I work with VP9 and VPX ... and have a cabinet with 3 monitors.... It works alright a long time ago... but the computer was broke.... so now I have a other motherboard and try it to get working again....
a old movie...
if I change my backglass monitor in display 3 than , in the game is the backglass okay.... but in PinballX is on the wrong monitor?
It stands on the same als the Led display....
so if I use display 2 then it is good in the front_end... but wrong if I play the table... us I display 3 it is wrong in the front_end, but good wen I play the table....  Help please!!!
I only change it in the setting from PinballX... Must I change more settings?
Might be a good idea to attach copies of your pinballx.ini and log.txt files for review. Click on the PinballX How to ask for help link in my signature for instructions on how to locate the files.
it is working :-)
auto backglass position off... and everthing is working alright!!!
