[RESOLVED] Exiting emulator always goes to desktop
Hey guys.  I'm using PinballX with Visual Pinball.  Launching games is fine, but when I exit the emulator and hope to go back to the PinballX launcher, I instead always go to desktop.  This is what my log says:
19:42:43.0  10/27/2016:  PinballX - Version 2.27
19:42:43.1  10/27/2016:  Windows XP Professional Service Pack 3 (3.2GB)
19:42:43.1  10/27/2016:  Loading Settings
19:42:43.2  10/27/2016:  Initialize Component
19:42:43.2  10/27/2016:  Initialize Display
19:42:44.3  10/27/2016:  Loading PlugIns
19:42:44.4  10/27/2016:  Created DirectX BackGlass Window
19:42:44.6  10/27/2016:  Hiding Cursor
19:42:44.6  10/27/2016:  Hiding Taskbar
19:42:44.7  10/27/2016:  CPU:  AMD Athlon(tm) Dual Core Processor 4450e
19:42:44.7  10/27/2016:  GPU 1: NVIDIA GeForce GTS 250
19:42:44.7  10/27/2016:  Displays: 2
19:42:44.7  10/27/2016:  Load Game List
19:42:44.7  10/27/2016:  Loading Database: Visual Pinball
19:42:44.7  10/27/2016:  Loading Custom Database: Copy of Visual Pinball
19:42:44.8  10/27/2016:  Finding and matching artwork and videos
19:42:46.1  10/27/2016:  Loading Game Statistics and Scores
19:42:46.1  10/27/2016:  Loading Surfaces
19:42:46.5  10/27/2016:  Finished Loading Surfaces
19:42:46.5  10/27/2016:  Initialize Audio
19:42:46.6  10/27/2016:  Set Keyboard Controls
19:42:46.6  10/27/2016:  Initialize Joystick
19:42:46.6  10/27/2016:  1 Joystick Attached
19:42:46.6  10/27/2016:  Started
19:42:49.3  10/27/2016:  Launch System
19:42:49.3  10/27/2016:  Waiting for threads
19:42:49.3  10/27/2016:  Disposing display
19:42:51.2  10/27/2016:  C:\Visual Pinball\VPinball992.exe /play -"C:\Visual Pinball\Tables\TAF VP91X FS 2.0.1.vpt"
19:42:51.2  10/27/2016:  C:\PinballX\vpauto.exe
19:42:58.9  10/27/2016:  Hidden Visual Pinball Editor Window
19:42:59.6  10/27/2016:  Found PinMAME ROM: taf_l7.nv
19:43:02.7  10/27/2016:  Exit System Control Pressed
19:43:05.7  10/27/2016:  Error in the application.
19:43:05.7  10/27/2016:  Exeption intializing display. Trying full screen windowed.
19:43:05.7  10/27/2016:  Error. Exiting
19:43:05.7  10/27/2016:     at PinballX.Main.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4)
19:43:05.7  10/27/2016:     at PinballX.Main.ap()
19:43:05.7  10/27/2016:     at PinballX.Main..ctor()
19:43:05.7  10/27/2016:  Disposing Plugins
19:43:05.7  10/27/2016:  Showing Taskbar
19:43:05.7  10/27/2016:  Unhiding Mouse Cursor
19:43:05.7  10/27/2016:  Bye
Can someone tell me what might be going wrong?
Hello dinki,
make sure that you use different key Settings for "Quit" (which will Exit PinballX) and "Exit Simulator" (which will just Exit Visual Pinball (for example).
Using the same key may lead to the issue you´ve discribed.
Easiest way is to leave the Setting for "Quit" empty. This should solve your Problem.
Kind regrds,
Jannek
Thanks for the reply.  I tried this and it didn't work.
Oddly when I booted the machine up this afternoon the pinballx gui and playfield was on the back box monitor and when I tried it it did exit back to Pinball X.  I managed to get the display back in order (I think by rebooting), but now I'm crashing back to desktop when exiting the emulator.  I don't know what to make of this.
Can anyone tell me what to check?
I'm getting pretty desperate.  No one has encountered this before or can even give me a clue as to what to check?
Here's another log:
:27:04.5  10/30/2016:  PinballX - Version 2.27
17:27:04.7  10/30/2016:  Windows XP Professional Service Pack 3 (3.2GB)
17:27:04.7  10/30/2016:  Loading Settings
17:27:04.7  10/30/2016:  Initialize Component
17:27:04.8  10/30/2016:  Initialize Display
17:27:06.0  10/30/2016:  Start with windows is set so waiting 5 seconds. Boot Time = 10/30/2016 5:24:21 PM
17:27:14.9  10/30/2016:  Loading PlugIns
17:27:15.0  10/30/2016:  Created DirectX BackGlass Window
17:27:15.1  10/30/2016:  Hiding Cursor
17:27:15.1  10/30/2016:  Hiding Taskbar
17:27:15.2  10/30/2016:  CPU:  AMD Athlon(tm) Dual Core Processor 4450e
17:27:15.2  10/30/2016:  GPU 1: NVIDIA GeForce GTS 250
17:27:15.2  10/30/2016:  Displays: 2
17:27:15.2  10/30/2016:  Load Game List
17:27:15.2  10/30/2016:  Loading Database: Visual Pinball
17:27:15.3  10/30/2016:  Loading Custom Database: Copy of Visual Pinball
17:27:15.3  10/30/2016:  Finding and matching artwork and videos
17:27:16.6  10/30/2016:  Loading Game Statistics and Scores
17:27:16.6  10/30/2016:  Loading Surfaces
17:27:16.9  10/30/2016:  Finished Loading Surfaces
17:27:16.9  10/30/2016:  Initialize Audio
17:27:17.0  10/30/2016:  Set Keyboard Controls
17:27:17.1  10/30/2016:  Initialize Joystick
17:27:17.1  10/30/2016:  1 Joystick Attached
17:27:17.1  10/30/2016:  Started
17:27:21.3  10/30/2016:  Launch System
17:27:21.3  10/30/2016:  Waiting for threads
17:27:21.3  10/30/2016:  Disposing display
17:27:23.2  10/30/2016:  C:\Visual Pinball\VPinball992.exe /play -"C:\Visual Pinball\Tables\Whirlwind_VP9.2+_1.0.1_FS.vpt"
17:27:23.3  10/30/2016:  C:\PinballX\vpauto.exe
17:27:36.9  10/30/2016:  Hidden Visual Pinball Editor Window
17:27:38.2  10/30/2016:  Found PinMAME ROM: whirl_l3.nv
17:28:00.7  10/30/2016:  Exit System Control Pressed
17:28:04.3  10/30/2016:  Error in the application.
17:28:04.3  10/30/2016:  Exeption intializing display. Trying full screen windowed.
17:28:04.3  10/30/2016:  Error. Exiting
17:28:04.4  10/30/2016:     at PinballX.Main.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4)
17:28:04.4  10/30/2016:     at PinballX.Main.ap()
17:28:04.4  10/30/2016:     at PinballX.Main..ctor()
17:28:04.4  10/30/2016:  Disposing Plugins
17:28:04.4  10/30/2016:  Showing Taskbar
17:28:04.4  10/30/2016:  Unhiding Mouse Cursor
17:28:04.4  10/30/2016:  Bye
On addition to the log file, can you provide your pinballx.ini file? Please attach it as opposed to pasting in your reply .
I found the problem after tinkering with it for quite a while.  I had to turn, and this is from memory, exclusive full screen mode off or something similar.
  • 6 months later...
Im having this same issue right now. Started when I just added my controller and xpadder. If I unplug controller and just use keyboard it's fine, with controller and mapped with xpadder it crashes to desktop. Pinball FX2 tables do not crash to desktop, but VP and FP do.
My log is identical to OP's
I just want to make sure this isn't the same issue you are reporting here...
If not the same as the other issue, then please attach copies of your pinballx.ini and log.txt files. We need these each time you report an error. Thanks.
nope different issue it seems. the other issue is just certain tables that I have since disabled. My issue now is exactly whats happening to the OP of this thread. Exiting an emulator,  also exits pinballX. My only change was adding xpadder and a USB controller into the mix and its not playing nicely.  I  have since disabled xpadder and unplugged my controls but I will try again so I can get the log.txt. its identical to the OPS log on here. I get the same boolean errors
  • 3 months later...
