Hi Tom,
The shutdown issue we discussed and you worked on here:
Seems to be present again under Win10. I've started a new build using the latest version of Windows 10 and so far its giving me far better results in term of video performance. However any attempt to run a program in the PinballX 'run before exit' option seems to stop the shutdown completely regardless of the 'wait before end' setting. Exit works just fine it just seems that there needs to be a longer delay on the shutdown execution. Alternatively (and probably simpler) would be for the shutdown selection to simply bypass and ignore the 'run before exit' option.
