Hi all!!
Trying to use the advancedconfigeditor.exe program with one emulator, but don't know hoy to use it correctly....
1 - Need to put the command line to execute advancedconfigeditor.exe in "also launch" on my emulator config?
2 - What is the correct way to launch this program? My command line for this program in also launch line inside my emulator config now is: advancedconfigeditor.exe [C:\emulators\config.ini]  is that correct??? It seems do nothing....
Thanks in advance!!!
Why do you need to do that? What are you trying to do? That's super wrong, but it would probably help if we understood the goal here.
