Trying to help out an internet user..
All the .exe are returning the same error. This is the latest download version - new install directory.
Are there any dependencies that I might need to install/resinstall.
Any debug/logs I can see?
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Settings.exe
  Application Version:    1.0.5347.308
  Application Timestamp:    53f68a69
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7601.17514
  Fault Module Timestamp:    4ce7bafa
  Exception Code:    e0434f4d
  Exception Offset:    0000b727
  OS Version:    6.1.7601.2.1.0.768.3
  Locale ID:    1033
It is .. I ran the .net (4) full installer and it said to repair or remove. I chose the repair option. Is it somewhat safe to uninstall/reinstall .net? It warned that it may break already existing programs.
No such luck. Tried uninstalling and clean out and reinstall 1.1 3.5 and 4.0 cleanup shows them all being installed.
Is there any debug version of setup.exe or pinballx that I can run to diagnose what is missing/corrupt/screwed up on this pc?
What OS and is it a new install? In the past, I have had to perform a clean install of the OS to remedy a similar issue. I have also seen where someone encountered similar issues becuase they were using an "nLite" version of the OS which was lacking some key files. If you "google" the faulting module and version and the exception codes, you will find that there are way too many to nail it down to just one cause, hence the clean install of the OS.
