[RESOLVED] GameEx Arcade 14.67 - Xbox 360 Controller Mapping Issue
Hi Tom - I am really liking the updates to GameEx Arcade. I have both Sega Model 2 and Model 3 in addition to MAME running well.
One thing I noticed from the first release to current is that the Xbox 360 Controller is not properly mapped. When I press the A key, nothing happens. B key is selecting and Y key is going back. When I go into the Setup Wizard to try to set the keys and clear the entry and press the key, nothing happens.
The controls seem to work fine within the games, however. I have confiormed that I am running as administrator. Not sure what else to try.
Attached are my gameex.ini and log.txt files, but not sure they are going to be of much help.
GameEx.ini
Still have the same issue after 14.68. I have looked through the gameex.ini and cannot find where the settings for the key settings are located. Behavior has the B key as Select instead, Y key as Back. A key nonfunctional.
I have had no problems with the same 360 controller in regular GameEx. Also, when I clear and attempt to register the keypress in Arcade, it will not update the field.. As I noted, I cannot find anywhere in the .ini where I can manually change it back, but not that it matters at this point because it wasn't working before when the keycode entry was there for the A button.
OK, hanging head in shame. I will give that a try tonight. I was obviously attempting the section above that.
<INSERT DERP FACE HERE>
Marking issue as resolved. I enabled the Custom Joystick controls and all is well in the world. Thanks Tom!
