My newly registered copy of GameEx has got its nag screen back. Nothing else has changed.
I can get it to start without the nag screen if I run it as administrator. However, if I set this in the app's properties, it won't then start automatically with Windows (shortcut in the Startup folder), even with the UAC turn off.
I'm running Win 10 64bit
This is a known issue unfortunately.
You can get round the issue by using a .bat instead of the .exe
Create a text file in notepad and put in the following:
c:
cd c:\gameex
gameex.exe
Save the file, select "all files" and put the file name as "gameex.bat" with the quotes and save it in c:\gameex
Move the batch file to the startup folder.
c:
cd c:\gameex
gameex.exe
Don't forget the No Echo line at the top of your batch file to supress display output.
