Hi all!! :(
Bad news from here... My GameEx setup continue crashing randomly and can't do nothing to resolve it...
As some of you know, I post this problem on the forum some days ago, the problem supposed resolved, but now I see it's not... I'm desperate...
Attached logs.
The message Windows shows when GameEx crash is:
Quote
Descripción:
  Stopped working
Archivos que ayudan a describir el problema:
  C:\Users\Retro Dream\AppData\Local\Temp\WER2FF6.tmp.WERInternalMetadata.xml
  C:\Users\Retro Dream\AppData\Local\Temp\WER3BBA.tmp.mdmp
Lea nuestra declaración de privacidad en línea:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0c0a
Si la declaración de privacidad en línea no está disponible, lea la declaración de privacidad sin conexión:
  C:\Windows\system32\es-ES\erofflps.txt
I saw the GameEx log and all seems to be correct, but there is another log called "background_log" that seems to have a problem. I don't understand what's the meaning of that problem or if could be the reason of my crashes.
As you know, I've reinstalled GameEx several times to try correct the problem, but this has no effect.
The crashes are random. Sometimes I can navigate and play games without problems for hours, but other times when I navigating throught list the crash appears and GameEx closes.
My video drivers are up to date, and Windows Updates are up to date. The LAV codecs are installed correctly, and I haven't another programs but emulators. This is my machine for gamin. I don't use it for anything else...
Please, any suggestions to try solve this big problem?
Today installed latest version, but the problem still happening randomly....
Thanks in advance to all of you.
background_log.txt
GameEx.ini
Hi Tom, I've taken some time to answer because I wanted to be sure that the error had been corrected.
I tried GameEx for several hours and it seems that the crashes are gone.
I wanted to thank you for your quick solution to the problem with the last update.
As always, you solve the problems very quickly and that makes GameEx the best frontend.
Thank you for your great work Tom.
