Is there any way to get PinballX to launch Pinball Arcade in Portrait Mode? If yes, please point me to the Documentation
My Main monitor is rotated to the left (270°). I've set up PinballX, activated Pinball Arcade in the Wizard, started the Pinball Arcade Config Tool and entered Width 1080, Height 1920, the game launches in landsape mode (i just see a small game window in the middle, but not rotated, when i start Pinball Arcade outside of Pinball X.
When i launch a table in PinballX, it is exactly the same, but the tables are started correctly.
When i rotate the screen with a tool, it works as it should.
Do i have to put the rotation tool in the LaunchFirst / Launch After of PinballX or does it have this functionality included?
I'm not posting any of my configurations here, as this is the default configuration of PinballX with nothing changed, i'm rather asking for help how to set it up. Thanks in advance!
All the same, I would like to see your pinballx.ini and log.txt files  as you may have something tweaked incorrectly that you are not seeing that may be blatantly obvious to us. That's how it works here. Thanks.
Change your playfield to portrat
Go into steam and push play on pinball arcade
choose configure
change any setting you want to
Launch game through steam
If it looks right exit
Now rotate your screen back to landscape
When you launch from pinballX the screen will be in portrat
