Having a meltdown moment!! Help with Nintendo!!
Hi all-
I had my system set up as a MAME system primarily, but now want to use the JNES but forgot how to do it show the emulator shows up?!?! Please help!! Just keep blanking out and I know it is something really simple! Thank you!
HI Han-
Where is that located?? I can't seem to find it?!?!
When you open your GameEx configuration, it's either the first or second option on the emulator's config screen. Set that to 'YES'.
Hope that helps! :)
Hate to be a pest, but I still don't see it..can you do a screen capture so I can try and locate it that way?? Many thanks..
Sure thing.. here ya go:
Sorry I didn't crop it down or anything.. I'm using pcAnywhere to gain remote access to my MCE computer from my main computer.
Heya Han-
I guess my next question (thanks for the graphic by the way!) is what initial screen did you click on to get to the emulators?? I used to know where the hell is was, but have looked everywhere and can't see where to get to that screen. I appreciate your time in this matter!
Its like page #4 of the program. Launch the configurator program, and click NEXT until you get to the emulators.
Man do I feel STOOPID!! Thanks again Han!! Everything is good again!! Geez....I guess sometimes the easiest things quickly become difficult when over analyzed! :)
