thx for your replys. Can anyone tell me if the nagscreen returns when my subscription runs out? I dont care about updates that much as long as the nag screen stays away
I can't say for sure if the nag screen would return or not, but hopefully by the time your subscription runs out Evolution will be released and you'll probably want to upgrade to that anyway.
I have not decided how things with Evo will work yet, it may time out. As for the current GameEx it is version based. So if you upgrade to a newer version after the subscription expires it will be expired otherwise you can continue to use an old version. Note though that I won't help you find an old version if you contact me in a few years.
So with current GameEx if you are happy to use an old version for the rest of days the nag screen won't come back if you purchase a subscription.
Obviously there is some catch with something that states "1 year license only" versus "lifetime". Goes without saying right?
Anyway, as discussed in the other topic subscriptions are not working for German users anyway right now. So at the moment lifetime is the only option.
