Hello Tom, hello Draco, hello all others,
I´ve just encountered that the "old" issue with Pinball FX2 is back (which was already solved by Tom). Here is the link to the former post:
In the latest Version of PinballX it is not possible to set the "Wait for" entry to "-1" anymore. But this is necessary to avoid unwanted key strokes (and therefore to avoid unwanted Input).
For example: if you start the "Avengers" table, the game Shows a few seconds of the intro, automatically launches a new game and also automatically chooses a first ball for you.
Is it possible for you to include the "Wait for = -1" option again (with low effort)?
Many thanks in advance and best regards,
Jannek
Hey Tom,
33 minutes ago, Tom Speirs said:
Pinball FX2 has command line support since some time ago which is likely the reason it was removed.
yes, indeed, I know (and use) the command line support. But unfortunatly I´ve encountered that the strange behavior (e.g. automatically choosing a ball on Avengers table) reappeared. I thought that - once again - the "wait for = -1" setting might help with this issue.
Many thanks again and kind regards,
Jannek
Hello Tom,
please forget about my issue. I guess this was a wrong alert... It does not happen anymore. Maybe my "problem" was another small thing regarding my update to Windows 10. I´m really sorry for wasting your time.
Nevertheless - many thanks for your support and again: I´m sorry for bothering you.
Kind regards,
Jannek
