Hi,
When holding a flipper button too long the keyboard buffer overflows after 8 seconds (-ish) and starts beeping really short beeps.
After that I can use the flipper keys, or any other for that matter, once every other click until I reboot my system.
This issue only appears when launching a Visual Pinball game through PinballX (latest version).
Playing them without the front end poses no issue.
It's kinda annoying while cradling in multiball.
I am aware this is not the default Windows Sticky keys. These are disabled for ages.
Can only reproduce when PinballX is loaded. Without it, the system works fine. MAME games, ProPinball, PinballFX etc. etc.
Specs : Gigabyte Z97xSLi * Intel i5-4690 * 2 x Asus GTX650Ti-boost * IPAC * ledwiz etc. etc.
Anyone of you have a suggestion for me where to look?
Thanks in advance!
Can you provide copies of your pinballx.ini and log.txt files as attachments in reply to this thread? Thanks!
Ah, silly me. Totally forgot to add those two.
Here they are.
I started a new game of AFM on 21:14:59
Launched a bal and held the right flipperbutton. It beeped within 8 seconds.
After releasing the flipperbutton I can't use it again. Have to press any other button to be able to use the right button again.
But can use it only once before it stops working again. Odd huh? :)
Full reboot solves the issue.
I'm completely in the dark with this strange behavior.
PinballX.ini
From PBX I launched various J P Salas VP tables and held either flipper at least 10 secs and could not produce an overflow. i7-6700 16 gig Windows 10 Pro GTX1080
Using keyboard because my cab buttons are not wired up yet. Logitech wireless.
I'm on the latest version of Vpinball (10.2), but this issue was persistent with all previous versions too.
It also happens on other games launched through PinballX. For example PinballFX, Propinball, Future Pinball, VPDX_9, VPhysmod etc.
When launched directly without the use of the front end all is okay.
I have a USB keyboard, but play with the IPAC connected to a USB port. Both have been switched around to no avail.
Even tried with only a PS2 keyboard, same result.
Remapping keys no luck either.
Updating to the latest BIOS didn't matter either, but that was to be expected.
Last resort is always a format C, but I'd rather not.
