Table crash with sound loop when ball hits flipper
I have a Physmod version of Getaway that works fine when load it from Visual Pinball but when try from PinballX it ALWAYS crashes to desktop as soon as the ball hits either of the lower flippers (upper flipper is fine). As well as crashing to desktop the sound just loops making an awful noise that only a reboot will clear.
I have over 100 tables set up in PinballX including about 20 Physmod ones and this is the only one that does this.
Really confused to why it works fine outside of PinballX... Any ideas?
Please provide copies of your pinballx.ini and log.txt files for review. Click on the PinballX How to ask for help link in my signature for instructions on how to locate the files and submit them for review. Thanks.
Discovered that it doesn't actually crash to desktop, rather VP crashes and it goes back to PinballX but with the awful sound loop.
PinballX.ini
Spoiler
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=1
x=0
y=0
width=1280
height=1024
UseB2S=False
[DMD]
Enabled=False
monitor=2
x=500
y=900
width=518
height=134
AutoPositionPinMAME=True
[FileSystem]
EnableFileMatching=False
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
WheelOverlay=3
OneClickLaunch=False
[Audio]
StreamVolume=90
SampleVolume=10
PlaySoundInVideos=True
[Startup]
playsound=False
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=19
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=X:\Emulation\Pinball\Visual Pinball
TablePath=X:\Emulation\Pinball\Visual Pinball\Tables
Executable=VPinball992.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
WorkingPath=X:\test
TablePath=X:\test\roms
Executable=mame.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[Internal]
lastwheelcachematchsize=636710
lastselected=Getaway - High Speed II (Williams 1992)Getaway 1.0.1 VP9.2 FS Physmod5System_2
filter_year=
filter_company=
filter_custom=
filtername=Tables
lastwheelcachematchsize2=13309
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=20
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=650,479
WindowLocation=635,280
[System_2]
Name=Physmod5
SystemType=1
TablePath=X:\Emulation\Pinball\Visual Pinball\Tables\Physmod5
Executable=VPinball99_PhysMod5.exe
[System_3]
Name=VPinball921
Executable=VPinball921.exe
SystemType=1
[System_4]
Name=VPinballX
TablePath=X:\Emulation\Pinball\Visual Pinball\Tables\VPinballX
Executable=VPinballX.exe
SystemType=1
[System_5]
Name=VPinball8
Executable=VPinball8.exe
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[System_6]
Name=VPX Beta
WorkingPath=X:\Emulation\Pinball\VPX Beta
Executable=vpinballx.exe
Parameters=
Enabled=False
SystemType=1
Spoiler
And log.txt
Spoiler
17:23:14.3  21/12/2016:  PinballX - Version 2.28
17:23:14.4  21/12/2016:  Windows 10 Pro 64-bit (7.9GB)
17:23:14.4  21/12/2016:  Loading Settings
17:23:14.4  21/12/2016:  Initialize Component
17:23:14.4  21/12/2016:  Initialize Display
17:23:15.7  21/12/2016:  Loading PlugIns
17:23:16.1  21/12/2016:  Created DirectX BackGlass Window
17:23:16.2  21/12/2016:  Hiding Cursor
17:23:16.3  21/12/2016:  Hiding Taskbar
17:23:16.4  21/12/2016:  CPU:  Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
17:23:16.4  21/12/2016:  GPU 1: NVIDIA GeForce GTX 1070
17:23:16.4  21/12/2016:  Displays: 2
17:23:16.5  21/12/2016:  Load Game List
17:23:16.5  21/12/2016:  Loading Database: Visual Pinball
17:23:16.6  21/12/2016:  Loading Database: Physmod5
17:23:16.6  21/12/2016:  Loading Database: VPinballX
17:23:16.6  21/12/2016:  Finding and matching artwork and videos
17:23:17.1  21/12/2016:  Loading Game Statistics and Scores
17:23:18.1  21/12/2016:  Loading Surfaces
17:23:18.2  21/12/2016:  Finished Loading Surfaces
17:23:18.2  21/12/2016:  Initialize Audio
17:23:18.5  21/12/2016:  Set Keyboard Controls
17:23:18.5  21/12/2016:  Initialize Joystick
17:23:18.8  21/12/2016:  3 Joysticks Attached
17:23:18.8  21/12/2016:  Started
17:23:28.1  21/12/2016:  Launch System
17:23:28.1  21/12/2016:  Waiting for threads
17:23:28.1  21/12/2016:  Disposing display
17:23:30.4  21/12/2016:  X:\Emulation\Pinball\Visual Pinball\VPinball99_PhysMod5.exe /play -"X:\Emulation\Pinball\Visual Pinball\Tables\Physmod5\Getaway 1.0.1 VP9.2 FS Physmod5.vpt"
17:23:30.5  21/12/2016:  X:\Emulation\Pinball\PinballX\vpauto.exe
17:23:38.5  21/12/2016:  Hidden Visual Pinball Editor Window
17:24:08.0  21/12/2016:  Created DirectX BackGlass Window
17:24:15.8  21/12/2016:  Exiting
17:24:17.0  21/12/2016:  Showing Taskbar
17:24:17.1  21/12/2016:  Unhiding Mouse Cursor
17:24:17.2  21/12/2016:  Disposing Plugins
17:24:17.2  21/12/2016:  Saving Settings
17:24:17.2  21/12/2016:  Bye
Here is another log file, this time tried a few other tables first.
Spoiler
22:04:55.3  22/12/2016:  PinballX - Version 2.28
22:04:55.4  22/12/2016:  Windows 10 Pro 64-bit (7.9GB)
22:04:55.4  22/12/2016:  Loading Settings
22:04:55.5  22/12/2016:  Initialize Component
22:04:55.5  22/12/2016:  Initialize Display
22:04:56.9  22/12/2016:  Loading PlugIns
22:04:57.4  22/12/2016:  Created DirectX BackGlass Window
22:04:57.5  22/12/2016:  Hiding Cursor
22:04:57.6  22/12/2016:  Hiding Taskbar
22:04:57.7  22/12/2016:  CPU:  Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
22:04:57.7  22/12/2016:  GPU 1: NVIDIA GeForce GTX 1070
22:04:57.7  22/12/2016:  Displays: 2
22:04:57.8  22/12/2016:  Load Game List
22:04:57.8  22/12/2016:  Loading Database: Visual Pinball
22:04:57.9  22/12/2016:  Loading Database: Physmod5
22:04:57.9  22/12/2016:  Loading Database: VPinballX
22:04:57.9  22/12/2016:  Finding and matching artwork and videos
22:04:58.1  22/12/2016:  Loading Game Statistics and Scores
22:04:58.6  22/12/2016:  Loading Surfaces
22:04:58.7  22/12/2016:  Finished Loading Surfaces
22:04:58.7  22/12/2016:  Initialize Audio
22:04:59.0  22/12/2016:  Set Keyboard Controls
22:04:59.0  22/12/2016:  Initialize Joystick
22:04:59.3  22/12/2016:  3 Joysticks Attached
22:04:59.3  22/12/2016:  Started
22:05:06.9  22/12/2016:  Launch System
22:05:06.9  22/12/2016:  Waiting for threads
22:05:07.0  22/12/2016:  Disposing display
22:05:08.1  22/12/2016:  X:\Emulation\Pinball\Visual Pinball\VPinballX.exe /play -"X:\Emulation\Pinball\Visual Pinball\Tables\VPinballX\No Good Gofers (Williams 1997) 1.0.vpx"
22:05:10.4  22/12/2016:  X:\Emulation\Pinball\PinballX\vpauto.exe
22:05:26.2  22/12/2016:  Found PinMAME ROM: ngg_13.nv
22:05:26.3  22/12/2016:  Hidden Visual Pinball Editor Window
22:06:16.6  22/12/2016:  Exit System Control Pressed
22:06:20.4  22/12/2016:  Created DirectX BackGlass Window
22:06:29.7  22/12/2016:  Launch System
22:06:29.7  22/12/2016:  Waiting for threads
22:06:29.7  22/12/2016:  Disposing display
22:06:30.6  22/12/2016:  X:\Emulation\Pinball\Visual Pinball\VPinball992.exe /play -"X:\Emulation\Pinball\Visual Pinball\Tables\Phantom_of_the_Opera_LH_rob046_Mod_FS_v2.04.vpt"
22:06:30.8  22/12/2016:  X:\Emulation\Pinball\PinballX\vpauto.exe
22:06:41.7  22/12/2016:  Hidden Visual Pinball Editor Window
22:07:01.7  22/12/2016:  Exit System Control Pressed
22:07:05.3  22/12/2016:  Created DirectX BackGlass Window
22:07:14.2  22/12/2016:  Launch System
22:07:14.2  22/12/2016:  Waiting for threads
22:07:14.2  22/12/2016:  Disposing display
22:07:15.1  22/12/2016:  X:\Emulation\Pinball\Visual Pinball\VPinball99_PhysMod5.exe /play -"X:\Emulation\Pinball\Visual Pinball\Tables\Physmod5\Rocky & Bullwinkle_HR_FS_VP_physmod5_Ver_1.3b.vpt"
22:07:15.5  22/12/2016:  X:\Emulation\Pinball\PinballX\vpauto.exe
22:07:21.0  22/12/2016:  Hidden Visual Pinball Editor Window
22:07:53.2  22/12/2016:  Exit System Control Pressed
22:07:56.1  22/12/2016:  Created DirectX BackGlass Window
22:08:11.1  22/12/2016:  Launch System
22:08:11.1  22/12/2016:  Waiting for threads
22:08:11.1  22/12/2016:  Disposing display
22:08:11.9  22/12/2016:  X:\Emulation\Pinball\Visual Pinball\VPinball99_PhysMod5.exe /play -"X:\Emulation\Pinball\Visual Pinball\Tables\Physmod5\Getaway 1.0.1 VP9.2 FS Physmod5.vpt"
22:08:12.0  22/12/2016:  X:\Emulation\Pinball\PinballX\vpauto.exe
22:08:17.4  22/12/2016:  Hidden Visual Pinball Editor Window
22:08:55.9  22/12/2016:  Created DirectX BackGlass Window
22:08:59.8  22/12/2016:  Exiting
22:08:59.9  22/12/2016:  Showing Taskbar
22:08:59.9  22/12/2016:  Unhiding Mouse Cursor
22:09:00.0  22/12/2016:  Disposing Plugins
22:09:00.0  22/12/2016:  Saving Settings
22:09:00.0  22/12/2016:  Bye
