I have a really small but kind of irritating issue with PinballX and FX2. Everything works great, except for that when I choose a table and it loads up, after around 11 seconds it sends some input to FX2 making it start a new game and leaving the "attract" mode. This is most annoying in tables where you have to chose some option in the beginning (like Avengers) because it just chooses the default setting and goes straight to launch ball. I was thinking this had something to do with the "WaitFor" setting in PinballX.ini but nothing changes when I put different values there (like -1). Is it possible to get PinballX to not send any input to FX2 after the table is loaded?
PinballX.ini
Spoiler
[Display]
Monitor=0
rotate=90
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ff000000
[BackGlass]
monitor=1
x=0
y=0
width=1280
height=1024
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=False
ShowSystem=True
ShowRatings=True
OneClickLaunch=True
WheelOverlay=0
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=Yes
[KeyCodes]
quit=27
left=160
right=161
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=9
left=6
right=7
select=1
rotate=3
pageleft=4
pageright=5
exitemulator=9
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
Enabled=False
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Users\johan\Downloads\The Walking Dead Physmod5 1.1
Executable=VPinball99_PhysMod5.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Executable=steam.exe
Parameters=-applaunch 226980 "[TABLEFILE]"
Process=Pinball FX2
Rotate=False
WaitFor=-1
[Internal]
lastwheelcachematchsize=-1123
lastselected=PashaPashaPinball FX2
filter_year=
filter_company=
filter_custom=
filtername=Tables
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=3
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,478
WindowLocation=197,1071
Spoiler
15:48:13.1  5/1/2016:  PinballX - Version 2.14
15:48:13.2  5/1/2016:  Windows 8.1 Pro 64-bit (3.9GB)
15:48:13.2  5/1/2016:  Loading Settings
15:48:13.2  5/1/2016:  Initialize Component
15:48:13.3  5/1/2016:  Initialize Display
15:48:14.4  5/1/2016:  Loading PlugIns
15:48:14.5  5/1/2016:  Created DirectX BackGlass Window
15:48:14.7  5/1/2016:  Hiding Cursor
15:48:14.7  5/1/2016:  Hiding Taskbar
15:48:14.8  5/1/2016:  CPU:  Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
15:48:14.8  5/1/2016:  GPU 1: NVIDIA GeForce GTX 750 Ti
15:48:14.8  5/1/2016:  Displays: 2
15:48:14.8  5/1/2016:  Load Game List
15:48:14.8  5/1/2016:  Loading Database: Pinball FX2
15:48:14.8  5/1/2016:  Finding and matching artwork and videos
15:48:15.2  5/1/2016:  Loading Game Statistics and Scores
15:48:15.8  5/1/2016:  Loading Surfaces
15:48:16.0  5/1/2016:  Finished Loading Surfaces
15:48:16.0  5/1/2016:  Initialize Audio
15:48:16.1  5/1/2016:  Set Keyboard Controls
15:48:16.1  5/1/2016:  Initialize Joystick
15:48:16.2  5/1/2016:  1 Joystick Attached
15:48:16.2  5/1/2016:  Started
15:48:19.8  5/1/2016:  Launch System
15:48:19.8  5/1/2016:  Waiting for threads
15:48:19.8  5/1/2016:  Disposing display
15:48:21.9  5/1/2016:  C:\Program Files (x86)\Steam\steam.exe -applaunch 226980 "Pasha"
15:48:41.5  5/1/2016:  Found Pinball FX 2 Process
15:48:45.5  5/1/2016:  Exit System Control Pressed
15:48:46.8  5/1/2016:  Created DirectX BackGlass Window
15:48:50.5  5/1/2016:  Exiting
15:48:50.8  5/1/2016:  Showing Taskbar
15:48:50.8  5/1/2016:  Unhiding Mouse Cursor
15:48:50.9  5/1/2016:  Disposing Plugins
15:48:50.9  5/1/2016:  Saving Settings
15:48:50.9  5/1/2016:  Bye
To be honest, this doesn't sound like a PinballX issue, at least not directly. What kind of interface setup do you have (Pincab or Desktop)? What are you using for input devices? Any software such as X360ce or Xpadder to manage inputs as a 360 game pad?
Usually when this type of complaint is made, it turns out to be a device (i.e., stuck button on a controller or keyboard) as the cause. I had an issue with inputs due to the plunger accelerometer being close to the subwoofer in my mini cab and causing nudging to occur and tilt my tables among other issues.
At the moment I'm just setting a computer up for use in a cabinet that isn't built yet so the only input I'm using at the moment is from the keyboard - no other software installed. It always happen after exactly 11 seconds after loading.
I was reading this closed topic where someone had the same problem but I'm guessing this is from an older version before you could launch the tables directly from command line.
You may want to provide a copy of your pinball fx2.xml file for review. As of a few versions ago, the wait for timer was not required as part of the integrated Pinball FX2 support.
Just to clarify, if I run a table directly from command line not using PinballX this problem does not occur.
Pinball FX2.xml
Spoiler
<menu>
    <game name="Alien_Isolation">
        <description>Alien Isolation</description>
        <rom></rom>
        <manufacturer>Zen Studios</manufacturer>
        <year>2016</year>
        <type>PC</type>
        <hidedmd>True</hidedmd>
        <hidebackglass>False</hidebackglass>
        <enabled>True</enabled>
        <rating>0</rating>
        <gridposition>1x1</gridposition>
    </game>
    <game name="Alien_vs_Predator">
        <description>Alien vs. Predator</description>
        <rom></rom>
        <year>2016</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Aliens">
        <description>Aliens</description>
        <rom></rom>
        <year>2016</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="AmericanDad">
        <description>American Dad</description>
        <rom></rom>
        <year>2015</year>
        <type></type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Ant-Man">
        <description>Ant-Man</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Archer">
        <description>Archer</description>
        <rom></rom>
        <year>2015</year>
        <type></type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Avengers">
        <description>Avengers</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Age_of_Ultron">
        <description>Avengers - Age of Ultron</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="BioLab">
        <description>BioLab</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Blade">
        <description>Blade</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="BobsBurgers">
        <description>Bob's Burgers</description>
        <rom></rom>
        <year>2015</year>
        <type></type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_CaptainAmerica">
        <description>Captain America</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="CastleStorm">
        <description>Castle Storm</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_CivilWar">
        <description>Civil War</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Deadpool">
        <description>Deadpool</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_DrStrange">
        <description>Doctor Strange</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="EarthDefense">
        <description>Earth Defense</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Eldorado">
        <description>El Dorado</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Looter">
        <description>Epic Quest</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Excalibur">
        <description>Excalibur</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="FamilyGuy">
        <description>Family Guy</description>
        <rom></rom>
        <year>2015</year>
        <type></type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_FantasticFour">
        <description>Fantastic Four</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_FearItSelf">
        <description>Fear Itself</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_GhostRider">
        <description>Ghost Rider</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Guardians">
        <description>Guardians of the Galaxy</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_IronMan">
        <description>Iron Man</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Mars">
        <description>Mars</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_MoonKnight">
        <description>Moon Knight</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="SplosionMan">
        <description>Ms. Splosion Man</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Paranormal">
        <description>Paranormal</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Pasha">
        <description>Pasha</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="PlantsVsZombies">
        <description>Plants vs Zombies</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Portal">
        <description>Portal</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Rome">
        <description>Rome</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Atlantis">
        <description>Secrets of the Deep</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Shaman">
        <description>Shaman</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Citadel">
        <description>Sorcerers Lair</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="SouthPark2">
        <description>South Park - Butters Own Pinball</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="SouthPark1">
        <description>South Park - Super Sweet Pinball</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_SpiderMan">
        <description>Spider-Man</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Episode_4">
        <description>Star Wars -  A New Hope</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Boba_Fett">
        <description>Star Wars - Boba Fett</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Darth_Vader">
        <description>Star Wars - Darth Vader</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Droids">
        <description>Star Wars - Droids</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Han_Solo">
        <description>Star Wars - Han Solo</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Light_VS_Dark">
        <description>Star Wars - Masters of the Force</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_MFO">
        <description>Star Wars - Might of the First Order</description>
        <rom></rom>
        <year>2016</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Rebels">
        <description>Star Wars - Rebels</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Episode_6">
        <description>Star Wars - Return of the Jedi</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_SFA">
        <description>Star Wars - Starfighter Assault</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_CloneWars">
        <description>Star Wars - The Clone Wars</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Episode_5">
        <description>Star Wars - The Empire Strikes Back</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="STARWARS_Episode_7">
        <description>Star Wars - The Force Awakens</description>
        <rom></rom>
        <year>2016</year>
        <type></type>
        <rating>0</rating>
    </game>
    <game name="Tesla">
        <description>Tesla</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_InfinityGauntlet">
        <description>The Infinity Gauntlet</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="TheWalkingDead">
        <description>The Walking Dead</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Thor">
        <description>Thor</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="V12">
        <description>V12</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Venom">
        <description>Venom</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Western">
        <description>Wild West Rampage</description>
        <rom></rom>
        <year>2015</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_Wolverine">
        <description>Wolverine</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_WWH">
        <description>World War Hulk</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="MARVEL_XMen">
        <description>X-Men</description>
        <rom></rom>
        <year>2013</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
    <game name="Football">
        <description>Zen Football</description>
        <rom></rom>
        <year>2014</year>
        <type>PC</type>
        <rating>0</rating>
    </game>
</menu>
I'm also having trouble with Pinball FX2.  After I launch a table from PinballX it load up and starts table.  I can launch a ball, but after a few seconds after launching ball it goes back to PinballX (kinda, as there are some open windows left behind and I have to Ctrl-Alt_Del and stop these tasks.  Maybe same thing???
After the latest update of PinballX i doesn't take 11 seconds for the table to "auto start", now it goes into launch ball instantly after the table is loaded. Since this doesn't happen when I load the tables directly from command line this should be a PinballX related issue right?
Also, when I finish a game and it's over it goes into the tables attract mode and stays there until I press "Enter", so this does just occur when the table is first loaded.
@slydog43 and @ampeg - Let's upload updated pinballx.ini and log.txt files please after the most recent PinballX version 2.16 release. Thanks, guys.
@ampeg - Before you reup your pinballx.ini and log.txt files, please change your process to read Process=Pinball FX2.exe instead of Process=Pinball FX2 I am not sure but that may make a difference.
