\N64\titles
11:54:04.3  1/27/2017:  Validating: Emulator_3: Box Art Path: C:\GameEx\DEMO\N64\boxart
11:54:04.3  1/27/2017:  Validating: Emulator_3: Cart Art Path: C:\GameEx\DEMO\N64\cart
11:54:04.3  1/27/2017:  Validating: Emulator_3: Manual Path: C:\GameEx\DEMO\N64\manual
11:54:04.3  1/27/2017:  Validating: Emulator_200: Snap Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\SNAP
11:54:04.3  1/27/2017:  Validating: Emulator_200: Video Snap Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\Video
11:54:04.3  1/27/2017:  Validating: Emulator_200: Database: [Console] Nintendo NES
11:54:04.3  1/27/2017:  Validating: Emulator_200: Title Snap Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\TITLE
11:54:04.3  1/27/2017:  Validating: Emulator_200: Box Art Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\BOX
11:54:04.4  1/27/2017:  Validating: Emulator_200: Cart Art Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\Cart
11:54:04.4  1/27/2017:  Validating: Emulator_200: Manual Path: C:\Users\Walker\Downloads\Nintendo_NES_GameEx_System_Pack\MEDIA\Nintendo NES\\-Matched-\Manual
11:54:04.4  1/27/2017:  Restoring Emulator from Cache: 1
11:54:04.5  1/27/2017:  Restoring Emulator Database From Cache: 1
11:54:04.6  1/27/2017:  Restoring Emulator from Cache: 3
11:54:04.6  1/27/2017:  Restoring Emulator Database From Cache: 3
11:54:23.3  1/27/2017:  Extracting: C:\Emulation\Emulators\Nestopia\Fullset roms\.rar
11:54:23.8  1/27/2017:  Running: cmd.exe /c C: nestopia.exe C:\Users\Walker\AppData\Local\Temp\Unzipped7-Zip\3-D Battles of World Runner, The (U).nes
11:54:24.0  1/27/2017:  Shutting down display
11:54:29.8  1/27/2017:  Writing Stats
11:54:29.9  1/27/2017:  Plugin: Game Exit
11:54:29.9  1/27/2017:  Plugin: Process Commands
11:54:29.9  1/27/2017:  Refreshing Keyboard
11:54:30.0  1/27/2017:  Initialising Audio
11:54:30.1  1/27/2017:  Relaunching HideOS
11:54:30.3  1/27/2017:  Restoring Window
11:54:30.4  1/27/2017:  Reinitializing Graphics System
11:54:31.7  1/27/2017:  Reloading Game Info Page
11:54:31.9  1/27/2017:  Returning to GameEx
11:54:37.2  1/27/2017:  Exiting GameEx!
11:54:37.2  1/27/2017:  Disposing all videos
11:54:37.2  1/27/2017:  Deleting temporary Karaoke videos
11:54:37.2  1/27/2017:  Disposing Image List
11:54:37.2  1/27/2017:  Disposing Fonts
11:54:37.2  1/27/2017:  Disposing Surfaces
11:54:37.2  1/27/2017:  Saving Settings
11:54:37.2  1/27/2017:  Shutting down Bass
11:54:37.3  1/27/2017:  Closing HideOS.exe
11:54:37.5  1/27/2017:  Disposing Plugins
11:54:37.5  1/27/2017:  Closing database connection
11:54:37.5  1/27/2017:  Checking for applications to Launch On Exit
11:54:37.5  1/27/2017:  Bye
Hey Ragnar,
Without the GameEx.ini, troubleshooting is a lot more difficult. The file is pretty easy to find if you know where GameEx was installed and if Windows is not hiding is, so please try again. Find where GameEx was installed to on your PC. Inside the GameEx folder is a CONFIG folder. Inside thge CONFIG folder, you will find the GameEx.ini file. Depending on how your PC is set to display files, it may be simply called "GameEx". If you still cannot see it, do a little searching on the internet on how to make files on your PC visible.
If you do not have a GameEx.ini file to offer for the time being, take a snapshot of the nes configuration in GameEx (like below). A snapshot won't be anywhere as helpful, but maybe we can get you pointed in the right direction. Then, once you have Nestopia running in GameEx, hopefully it will give you what you need to get some of your other emulators working.  :)
Also, we would still need to confirm the directory paths to nestopia and the roms so we cna be sure you have configured GameEx correctly (as I had commented above).
Lastly, the log shows GameEx trying to extract something from "C:\Emulation\Emulators\Nestopia\Fullset roms\.rar". Your roms aren't archived into a single rar file, are they?
For example, this is a snapshot from my nestopia for page 1 of the Emulator Setup:
This is just my opinion, but I would strongly recommend not having anything under  C:\Users\ . This is usually a protected area as is anything under C:\Program Files or C:\Program Files (x86) and can cause problems, especially if you have multiple users on the same machine.
GameEx.ini
#1: Put quotes around [ROMPATH]\[ROMFILE] in the command line
#2: Change the Zip/7-Zip/Good/Merge/RAR parameter under Advanced Emulator Setup to No
#3: I strongly agree with @Draco1962 that placing any assets in a user folder is not a good idea
If it is still not working, please repost another GameEx.ini and log.txt after the attempt.
Also, please do not copy and paste your log.txt file! Attach it like you did for your gameex.ini file. Some of us may respond to your thread via smartphone and all the scrolling is killing me, Smalls!
Thanks for your help everyone.  The " marks did the trick.  I have moved everything from the users folder.  I am down to just few more quirks and then I should be good to go.  Mame shows the the bezels from the actual arcade which in turn makes my game play tiny on the screen, I would like to know what to change to make that go away.  NES and SNES open emulators and load games, but I still see the emulator.  If I check the hide desktop all I get is a black screen that I can't exit out of.  Finally the N64 emulator will not load rom.  If says that it was a failed attempt to load rom, but I can load it straight from the emulator and everything works.  Any ideas would be great.
GameEx.ini
Glad you made some headway on NES. Getting one emulator to work in through GameEx does make getting others working a bit easier.
Normally, we ask that you create one thread for each issue (or group of issues if they are related). It can get confusing when we start talking about multiple issues in the same thread. Please do this for N64 and the Hide Desktop issues and include the files like you did just above. Thanks
As for the other questions, I think this will help. Different emulators have different settings. Sometimes you have to hunt them down, but I happen to use both Nestopia and Snes9x.
MAME BEZELS:
There is an option under Advance Mame Settings called Use Bezel.
NESTOPIA FULL SCREEN:
I believe this command line will get you what you want:
Nestopia.exe "[ROMPATH]\[ROMFILE]" -video fullscreen
There is also an option in Nestopia under View > Show > Menu/Dialog that needs to be unchecked.
SNES9X FULL SCREEN:
...and this one for SNES9x:
snes9x-x64.exe -fullscreen "[ROMPATH]\[ROMFILE]"
There is an option in SNES9x under Video > Hide Menubar that should be checked.
