Whats working using native pinball x support
I can launch any table and play it on my cab although table launch is slow.
What not working
How do you move the DMD to another screen?
J
5 hours ago, Umpa said:
Use your mouse and drag the dmd to the screen you want
Is that using the Free Camera Mod?
Oh your using future pinball. I thought you were talking about visual pinball. If your using futuredmd you can still drag it where you want don't matter what mode in BAM your using.
Reading is fundamental! B) The thread title is a question regarding Pinball Arcade, not VP or FP.
@CHASER - Unfortunately, there is no way to move the DMD with the integrated Pinball Arcade support. You will have to setup Pinball Arcade as a separate system using the Noex's Free Camera Mod
Yep. My bad!
Thanks Draco
So has anyone have luck with Pinballx and NOEX with a 3 monitor cab?
18 hours ago, CHASER said:
Thanks Draco
Meh, partial success so far. I have a new VP Cabs setup and can get the backglass and playfield to work so far with Pinball Arcade and the NOEX patch. Haven't gotten the DMD to work correctly yet, but will get back at it within a day or two to try again. Not particularly fond of having to enable Aero on Windows just to play a Pinball Arcade table. Doesn't look like I can leave it enabled all the time as it adds noticeable lag on other tables launched through PinballX.
W
22 minutes ago, Carny_Priest said:
Aero can be turned on and off programmatically, if you are inclined to write a script to do it.
Good reminder on that, thank you. If/when I can get Pinball Arcade to work 100% on the new cabinet, I'll look at automating somethings at launch with PinballX.
W
2 hours ago, CHASER said:
Can pinballx launch PBA in DX11 instead of DX9?
I merged you question back into this topic since it is related. You can if you rename the pinball arcade DX11 executable to the name of the DX9 file. This, unfortunately is not a long term fix as it will be updated by Steam periodically.  The setup with FCM previously mentioned,  however,  handles launching the DX11 file.
