I am running 2 screen setup. When trying to re position the DMD on the second screen, the mouse pointer doesn't always show. It shows fine on the PF monitor but the BG monitor it only appears  sometimes and even then it disappears when you move it  making it hard to re position the DMD on the back glass image.
Any thoughts?
Um, not a thought but a question, does that mean the issues reported in this thread are resolved and, if so, what was the resolution? It seems if you have advanced this far that maybe you got these other issues you posted resolved. If this is the case, can you make a note accordingly in the other thread as to what you did to fix the issue?
I never was able to get it to work. I am using a manual work around. I updated the thread with a response.
