I'm having the same problem except the file you sent me ends with .gxkey I download it, click it and it says something about updating the registry but nothing seems to of changed when I open gameex, the nag screen is still there and nothing else seems different, what am I doing wrong?
You did allow it to update the registry?
You can just do it again just to make sure - it wont hurt anything.
Depending on how confident you are, you can check that it has 'installed' the key by examining the registry:
Press Windows Key + R
type "regedit" + press return
navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\GameEx
There should be a node called "Key" on the right hand side  - obviously don't post that here!
Don't change anything in the registry
Let us know how you get on.
I separated this from the other topic as registry key issues are generally not all the same for each user.
Hey guys,
Please just tell these folks to contact me directly with registration or billing issues. I always handle these myself one to one. Sometimes they email me then post here anyway before I have had a chance to reply.
Cheers.
Tom.
