I have just started to use Pinball X for the first time and am having a few issues.
I am using a resolution of 1440x2560 for Pinball FX2 and when i loaded up PinballX the backglass image it correctly position but when i load a table then the backglass image disappears and then reappears but now its shifted over to the left, now im guess this is because im not using 1080p resolution how to i get the image to display centred when using 1440p?
In windows i have set the task bar to auto hide, when in PinballX it seems to bring the taskbar out of hiding each time i load a table, how do i stop this from happening?
A few tables dont appear to display the backglass image despite the name of the backglass being correct and using this same backglass image that loads up fine when just loading Pinball FX2 (without PinballX), any ideas why a few tables dont display the backglass in PinballX?
I have noticed for every table that after about 10 seconds of the table loading it seems to auto start a game, im guessing the 'enter' key is being pressed by PinballX, how do i stop this from happening?
For the time being i think thats it, thanks for any help given!!
Well the first problem, when using a resolution of 1440p for the playfield monitor, it seems to shift over the backglass when the Pinball FX2 table actually loads, so the backglass isnt centred anymore
We could really use your pinballx.ini and log.txt files. Help us help you by clicking on the link Carny provided. Thanks!
Sorry for the delay, i have attached the log and ini files
The backglass shifting issue seems to have sorted it self but im still having issues with....
1. Tables seem to automatically start after about 10 seconds of the table loading, im guessing the 'enter' key is being pressed by PinballX?
2. The auto hide task bar popping up on the blackglass monitor each time i load a table
3. A few tables dont appear to display the backglass image despite the name of the backglass being correct and using this same backglass image that loads up fine when just loading Pinball FX2 (without PinballX), any ideas why a few tables dont display the backglass in PinballX?
PinballX.ini
1. Yes, PinballX starts a single player game for you. I'm not aware of options to do otherwise.
2. Do not use auto hide task bar. PinballX will hide the task bar for you when you start PinballX.
3. With PinballX displaying the backglass you don't need Pinball FX2 to display an image also. Just turn off that feature in the Pinball FX2 cab support settings
Sent from my iPad using Tapatalk
Thanks for the help. So there is no way to stop the auto start table option then?, this is a shame as a fair few Marvel Pinball FX tables have 'intros' at the start and Pinballx always cuts these off as it auto starts the table
