Seems like every emulator I have set up has been a real pain and I am beginning to think a lot of this comes with windows 10 and now im on N64(project64). I have done my forum research regarding this issue and it seems like project64 needs a (alt+f4) command to exit  which does work directly when using just the emulator but not GameEx. I have also read that I just need to do an advanced config and use a %{F4} command which I have done manually as well as used some of the pre-made advanced conf .ini files but none seem to have an effect when pressing escape after loading using GameEx it just switches between full and windowed screen however if I just hit (alt+F4) it exits back to GameEx.
I should also note that I am using Project64 ver. 2.x
I know you've already posted it in another thread, but can you post your GameEx.ini and log.txt files please.
I'm using Project 64 ver 1.6 in Windows 10 and it exited fine using GameEx. When I ran the emulator separately and hit Esc it switched from full screen to a window as you've already experienced. I don't currently have it running as admin or with any compatibility settings. I'm going to download the version you have and see if I can recreate the problem.
I couldn't get ver 2.2 running for whatever reason, but I think I may have found a solution.
Fire up the GameEx Setup Wizard. Select Advanced at the beginning part. Click the Right Arrow until you get to Advanced Emulator Setup. Select your N64 Emulator at the top of the page. Go down to Advanced Config. From the pull down menu select [Mapping Off] Exit (Alt+F4).
That might do the trick.
Certainly,
Gameex.ini
Spoiler
[gameexonline]
streamquality=0
Privacy=0
EnableBackground=True
[general]
Xresolution=1920
Yresolution=1080
DisplayOnSecondary=False
MAMEPath=C:\Emulators\Mame32
MAMEEXE=Mame32.exe
ROMPath=C:\Emulators\Mame32\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Comic Sans MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=True
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
SnapPath=C:\Emulators\Mame32\snap
AVISnapPath=C:\Emulators\Mame32\avisnap
AVIFrameSkip=0
flyerpath=C:\Emulators\Mame32\flyers
cabinetpath=C:\Emulators\Mame32\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=119
MusicPlayList=C:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=0
AttractModeAudio=3
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=False
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=True
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=True
DisableRemoveGame=False
theme=Default - Brokeh
Language=English
flatstartpage=False
DontSwitchRes=False
SnapDelay=4
AllowWindowResize=False
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=True
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=False
ShufflePlayLists=False
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Comic Sans MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
MarqueePath=C:\Emulators\Mame32\marquees
PanelPath=C:\Emulators\Mame32\cpanel
TitlePath=C:\Emulators\Mame32\titles
ICONPath=C:\Emulators\Mame32\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=False
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=True
HideLogoff=True
HideStandBy=True
DisableMouse=False
ShowVideos=False
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=False
AttractVideosRatio=1
AttractVideosPath=C:\Video
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=True
TransitionType=1
Bypass=True
DontBlitWait=False
ShowMostPlayed=False
excludedmameroms=
DeadZoneX=0
DeadZoneY=0
jukeboxmode=2
enableambiance=False
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121|122
EnableThemePicker=False
DisablePleaseWaitAnimation=False
EnableRipCD=False
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
autoupdate=1
NoMAMEOnStartPage=False
HideRestart=True
EnableStartScreenSaver=False
SortMAMEThE=False
SortEmuThE=True
ShowMCEEXport=False
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
ManualPath=C:\Emulators\Mame32\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=False
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=False
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=C:\Emulators\Mame32\pcb
ArtworkPath=C:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=False
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=False
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=True
SortEmulators=False
ShowAllGames=False
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=True
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=C:\Users\ThomasSpeirs\Music
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=C:\Emulators\Mame32\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=C:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=2
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=False
GameExtenderCustomImageMAMEPath=C:\Emulators\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=C:\ArcadeAmbiance
EnableEscapeKeyExit=False
DisableChangeView=True
EnabledConfigurationApp=False
resumelastatstartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=C:\Emulators\Mame32\backgroundsnap
TVVideoPath=
OtherVideoPath=C:\Video;[myvideos]
ChangeMonitorFrequency=False
ChangeMonitorResolution=True
NoCasino=True
EnableDownloadService=True
ShowCHD=True
Databasesnappath=C:\Emulators\Mame32\databasesnap
ArcadeMonitorType=0
EnableHighestRated=False
SeekPreviewVideo=0
[daphne]
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "R:\ARCADE\Daphne\vldp\astron\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "R:\ARCADE\Daphne\vldp\badlands\badlands.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "R:\ARCADE\Daphne\vldp\bega\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "R:\ARCADE\Daphne\vldp\cliff\cliff.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "R:\ARCADE\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "R:\ARCADE\Daphne\lair_HD\lair_hd.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "R:\ARCADE\Daphne\vldp\lair2\lair2.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "R:\ARCADE\Daphne\vldp\esh\esh.txt"
Enabled_9=False
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "R:\ARCADE\Daphne\vldp\FireFox\firefox.txt"
Enabled_10=False
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "R:\ARCADE\Daphne\vldp\galaxyr\galaxyr.txt"
Enabled_12=False
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile "R:\ARCADE\Daphne\vldp\interstellar\interstellar.txt"
Enabled_14=True
ROMName_14=gpworld
GameName_14=GP World
GameOptions_14=-framefile "R:\ARCADE\Daphne\vldp\gpworld\gpworld.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "R:\ARCADE\Daphne\vldp\mach3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "R:\ARCADE\Daphne\vldp\rb\rb.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "R:\ARCADE\Daphne\Space Ace HD\ace_hd.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "R:\ARCADE\Daphne\vldp\sdq\sdq.txt"
Enabled_19=False
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "R:\ARCADE\Daphne\vldp\tq\tq.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "R:\ARCADE\Daphne\vldp\uvt\uvt.txt"
UseGamepad=False
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marquees
DaphneBakSNAP=C:\Emulators\Daphne\backgroundimages
[dvd]
EnableDVD=False
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=False
DVDPath=C:\DVD
UseVMR9=False
EnableExternalPlayer=False
Use VMR9=False
CMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""
[pictures]
PicturesEnabled=False
Paths=C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=15
[news]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
Enabled=False
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[radio]
RadioEnabled=False
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlapplications]
enabled_1=False
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1&lang=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=https://online.gameex.com
Name_2=GameEx Online
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1&lang=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=False
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[externalapplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[text]
mameCHDlist=CHD
mameCHDstart=MAME CHD Games
steamlist=Steam
steamstart=Steam Games
uplaylist=Uplay
uplaystart=Uplay Games
originlist=Origin
originstart=Origin Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokeAllSongs=All Songs
KaraokeMode1Click=Instant Play Mode
KaraokeModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
weather=Weather
Titles=Titles
Movies=Movies
Actors=Actors
Year=Year
Directors=Directors
Genres=Genres
Collections=Collections
Ratings=Ratings
Cast=Cast
Director=Director
Collection=Collection
TV=TV
NetFlix=NetFlix
SearchNetFlix=Search NetFlix
[favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[dvrms]
DVRFFDSHOW=0
CODEC=
[atractmodenewgametimer]
When in attract mode start a new random game or video each time this value is reached.=2
[attractvideospath]
The folder your videos are located.=L:\GameAds
[gameextender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=Mark Viars
Username=User33549
ComputerName=MEDIACENTER
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[gameextenderviewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[karaoke]
Path=D:\Karaoke
mode=True
[arcadesoundplugin]
Volume=8
[emulator_]
SelectionMusicFolder=C:\Music
[ebook]
Enabled=False
Paths=C:\eBooks
Quality=1
fittopage=False
[mediaplayer]
Enabled=False
AudioMode=0
[cpwizard]
CPWizardEnable=False
CPWizardPath=C:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
[video]
UseWMPWMV=
CMD=
[advkeyboard]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[cursorhider]
DoNotHide=
DoNotHideInGameEX=False
[defaultpaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[youtube]
Enabled=False
[gamebase]
Enabled=False
Path=
MapBack=False
ShowDesktop=True
[dvdrip]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[gameexarcade]
Enabled=False
[touchscreen]
Touchscreen_Enabled=False
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[laststatus]
specialfilter=KARAOKE
oldspecialfilter=KARAOKE
curemulator=10
listtype=220
curbak=emu
maxgames=140
gamename=Donkey Kong Country 3
[steam]
LaunchBefore=
LaunchAfter=
Enabled=False
[mappeddrives_1]
UNCPATH=\\Nasusa\roms_mint
Drive=R
[uplay]
Enabled=False
UPlayEnabled=False
LaunchBefore=
[origin]
Enabled=False
OriginEnabled=False
[emulator_0]
excludedfileswithnamesverifiedfound=;10yard85;
[login]
Enabled=False
[movies]
Enabled=False
[netflix]
Enabled=False
[tv]
available=False
[INTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
version=14.44
timesruncount=15
startpagethumbscount=4
emu_1lastfolderwrite=4/15/2016 9:19:35 PM
emu_1lastromfilter=*.*
emu_3lastfolderwrite=4/18/2016 12:24:48 AM
emu_3lastromfilter=*.*
emu_4lastfolderwrite=4/17/2016 8:00:51 PM
emu_4lastromfilter=*.zip
lastglaunchlist=0
glaunchlistselected_0=13
glaunchlisttop_0=1
viewalbumtype=0
windowed=False
selectedgame=13
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=3200
emulator=6
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=
romname2=
currentstationurl=
emu_1_dbcachemodified=12/16/2014 5:11:34 PM
emu_1_lastnumgames=142
emu_1_dbcachelastname=[Console] Atari 2600
emu_1_dbcacheinicreated51=True
emu_1_downloadid=255
emu_1_cdcheckfile=
emu_1_cdcheck=False
emu_1_randommostplayed=True
emu_1_showmostplayed=True
emu_1_playinscreensaver=False
emu_1_gamesin7zips=False
emu_1_pcgame=False
emu_1_selectionmusicfolder=
emu_1_playselectionmusic=False
emu_1_dontshowinfo=False
emu_1_playmusic=False
emu_1_custombackground=
emu_1_excludedfiles=
emu_1_launchafter=
emu_1_launchbefore=
emu_1_oldatzip=
emu_1_alsolaunch=
emu_1_debug=False
emu_1_showdesktop=True
emu_1_removebrackets=True
emu_1_capitals=False
emu_1_replaceunder=True
emu_1_replacedash=False
emu_1_sendkeys=
emu_1_waitbeforekeys=
emu_1_mapkeys=True
emu_1_workingpath=D:\Emulators\2600
emu_1_controlpanelpath=D:\GameEx\Assets\Atari 2600\Controls
emu_1_manualpath=D:\GameEx\Assets\Atari 2600\Manuals
emu_1_cartpath=D:\GameEx\Assets\Atari 2600\Cartridges
emu_1_boxpath=D:\GameEx\Assets\Atari 2600\Boxes
emu_1_titlepath=D:\GameEx\Assets\Atari 2600\Titles
emu_1_snappath=D:\GameEx\Assets\Atari 2600\Snaps
emu_1_rompath=D:\Emulators\2600\ROMS
emu_1_mapfile=
emu_1_configfile=[Mapping Off] Exit (Process Close)
emu_1_database=[Console] Atari 2600
emu_1_romfilter=
emu_1_command=Stella.exe -video gl -gl_fsmax 1 -fullscreen 1
[ROMPATH]\[ROMFILE]
emu_1_startpagelogo=AtariLogo
emu_1_startpagename=Atari 2600
emu_1_titletext=Atari 2600
emu_1_info=Atari 2600 emulator
emu_1_website=http://stella.sourceforge.net/
emu_1_requiredfiles=
emu_1_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/stella.7z
emu_1_rating=7.9
emu_1_version=3.6.1
emu_1_emulator=Stella
emu_1_category=Console
emu_1_system=Atari 2600
emu_1_enabled=True
donemenulistviewinitialchange2=true
emu_2lastfolderwrite=4/15/2016 11:13:12 PM
emu_2lastromfilter=*.*
emu_5lastfolderwrite=4/20/2016 1:44:41 AM
emu_5lastromfilter=*.cue
emu_2_downloadid=206
emu_2_cdcheckfile=
emu_2_cdcheck=False
emu_2_randommostplayed=True
emu_2_showmostplayed=True
emu_2_playinscreensaver=False
emu_2_gamesin7zips=False
emu_2_pcgame=False
emu_2_selectionmusicfolder=
emu_2_playselectionmusic=False
emu_2_dontshowinfo=
emu_2_playmusic=False
emu_2_custombackground=
emu_2_excludedfiles=
emu_2_launchafter=
emu_2_launchbefore=
emu_2_oldatzip=
emu_2_alsolaunch=
emu_2_debug=False
emu_2_showdesktop=True
emu_2_removebrackets=True
emu_2_capitals=False
emu_2_replaceunder=True
emu_2_replacedash=False
emu_2_sendkeys=
emu_2_waitbeforekeys=
emu_2_mapkeys=True
emu_2_workingpath=D:\Emulators\NES
emu_2_controlpanelpath=D:\GameEx\Assets\NES\Nintendo NES\Controls
emu_2_manualpath=D:\GameEx\Assets\NES\Nintendo NES\Manuals
emu_2_cartpath=D:\GameEx\Assets\NES\Nintendo NES\Cartridges
emu_2_boxpath=D:\GameEx\Assets\NES\Nintendo NES\Boxes
emu_2_titlepath=D:\GameEx\Assets\NES\Nintendo NES\Titles
emu_2_snappath=D:\GameEx\Assets\NES\Nintendo NES\Snaps
emu_2_rompath=D:\Emulators\NES\ROMS
emu_2_mapfile=
emu_2_configfile=[Mapping Off] Exit (Process Close)
emu_2_database=[Console] Nintendo NES
emu_2_romfilter=
emu_2_command=nestopia.exe
[ROMPATH]\[ROMFILE]
emu_2_startpagelogo=Nintendo NES
emu_2_startpagename=Nintendo NES
emu_2_titletext=Nintendo NES
emu_2_info=Nintendo NES 8bit emulator
emu_2_website=http://fceux.com/web/htdocs/
emu_2_requiredfiles=
emu_2_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/FCE%20Ultra.7z
emu_2_rating=8.6
emu_2_version=2.1.5
emu_2_emulator=FCE Ultra
emu_2_category=Console
emu_2_system=Nintendo NES
emu_2_enabled=True
emu_2_dbcachemodified=12/16/2014 5:12:10 PM
emu_2_lastnumgames=286
emu_2_dbcachelastname=[Console] Nintendo NES
emu_2_dbcacheinicreated51=True
emu_1_databasesnappath=D:\GameEx\Assets\Atari 2600\Snaps
emu_4_dbcachemodified=12/16/2014 5:11:53 PM
emu_4_lastnumgames=49
emu_4_dbcachelastname=[Console] NEC TurboGrafx-16
emu_4_dbcacheinicreated51=True
emu_1_baksnappath=D:\GameEx\Assets\Atari 2600\Snaps
emu_6lastfolderwrite=4/13/2016 8:43:50 AM
emu_6lastromfilter=*.*
emu_6_dbcachemodified=12/16/2014 5:12:01 PM
emu_6_lastnumgames=15
emu_6_dbcachelastname=[Console] Nintendo GameCube
emu_6_dbcacheinicreated51=True
emu_6_enabled=True
emu_6_system=Nintendo GameCube
emu_6_category=Console
emu_6_emulator=Dolphin
emu_6_version=3.0-631
emu_6_rating=7.9
emu_6_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Dolphin.7z
emu_6_requiredfiles=DirectX Runtime, Microsoft Visual C++ 2010 Redistributable Package
emu_6_website=http://www.dolphin-emulator.com
emu_6_info=Nintendo Gamecube and Wii emulator
emu_6_titletext=Nintendo GameCube
emu_6_startpagename=Nintendo GameCube
emu_6_startpagelogo=Nintendo GameCube
emu_6_command=Dolphin.exe -e
[ROMPATH]\[ROMFILE]
emu_6_romfilter=
emu_6_database=[Console] Nintendo GameCube
emu_6_configfile=[Mapping Off] Exit (Process Close)
emu_6_mapfile=
emu_6_rompath=D:\Emulators\Game Cube\Dolphin\isos
emu_6_snappath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Snaps
emu_6_titlepath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Titles
emu_6_boxpath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Boxes
emu_6_cartpath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Cartridges
emu_6_manualpath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Manuals
emu_6_controlpanelpath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Controls
emu_6_workingpath=D:\Emulators\Game Cube\Dolphin
emu_6_mapkeys=True
emu_6_waitbeforekeys=
emu_6_sendkeys=
emu_6_replacedash=False
emu_6_replaceunder=True
emu_6_capitals=False
emu_6_removebrackets=True
emu_6_showdesktop=True
emu_6_debug=False
emu_6_alsolaunch=
emu_6_launchbefore=
emu_6_launchafter=D:\GameEx\CONFIG\dolphin-kill.bat
emu_6_excludedfiles=
emu_6_custombackground=
emu_6_playmusic=False
emu_6_dontshowinfo=
emu_6_playselectionmusic=False
emu_6_selectionmusicfolder=
emu_6_pcgame=False
emu_6_gamesin7zips=False
emu_6_playinscreensaver=False
emu_6_showmostplayed=True
emu_6_randommostplayed=True
emu_6_cdcheck=False
emu_6_cdcheckfile=
emu_6_downloadid=202
emu_6_baksnappath=
emu_6_databasesnappath=
emu_3_dbcachemodified=12/16/2014 5:12:24 PM
emu_3_lastnumgames=192
emu_3_dbcachelastname=[Console] Nintendo SNES
emu_3_dbcacheinicreated51=True
emu_3_enabled=True
emu_3_system=Nintendo SNES
emu_3_category=Console
emu_3_emulator=ZSNES
emu_3_version=1.51
emu_3_rating=9.0
emu_3_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/zsnes.7z
emu_3_requiredfiles=
emu_3_website=http://www.zsnes.com/
emu_3_info=Super Nintendo emulator
emu_3_titletext=Nintendo SNES
emu_3_startpagename=Nintendo SNES
emu_3_startpagelogo=Nintendo SNES
emu_3_command=zsnesw.exe
[ROMPATH]\[ROMFILE]
emu_3_romfilter=
emu_3_database=[Console] Nintendo SNES
emu_3_configfile=ZSNES V6
emu_3_mapfile=
emu_3_rompath=D:\Emulators\SNES\ROMS
emu_3_snappath=D:\GameEx\Assets\SNES\Nintendo SNES\Snaps
emu_3_titlepath=D:\GameEx\Assets\SNES\Nintendo SNES\Titles
emu_3_boxpath=D:\GameEx\Assets\SNES\Nintendo SNES\Boxes
emu_3_cartpath=D:\GameEx\Assets\SNES\Nintendo SNES\Cartridges
emu_3_manualpath=D:\GameEx\Assets\SNES\Nintendo SNES\Manuals
emu_3_controlpanelpath=D:\GameEx\Assets\SNES\Nintendo SNES\Controls
emu_3_workingpath=D:\Emulators\SNES
emu_3_mapkeys=True
emu_3_waitbeforekeys=
emu_3_sendkeys=
emu_3_replacedash=False
emu_3_replaceunder=True
emu_3_capitals=False
emu_3_removebrackets=True
emu_3_showdesktop=True
emu_3_debug=False
emu_3_alsolaunch=
emu_3_oldatzip=
emu_3_launchbefore=
emu_3_launchafter=
emu_3_excludedfiles=
emu_3_custombackground=
emu_3_playmusic=False
emu_3_dontshowinfo=
emu_3_playselectionmusic=False
emu_3_selectionmusicfolder=
emu_3_pcgame=False
emu_3_gamesin7zips=False
emu_3_playinscreensaver=False
emu_3_showmostplayed=True
emu_3_randommostplayed=True
emu_3_cdcheck=False
emu_3_cdcheckfile=
emu_3_downloadid=272
emu_3_baksnappath=
emu_3_databasesnappath=
emu_5_dbcacheinicreated51=True
emu_5_enabled=True
emu_5_system=Sony Playstation
emu_5_category=Console
emu_5_emulator=ePSXe
emu_5_version=1.9.0
emu_5_rating=8.3
emu_5_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/epsxe.7z
emu_5_requiredfiles=scph1001.bin (512kb)
emu_5_website=http://www.epsxe.com/
emu_5_info=Sony Playstation Emulator
emu_5_titletext=Sony Playstation
emu_5_startpagename=Sony Playstation
emu_5_startpagelogo=Sony Playstation
emu_5_command=ePSXe.exe -nogui -loadbin
[ROMPATH]\[ROMFILE]
emu_5_romfilter=*.cue
emu_5_database=
emu_5_configfile=[Mapping Off] Exit (Process Close)
emu_5_mapfile=[Console] Sony Playstation.map
emu_5_rompath=D:\Emulators\PS1\isos
emu_5_snappath=D:\GameEx\Assets\PS1\Sony Playstation\Snaps
emu_5_titlepath=D:\GameEx\Assets\PS1\Sony Playstation\Titles
emu_5_boxpath=D:\GameEx\Assets\PS1\Sony Playstation\Boxes
emu_5_cartpath=D:\GameEx\Assets\PS1\Sony Playstation\Cartridges
emu_5_manualpath=D:\GameEx\Assets\PS1\Sony Playstation\Manuals
emu_5_controlpanelpath=D:\GameEx\Assets\PS1\Sony Playstation\Controls
emu_5_workingpath=D:\Emulators\PS1
emu_5_mapkeys=True
emu_5_waitbeforekeys=
emu_5_sendkeys=
emu_5_replacedash=False
emu_5_replaceunder=True
emu_5_capitals=False
emu_5_removebrackets=True
emu_5_showdesktop=True
emu_5_debug=False
emu_5_alsolaunch=
emu_5_launchbefore=
emu_5_launchafter=
emu_5_excludedfiles=
emu_5_custombackground=
emu_5_playmusic=False
emu_5_dontshowinfo=
emu_5_playselectionmusic=False
emu_5_selectionmusicfolder=
emu_5_pcgame=False
emu_5_gamesin7zips=True
emu_5_playinscreensaver=False
emu_5_showmostplayed=True
emu_5_randommostplayed=True
emu_5_cdcheck=False
emu_5_cdcheckfile=
emu_5_downloadid=204
emu_5_baksnappath=
emu_5_databasesnappath=
emu_7lastfolderwrite=4/16/2016 11:49:52 AM
emu_7lastromfilter=*.*
emu_7_dbcachemodified=12/16/2014 5:12:56 PM
emu_7_lastnumgames=723
emu_7_dbcachelastname=[Console] Sega Genesis
emu_7_dbcacheinicreated51=True
emu_7_enabled=True
emu_7_system=Sega Genesis
emu_7_category=Console
emu_7_emulator=Fusion
emu_7_version=3.64
emu_7_rating=8.9
emu_7_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Fusion.7z
emu_7_requiredfiles=
emu_7_info=Fusion(formerly known as Kega II and Kega Fusion) is a Sega SG1000, SC3000, Master System, Game Gear, Genesis/Megadrive, SegaCD/MegaCD and 32X emulator
emu_7_titletext=Sega Genesis
emu_7_startpagename=[Console] Sega Genesis (Fusion)
emu_7_startpagelogo=Sega Genesis
emu_7_command=Fusion.exe -gen -fullscreen
[ROMPATH]\[ROMFILE]
emu_7_romfilter=
emu_7_database=[Console] Sega Genesis
emu_7_configfile=[Mapping Off] Exit (Process Close)
emu_7_mapfile=
emu_7_rompath=D:\Emulators\Genesis\Roms
emu_7_snappath=D:\GameEx\Assets\Genesis\Snaps
emu_7_titlepath=D:\GameEx\Assets\Genesis\Titles
emu_7_boxpath=D:\GameEx\Assets\Genesis\Boxes
emu_7_cartpath=D:\GameEx\Assets\Genesis\Cartridges
emu_7_manualpath=D:\GameEx\Assets\Genesis\Manuals
emu_7_controlpanelpath=D:\GameEx\Assets\Genesis\Controls
emu_7_workingpath=D:\Emulators\Genesis
emu_7_mapkeys=True
emu_7_waitbeforekeys=
emu_7_sendkeys=
emu_7_replacedash=False
emu_7_replaceunder=True
emu_7_capitals=False
emu_7_removebrackets=True
emu_7_showdesktop=True
emu_7_debug=False
emu_7_alsolaunch=
emu_7_oldatzip=
emu_7_launchbefore=
emu_7_launchafter=
emu_7_excludedfiles=
emu_7_custombackground=
emu_7_playmusic=True
emu_7_dontshowinfo=
emu_7_playselectionmusic=False
emu_7_selectionmusicfolder=
emu_7_pcgame=False
emu_7_gamesin7zips=False
emu_7_playinscreensaver=False
emu_7_showmostplayed=True
emu_7_randommostplayed=True
emu_7_cdcheck=False
emu_7_cdcheckfile=
emu_7_downloadid=207
emu_7_baksnappath=
emu_7_databasesnappath=
emu_4_downloadid=215
emu_4_cdcheckfile=
emu_4_cdcheck=False
emu_4_randommostplayed=True
emu_4_showmostplayed=True
emu_4_playinscreensaver=False
emu_4_gamesin7zips=False
emu_4_pcgame=False
emu_4_selectionmusicfolder=
emu_4_playselectionmusic=False
emu_4_dontshowinfo=
emu_4_playmusic=False
emu_4_custombackground=
emu_4_excludedfiles=
emu_4_launchafter=
emu_4_launchbefore=
emu_4_oldatzip=
emu_4_alsolaunch=
emu_4_debug=False
emu_4_showdesktop=True
emu_4_removebrackets=True
emu_4_capitals=False
emu_4_replaceunder=True
emu_4_replacedash=False
emu_4_sendkeys=
emu_4_waitbeforekeys=
emu_4_mapkeys=True
emu_4_workingpath=D:\Emulators\TG16
emu_4_controlpanelpath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Controls
emu_4_manualpath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Manuals
emu_4_cartpath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Cartridges
emu_4_boxpath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Boxes
emu_4_titlepath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Titles
emu_4_snappath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Snaps
emu_4_rompath=D:\Emulators\TG16\ROMS
emu_4_mapfile=
emu_4_configfile=[Mapping Off] Exit (Process Close)
emu_4_database=[Console] NEC TurboGrafx-16
emu_4_romfilter=*.zip
emu_4_command=pce.exe
[ROMPATH]\[ROMFILE]
emu_4_startpagelogo=NEC TurboGrafx-16
emu_4_startpagename=NEC TurboGrafx-16
emu_4_titletext=NEC TurboGrafx-16
emu_4_info=PC Engine (TurboGrafx 16) emulator
emu_4_website=http://www.magicengine.com/
emu_4_requiredfiles=
emu_4_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/magicengine.7z
emu_4_rating=
emu_4_version=1.1.3
emu_4_emulator=MagicEngine
emu_4_category=Console
emu_4_system=NEC TurboGrafx-16
emu_4_enabled=True
emu_4_baksnappath=
emu_4_databasesnappath=
emu_8lastfolderwrite=4/17/2016 2:17:30 AM
emu_8lastromfilter=*.*
emu_8_dbcachemodified=12/16/2014 5:13:00 PM
emu_8_lastnumgames=88
emu_8_dbcachelastname=[Console] Sega Master System
emu_8_dbcacheinicreated51=True
emu_8_enabled=True
emu_8_system=Sega Master System
emu_8_category=Console
emu_8_emulator=Fusion
emu_8_version=3.64
emu_8_rating=8.9
emu_8_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Fusion.7z
emu_8_requiredfiles=
emu_8_info=Fusion(formerly known as Kega II and Kega Fusion) is a Sega SG1000, SC3000, Master System, Game Gear, Genesis/Megadrive, SegaCD/MegaCD and 32X emulator
emu_8_titletext=Sega Master System
emu_8_startpagename=Sega Master System
emu_8_startpagelogo=Sega Master System
emu_8_command=Fusion.exe -sms -fullscreen
[ROMPATH]\[ROMFILE]
emu_8_romfilter=
emu_8_database=[Console] Sega Master System
emu_8_configfile=[Mapping Off] Exit (Process Close)
emu_8_mapfile=
emu_8_rompath=D:\Emulators\Sega Master System\Roms
emu_8_snappath=D:\GameEx\Assets\Sega Master System\Snaps
emu_8_titlepath=D:\GameEx\Assets\Sega Master System\Titles
emu_8_boxpath=D:\GameEx\Assets\Sega Master System\Boxes
emu_8_cartpath=D:\GameEx\Assets\Sega Master System\Cartridges
emu_8_manualpath=D:\GameEx\Assets\Sega Master System\Manuals
emu_8_controlpanelpath=D:\GameEx\Assets\Sega Master System\Controls
emu_8_workingpath=D:\Emulators\Sega Master System
emu_8_mapkeys=True
emu_8_waitbeforekeys=
emu_8_sendkeys=
emu_8_replacedash=False
emu_8_replaceunder=True
emu_8_capitals=False
emu_8_removebrackets=True
emu_8_showdesktop=True
emu_8_debug=False
emu_8_alsolaunch=
emu_8_oldatzip=
emu_8_launchbefore=
emu_8_launchafter=
emu_8_excludedfiles=
emu_8_custombackground=
emu_8_playmusic=False
emu_8_dontshowinfo=
emu_8_playselectionmusic=False
emu_8_selectionmusicfolder=
emu_8_pcgame=False
emu_8_gamesin7zips=False
emu_8_playinscreensaver=False
emu_8_showmostplayed=True
emu_8_randommostplayed=True
emu_8_cdcheck=False
emu_8_cdcheckfile=
emu_8_downloadid=207
emu_8_baksnappath=
emu_8_databasesnappath=
emu_2_databasesnappath=
emu_2_baksnappath=
emu_5_romsinfolders=True
emu_9lastfolderwrite=4/20/2016 2:49:03 AM
emu_9lastromfilter=*.*
emu_9_dbcachemodified=3/15/2016 7:53:31 AM
emu_9_lastnumgames=95
emu_9_dbcachelastname=[Console] Nintendo N64
emu_9_dbcacheinicreated51=True
emu_9_enabled=True
emu_9_system=Nintendo N64
emu_9_category=Console
emu_9_emulator=Project64
emu_9_version=1.6
emu_9_rating=8.9
emu_9_downloadurl=http://www.gamesdbase.com/setupwizard/emulators/download/Project64.7z
emu_9_requiredfiles=
emu_9_website=http://www.pj64-emu.com/
emu_9_info=Nintendo 64 emulator
emu_9_titletext=Nintendo N64
emu_9_startpagename=Nintendo N64
emu_9_startpagelogo=Nintendo N64
emu_9_command=Project64.exe
[ROMPATH]\[ROMFILE]
emu_9_romfilter=
emu_9_database=[Console] Nintendo N64
emu_9_configfile=P64 exit
emu_9_mapfile=
emu_9_rompath=D:\Emulators\\Nintendo N64\Roms
emu_9_snappath=D:\GameEx\Assets\Nintendo N64\Snaps
emu_9_titlepath=D:\GameEx\Assets\Nintendo N64\Titles
emu_9_boxpath=D:\GameEx\Assets\Nintendo N64\Boxes
emu_9_cartpath=D:\GameEx\Assets\Nintendo N64\Cartridges
emu_9_manualpath=D:\GameEx\Assets\Nintendo N64\Manuals
emu_9_controlpanelpath=D:\GameEx\Assets\Nintendo N64\Controls
emu_9_workingpath=D:\Emulators\Nintendo N64
emu_9_mapkeys=True
emu_9_waitbeforekeys=
emu_9_sendkeys=
emu_9_replacedash=False
emu_9_replaceunder=True
emu_9_capitals=False
emu_9_removebrackets=True
emu_9_showdesktop=True
emu_9_debug=False
emu_9_alsolaunch=
emu_9_oldatzip=
emu_9_launchbefore=
emu_9_launchafter=
emu_9_excludedfiles=
emu_9_custombackground=
emu_9_playmusic=False
emu_9_dontshowinfo=
emu_9_playselectionmusic=False
emu_9_selectionmusicfolder=
emu_9_pcgame=False
emu_9_gamesin7zips=False
emu_9_playinscreensaver=False
emu_9_showmostplayed=True
emu_9_randommostplayed=True
emu_9_cdcheck=False
emu_9_cdcheckfile=
emu_9_downloadid=240
emu_9_baksnappath=
emu_9_databasesnappath=
emu_10lastfolderwrite=4/20/2016 12:03:37 PM
emu_10lastromfilter=*.*
emu_10_dbcachemodified=12/16/2014 5:14:36 PM
emu_10_lastnumgames=137
emu_10_dbcachelastname=[Handheld] Nintendo Game Boy Advance
emu_10_dbcacheinicreated51=True
[CachedImages]
res=786432
bakres=786432
[CachedImagesMenuFont]
res=0
[SetupWizard]
EmuPath1=D:\Emulators\
AssetPath1=D:\GameEx\Assets
RomPath1=D:\Emulators\
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=Emulator Setup|Advanced Emulator Setup
SearchArray=
SavePosition=False
SearchText=
EmulatorIndex=9
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowSize=1106, 578
WindowLocation=143, 57
WindowState=Normal
SectionIndex=41
[Emulator_1]
lastgame=
DownloadID=255
CDCheckFile=
CDCheck=False
RandomMostPlayed=True
ShowMostPlayed=True
PlayInScreenSaver=False
GamesIn7Zips=False
PCGame=False
PlaySelectionMusic=False
DontShowInfo=False
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\2600
ControlPanelPath=D:\GameEx\Assets\Atari 2600\Controls
ManualPath=D:\GameEx\Assets\Atari 2600\Manuals
CartPath=D:\GameEx\Assets\Atari 2600\Cartridges
BoxPath=D:\GameEx\Assets\Atari 2600\Boxes
TitlePath=D:\GameEx\Assets\Atari 2600\Titles
SnapPath=D:\GameEx\Assets\Atari 2600\Snaps
RomPath=D:\Emulators\2600\ROMS
MapFile=
ConfigFile=[Mapping Off] Exit (Process Close)
Database=[Console] Atari 2600
RomFilter=
Command=Stella.exe -video gl -gl_fsmax 1 -fullscreen 1 "[ROMPATH]\[ROMFILE]"
StartPageLogo=AtariLogo
StartPageName=Atari 2600
TitleText=Atari 2600
Info=Atari 2600 emulator
Website=http://stella.sourceforge.net/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/stella.7z
Rating=7.9
Version=3.6.1
Emulator=Stella
Category=Console
System=Atari 2600
Databasesnappath=D:\GameEx\Assets\Atari 2600\Snaps
BakSnapPath=D:\GameEx\Assets\Atari 2600\Snaps
[Emulator_2]
DownloadID=206
CDCheckFile=
CDCheck=False
ShowMostPlayed=True
GamesIn7Zips=False
PCGame=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\NES
ControlPanelPath=D:\GameEx\Assets\NES\Nintendo NES\Controls
ManualPath=D:\GameEx\Assets\NES\Nintendo NES\Manuals
CartPath=D:\GameEx\Assets\NES\Nintendo NES\Cartridges
BoxPath=D:\GameEx\Assets\NES\Nintendo NES\Boxes
TitlePath=D:\GameEx\Assets\NES\Nintendo NES\Titles
SnapPath=D:\GameEx\Assets\NES\Nintendo NES\Snaps
RomPath=D:\Emulators\NES\ROMS
MapFile=
Database=[Console] Nintendo NES
RomFilter=
Command=nestopia.exe "[ROMPATH]\[ROMFILE]"
StartPageLogo=Nintendo NES
StartPageName=Nintendo NES
TitleText=Nintendo NES
Info=Nintendo NES 8bit emulator
Website=http://fceux.com/web/htdocs/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/FCE%20Ultra.7z
Rating=8.6
Version=2.1.5
Emulator=FCE Ultra
Category=Console
System=Nintendo NES
lastgame=
Databasesnappath=
BakSnapPath=
[Emulator_16]
Enabled=False
[Emulator_15]
Enabled=False
[Emulator_14]
Enabled=False
[Emulator_13]
Enabled=False
[Emulator_12]
Enabled=False
[Emulator_11]
Enabled=False
[Emulator_10]
System=Nintendo Game Boy Advance
Category=Handheld
Emulator=VisualBoyAdvance
Version=1.8.0beta3
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/VisualBoyAdvance.7z
RequiredFiles=
Website=http://vba.ngemu.com/
Info=Nintendo Game boy, Game boy color and Gameboy advance emulator
TitleText=Nintendo Game Boy Advance
StartPageName=Nintendo Game Boy Advance
StartPageLogo=Nintendo Game Boy Advance
Command=VisualBoyAdvance.exe "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Handheld] Nintendo Game Boy Advance
MapFile=
RomPath=D:\Emulators\GBA\ROMS
SnapPath=D:\GameEx\Assets\Nintendo Game Boy Advance\Snaps
TitlePath=D:\GameEx\Assets\Nintendo Game Boy Advance\Titles
BoxPath=D:\GameEx\Assets\Nintendo Game Boy Advance\Boxes
CartPath=D:\GameEx\Assets\Nintendo Game Boy Advance\Cartridges
ManualPath=D:\GameEx\Assets\Nintendo Game Boy Advance\Manuals
ControlPanelPath=D:\GameEx\Assets\Nintendo Game Boy Advance\Controls
WorkingPath=D:\Emulators\GBA
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=262
BakSnapPath=
Databasesnappath=
[Emulator_9]
System=Nintendo N64
Category=Console
Emulator=Project64
Version=1.6
Rating=8.9
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Project64.7z
RequiredFiles=
Website=http://www.pj64-emu.com/
Info=Nintendo 64 emulator
TitleText=Nintendo N64
StartPageName=Nintendo N64
StartPageLogo=Nintendo N64
Command=Project64.exe "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo N64
ConfigFile=P64 exit
MapFile=
RomPath=D:\Emulators\\Nintendo N64\Roms
SnapPath=D:\GameEx\Assets\Nintendo N64\Snaps
TitlePath=D:\GameEx\Assets\Nintendo N64\Titles
BoxPath=D:\GameEx\Assets\Nintendo N64\Boxes
CartPath=D:\GameEx\Assets\Nintendo N64\Cartridges
ManualPath=D:\GameEx\Assets\Nintendo N64\Manuals
ControlPanelPath=D:\GameEx\Assets\Nintendo N64\Controls
WorkingPath=D:\Emulators\Nintendo N64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=240
BakSnapPath=
Databasesnappath=
lastgame=
[Emulator_8]
System=Sega Master System
Category=Console
Emulator=Fusion
Version=3.64
Rating=8.9
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Fusion.7z
RequiredFiles=
Info=Fusion(formerly known as Kega II and Kega Fusion) is a Sega SG1000, SC3000, Master System, Game Gear, Genesis/Megadrive, SegaCD/MegaCD and 32X emulator
TitleText=Sega Master System
StartPageName=Sega Master System
StartPageLogo=Sega Master System
Command=Fusion.exe -sms -fullscreen "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Sega Master System
MapFile=
RomPath=D:\Emulators\Sega Master System\Roms
SnapPath=D:\GameEx\Assets\Sega Master System\Snaps
TitlePath=D:\GameEx\Assets\Sega Master System\Titles
BoxPath=D:\GameEx\Assets\Sega Master System\Boxes
CartPath=D:\GameEx\Assets\Sega Master System\Cartridges
ManualPath=D:\GameEx\Assets\Sega Master System\Manuals
ControlPanelPath=D:\GameEx\Assets\Sega Master System\Controls
WorkingPath=D:\Emulators\Sega Master System
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=207
BakSnapPath=
Databasesnappath=
lastgame=
[Emulator_7]
System=Sega Genesis
Category=Console
Emulator=Fusion
Version=3.64
Rating=8.9
RequiredFiles=
TitleText=Sega Genesis
StartPageName=[Console] Sega Genesis (Fusion)
StartPageLogo=Sega Genesis
Command=Fusion.exe -gen -fullscreen "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Sega Genesis
MapFile=
RomPath=D:\Emulators\Genesis\Roms
SnapPath=D:\GameEx\Assets\Genesis\Snaps
TitlePath=D:\GameEx\Assets\Genesis\Titles
BoxPath=D:\GameEx\Assets\Genesis\Boxes
CartPath=D:\GameEx\Assets\Genesis\Cartridges
ManualPath=D:\GameEx\Assets\Genesis\Manuals
ControlPanelPath=D:\GameEx\Assets\Genesis\Controls
WorkingPath=D:\Emulators\Genesis
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=True
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=207
BakSnapPath=
Databasesnappath=
lastgame=
[Emulator_6]
System=Nintendo GameCube
Category=Console
Emulator=Dolphin
Version=3.0-631
Rating=7.9
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Dolphin.7z
RequiredFiles=DirectX Runtime, Microsoft Visual C++ 2010 Redistributable Package
Website=http://www.dolphin-emulator.com
Info=Nintendo Gamecube and Wii emulator
TitleText=Nintendo GameCube
StartPageName=Nintendo GameCube
StartPageLogo=Nintendo GameCube
Command=Dolphin.exe -e "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo GameCube
MapFile=
RomPath=D:\Emulators\Game Cube\Dolphin\isos
SnapPath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Snaps
TitlePath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Titles
BoxPath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Boxes
CartPath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Cartridges
ManualPath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Manuals
ControlPanelPath=D:\GameEx\Assets\Game Cube\Nintendo GameCube\Controls
WorkingPath=D:\Emulators\Game Cube\Dolphin
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
LaunchBefore=
LaunchAfter=D:\GameEx\CONFIG\dolphin-kill.bat
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=202
BakSnapPath=
Databasesnappath=
lastgame=
[Emulator_5]
System=Sony Playstation
Category=Console
Emulator=ePSXe
Version=1.9.0
Rating=8.3
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/epsxe.7z
RequiredFiles=scph1001.bin (512kb)
Website=http://www.epsxe.com/
Info=Sony Playstation Emulator
TitleText=Sony Playstation
StartPageName=Sony Playstation
StartPageLogo=Sony Playstation
Command= ePSXe.exe -nogui -loadbin "[ROMPATH]\[ROMFILE]"
RomFilter=*.cue
Database=
MapFile=[Console] Sony Playstation.map
RomPath=D:\Emulators\PS1\isos
SnapPath=D:\GameEx\Assets\PS1\Sony Playstation\Snaps
TitlePath=D:\GameEx\Assets\PS1\Sony Playstation\Titles
BoxPath=D:\GameEx\Assets\PS1\Sony Playstation\Boxes
CartPath=D:\GameEx\Assets\PS1\Sony Playstation\Cartridges
ManualPath=D:\GameEx\Assets\PS1\Sony Playstation\Manuals
ControlPanelPath=D:\GameEx\Assets\PS1\Sony Playstation\Controls
WorkingPath=D:\Emulators\PS1
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=True
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=204
BakSnapPath=
Databasesnappath=
lastgame=
RomsInFolders=True
[Emulator_4]
DownloadID=215
CDCheckFile=
CDCheck=False
ShowMostPlayed=True
GamesIn7Zips=False
PCGame=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=D:\Emulators\TG16
ControlPanelPath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Controls
ManualPath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Manuals
CartPath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Cartridges
BoxPath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Boxes
TitlePath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Titles
SnapPath=D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Snaps
RomPath=D:\Emulators\TG16\ROMS
MapFile=
Database=[Console] NEC TurboGrafx-16
RomFilter=*.zip
Command=pce.exe "[ROMPATH]\[ROMFILE]"
StartPageLogo=NEC TurboGrafx-16
StartPageName=NEC TurboGrafx-16
TitleText=NEC TurboGrafx-16
Info=PC Engine (TurboGrafx 16) emulator
Website=http://www.magicengine.com/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/magicengine.7z
Rating=
Version=1.1.3
Emulator=MagicEngine
Category=Console
System=NEC TurboGrafx-16
BakSnapPath=
Databasesnappath=
lastgame=
[Emulator_3]
System=Nintendo SNES
Category=Console
Emulator=ZSNES
Version=1.51
Rating=9.0
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/zsnes.7z
RequiredFiles=
Website=http://www.zsnes.com/
Info=Super Nintendo emulator
TitleText=Nintendo SNES
StartPageName=Nintendo SNES
StartPageLogo=Nintendo SNES
Command=zsnesw.exe "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Nintendo SNES
ConfigFile=ZSNES V6
MapFile=
RomPath=D:\Emulators\SNES\ROMS
SnapPath=D:\GameEx\Assets\SNES\Nintendo SNES\Snaps
TitlePath=D:\GameEx\Assets\SNES\Nintendo SNES\Titles
BoxPath=D:\GameEx\Assets\SNES\Nintendo SNES\Boxes
CartPath=D:\GameEx\Assets\SNES\Nintendo SNES\Cartridges
ManualPath=D:\GameEx\Assets\SNES\Nintendo SNES\Manuals
ControlPanelPath=D:\GameEx\Assets\SNES\Nintendo SNES\Controls
WorkingPath=D:\Emulators\SNES
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
DownloadID=272
BakSnapPath=
Databasesnappath=
lastgame=
[CachedImagesGameFont]
res=786432
[CachedImagesGameFontFaded]
res=786432
[CachedImages3d]
themedir=\themes\Default - Brokeh\MEDIA\
titlefontres=786432
titlefont=Trebuchet MS
titlefontstyle=0
titlefontsize=36
outlinefonts=False
use16bitcolour=False
gradienttitlefont=False
lowercasetitlefont=False
antialiasfonts=True
windowed=False
[LIST_SETTINGS_8]
displaybackgroundimage=True
displaybackgroundimageemu=False
displaystartpagemenuimage=False
displaystartpagemenuimage2=False
displaystartpagelistnotforcebaksnap=True
displayimagelist=False
[Weather]
Enabled=False
EnablePage=False
Log file (before this log I ran project64 within GameEx and tried escape button which only took it from full screen to windowed. I then just hit the X on the window screen to exit back to GameEx)
Spoiler
22:27:51.9  4/20/2016:  Opening Configuration File
22:27:51.9  4/20/2016:  GameEx: Version 14.44: Starting Log
22:27:52.0  4/20/2016:  Windows 10 Home 64-bit
22:27:52.0  4/20/2016:  Aero running
22:27:52.0  4/20/2016:  Initializing Vista/Windows 7 volume control
22:27:52.0  4/20/2016:  Getting CPU and RAM info
22:27:52.0  4/20/2016:  Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz, 16334MB
22:27:52.0  4/20/2016:  3.31Ghz - 4 Cores or CPU's
22:27:52.0  4/20/2016:  Running Randomize()
22:27:52.0  4/20/2016:  Loading PlugIns
22:27:52.0  4/20/2016:  Checking for applications to Launch On Startup
22:27:52.0  4/20/2016:  Setting default net connection limit to 15
22:27:52.0  4/20/2016:  Running Misc startup tasks
22:27:52.0  4/20/2016:  Setting Menu types
22:27:52.0  4/20/2016:  Getting Configuration Values
22:27:52.0  4/20/2016:  Using Theme: Default - Brokeh
22:27:52.0  4/20/2016:  Checking for alternate Image Directory for Theme: Default - Brokeh
22:27:52.0  4/20/2016:  Launching HideOS.exe
22:27:52.0  4/20/2016:  Initialising Video/MNG DLL's
22:27:52.0  4/20/2016:  Hiding Taskbar
22:27:52.0  4/20/2016:  Is Media Center running?
22:27:52.0  4/20/2016:  Checking/Creating LCD Registry values
22:27:52.0  4/20/2016:  Check Media Center Exit/Start Mode
22:27:52.0  4/20/2016:  Media Center Mode 2
22:27:52.0  4/20/2016:  Video previews on. Warning: Only recommended on modern systems
22:27:52.0  4/20/2016:  Snap Delay set to: 4
22:27:52.0  4/20/2016:  Get other settings
22:27:52.0  4/20/2016:  Desktop set to Hide ICONS and set Background to Black
22:27:52.0  4/20/2016:  Set: Find emulator artwork on best match basis
22:27:52.0  4/20/2016:  Start work for Form
22:27:52.0  4/20/2016:  Getting Original Screen Size
22:27:52.1  4/20/2016:  Opening Database Connection
22:27:52.1  4/20/2016:  Initializing Component
22:27:52.1  4/20/2016:  Loading Controls.ini map file
22:27:52.1  4/20/2016:  Applying Language/Text
22:27:52.1  4/20/2016:  Text/Language: English
22:27:52.1  4/20/2016:  Loading Language/Text
22:27:52.1  4/20/2016:  Using 3D Alpha Blended Animations.
22:27:52.1  4/20/2016:  Retrieving resolution setting
22:27:52.1  4/20/2016:  Using General Font: Trebuchet MS
22:27:52.1  4/20/2016:  Using Title Font: Trebuchet MS
22:27:52.1  4/20/2016:  GameEx will try to reduce CPU usage
22:27:52.2  4/20/2016:  Initialising Direct3D
22:27:52.3  4/20/2016:  Applying GameEx is Loading Image
22:27:52.3  4/20/2016:  Setting Resolution to 1024x768 32 bit color
22:27:52.3  4/20/2016:  Creating Surfaces
22:27:52.9  4/20/2016:  Creating Primary Surface - Full Screen Mode
22:27:52.9  4/20/2016:  Creating Back Buffer
22:27:52.9  4/20/2016:  Version 2 Theme being used. Loading.
22:27:52.9  4/20/2016:  Loading Button Data
22:27:52.9  4/20/2016:  Loading Font Data
22:27:52.9  4/20/2016:  Loading Layout Data
22:27:52.9  4/20/2016:  Loading Taskbar Data
22:27:52.9  4/20/2016:  Loading graphic Surfaces
22:27:52.9  4/20/2016:  Display is running at: 1024x768 32bit color, 75hz
22:27:52.9  4/20/2016:  Adapter: AMD Radeon (TM) R9 390 Series
22:27:52.9  4/20/2016:  Max texture size: 16384x16384
22:27:52.9  4/20/2016:  Available texture memory: -9MB
22:27:52.9  4/20/2016:  Initialising Bass Audio Library
22:27:52.9  4/20/2016:  Creating Surfaces Misc and Dialogs
22:27:53.0  4/20/2016:  Creating Surfaces Volume
22:27:53.0  4/20/2016:  Creating Surfaces Arrows
22:27:53.0  4/20/2016:  Creating Surfaces GameEXlogo Text
22:27:53.0  4/20/2016:  Creating Surfaces Toolbar
22:27:53.0  4/20/2016:  Creating Surfaces Toolbar Controls
22:27:53.0  4/20/2016:  Creating Surfaces Backgrounds
22:27:53.0  4/20/2016:  Creating Surfaces GameEx Logo
22:27:53.0  4/20/2016:  Creating Surface Unselected
22:27:53.0  4/20/2016:  Creating Surfaces Snaps
22:27:53.0  4/20/2016:  Creating Surfaces Menu and List Bars
22:27:53.0  4/20/2016:  Creating Fonts
22:27:53.0  4/20/2016:  Creating Game Font
22:27:53.1  4/20/2016:  Creating Game Font Faded
22:27:53.1  4/20/2016:  Creating Title Font
22:27:53.1  4/20/2016:  Restoring Title Font From Cache
22:27:53.2  4/20/2016:  Creating Font Black
22:27:53.2  4/20/2016:  Creating Font Black Small
22:27:53.3  4/20/2016:  Fonts Created Succesfully
22:27:53.3  4/20/2016:  Initial Emulator Load
22:27:53.4  4/20/2016:  Loading Custom Emulators
22:27:53.4  4/20/2016:  Loading Emulator 1: Atari 2600
22:27:53.5  4/20/2016:  Loading Emulator 2: Nintendo NES
22:27:53.5  4/20/2016:  Loading Emulator 3: Nintendo SNES
22:27:53.6  4/20/2016:  Loading Emulator 4: NEC TurboGrafx-16
22:27:53.6  4/20/2016:  Loading Emulator 5: Sony Playstation
22:27:53.6  4/20/2016:  Loading Emulator 6: Nintendo GameCube
22:27:53.7  4/20/2016:  Loading Emulator 7: [Console] Sega Genesis (Fusion)
22:27:53.7  4/20/2016:  Loading Emulator 8: Sega Master System
22:27:53.7  4/20/2016:  Loading Emulator 9: Nintendo N64
22:27:53.7  4/20/2016:  Loading Emulator 10: Nintendo Game Boy Advance
22:27:53.8  4/20/2016:  Checking if Steam enabled
22:27:53.8  4/20/2016:  Steam support is turned off in configuration.
22:27:53.8  4/20/2016:  Checking if Origin enabled
22:27:53.8  4/20/2016:  Origin support is turned off in configuration.
22:27:53.8  4/20/2016:  Checking if Uplay enabled
22:27:53.8  4/20/2016:  UPlay support is turned off in configuration.
22:27:53.8  4/20/2016:  MAME CMD options: -nowindow -joy -skip_gameinfo
22:27:53.9  4/20/2016:  Cannot Load Play List. Check Path and filename
22:27:53.9  4/20/2016:  Initialising DirectInput for Gamepad support
22:27:53.9  4/20/2016:  Unable to create a joystick device
22:27:53.9  4/20/2016:  Loading Start Page
22:27:54.0  4/20/2016:  Initializing MCE Remote
22:27:54.0  4/20/2016:  Playing intro sound file
22:27:54.0  4/20/2016:  Initialization OK! Starting GameEx!
22:27:54.0  4/20/2016:  Testing Main Loop Once: Processing Frame
22:27:54.1  4/20/2016:  Testing Main Loop Once: Main Loop ran successfully
22:27:57.5  4/20/2016:  Validating: Emulator_1: Snap Path: D:\GameEx\Assets\Atari 2600\Snaps
22:27:57.6  4/20/2016:  Validating: Emulator_1: Background Snap Path: D:\GameEx\Assets\Atari 2600\Snaps
22:27:57.6  4/20/2016:  Validating: Emulator_1: Database Snap Path: D:\GameEx\Assets\Atari 2600\Snaps
22:27:57.6  4/20/2016:  Validating: Emulator_1: Control Panel Path: D:\GameEx\Assets\Atari 2600\Controls
22:27:57.6  4/20/2016:  Validating: Emulator_1: Database: [Console] Atari 2600
22:27:57.6  4/20/2016:  Validating: Emulator_1: Title Snap Path: D:\GameEx\Assets\Atari 2600\Titles
22:27:57.6  4/20/2016:  Validating: Emulator_1: Box Art Path: D:\GameEx\Assets\Atari 2600\Boxes
22:27:57.6  4/20/2016:  Validating: Emulator_1: Cart Art Path: D:\GameEx\Assets\Atari 2600\Cartridges
22:27:57.6  4/20/2016:  Validating: Emulator_1: Manual Path: D:\GameEx\Assets\Atari 2600\Manuals
22:27:57.6  4/20/2016:  Validating: Emulator_2: Snap Path: D:\GameEx\Assets\NES\Nintendo NES\Snaps
22:27:57.6  4/20/2016:  Validating: Emulator_2: Control Panel Path: D:\GameEx\Assets\NES\Nintendo NES\Controls
22:27:57.6  4/20/2016:  Validating: Emulator_2: Database: [Console] Nintendo NES
22:27:57.7  4/20/2016:  Validating: Emulator_2: Title Snap Path: D:\GameEx\Assets\NES\Nintendo NES\Titles
22:27:57.7  4/20/2016:  Validating: Emulator_2: Box Art Path: D:\GameEx\Assets\NES\Nintendo NES\Boxes
22:27:57.7  4/20/2016:  Validating: Emulator_2: Cart Art Path: D:\GameEx\Assets\NES\Nintendo NES\Cartridges
22:27:57.7  4/20/2016:  Validating: Emulator_2: Manual Path: D:\GameEx\Assets\NES\Nintendo NES\Manuals
22:27:57.7  4/20/2016:  Validating: Emulator_3: Snap Path: D:\GameEx\Assets\SNES\Nintendo SNES\Snaps
22:27:57.7  4/20/2016:  Validating: Emulator_3: Control Panel Path: D:\GameEx\Assets\SNES\Nintendo SNES\Controls
22:27:57.7  4/20/2016:  Validating: Emulator_3: Database: [Console] Nintendo SNES
22:27:57.7  4/20/2016:  Validating: Emulator_3: Title Snap Path: D:\GameEx\Assets\SNES\Nintendo SNES\Titles
22:27:57.7  4/20/2016:  Validating: Emulator_3: Box Art Path: D:\GameEx\Assets\SNES\Nintendo SNES\Boxes
22:27:57.7  4/20/2016:  Validating: Emulator_3: Cart Art Path: D:\GameEx\Assets\SNES\Nintendo SNES\Cartridges
22:27:57.7  4/20/2016:  Validating: Emulator_3: Manual Path: D:\GameEx\Assets\SNES\Nintendo SNES\Manuals
22:27:57.7  4/20/2016:  Validating: Emulator_4: Snap Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Snaps
22:27:57.7  4/20/2016:  Warning: Emulator_4: Snap Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_4: Control Panel Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Controls
22:27:57.7  4/20/2016:  Warning: Emulator_4: Control Panel Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_4: Database: [Console] NEC TurboGrafx-16
22:27:57.7  4/20/2016:  Validating: Emulator_4: Title Snap Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Titles
22:27:57.7  4/20/2016:  Warning: Emulator_4: Title Snap Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_4: Box Art Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Boxes
22:27:57.7  4/20/2016:  Warning: Emulator_4: Box Art Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_4: Cart Art Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Cartridges
22:27:57.7  4/20/2016:  Warning: Emulator_4: Cart Art Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_4: Manual Path: D:\GameEx\Assets\TG16\NEC TurboGrafx-16\Manuals
22:27:57.7  4/20/2016:  Warning: Emulator_4: Manual Path Does not exist
22:27:57.7  4/20/2016:  Validating: Emulator_5: Snap Path: D:\GameEx\Assets\PS1\Sony Playstation\Snaps
22:27:57.7  4/20/2016:  Validating: Emulator_5: Control Panel Path: D:\GameEx\Assets\PS1\Sony Playstation\Controls
22:27:57.7  4/20/2016:  Validating: Emulator_5: Title Snap Path: D:\GameEx\Assets\PS1\Sony Playstation\Titles
22:27:57.7  4/20/2016:  Validating: Emulator_5: Box Art Path: D:\GameEx\Assets\PS1\Sony Playstation\Boxes
22:27:57.7  4/20/2016:  Validating: Emulator_5: Cart Art Path: D:\GameEx\Assets\PS1\Sony Playstation\Cartridges
22:27:57.7  4/20/2016:  Validating: Emulator_5: Manual Path: D:\GameEx\Assets\PS1\Sony Playstation\Manuals
22:27:57.7  4/20/2016:  Warning: Emulator_5: MAPFile Does Not Exist
22:27:57.7  4/20/2016:  Validating: Emulator_6: Snap Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Snaps
22:27:57.7  4/20/2016:  Validating: Emulator_6: Control Panel Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Controls
22:27:57.7  4/20/2016:  Validating: Emulator_6: Database: [Console] Nintendo GameCube
22:27:57.7  4/20/2016:  Validating: Emulator_6: Title Snap Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Titles
22:27:57.7  4/20/2016:  Validating: Emulator_6: Box Art Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Boxes
22:27:57.7  4/20/2016:  Validating: Emulator_6: Cart Art Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Cartridges
22:27:57.7  4/20/2016:  Validating: Emulator_6: Manual Path: D:\GameEx\Assets\Game Cube\Nintendo GameCube\Manuals
22:27:57.7  4/20/2016:  Validating: Emulator_7: Snap Path: D:\GameEx\Assets\Genesis\Snaps
22:27:57.8  4/20/2016:  Validating: Emulator_7: Control Panel Path: D:\GameEx\Assets\Genesis\Controls
22:27:57.8  4/20/2016:  Validating: Emulator_7: Database: [Console] Sega Genesis
22:27:57.8  4/20/2016:  Validating: Emulator_7: Title Snap Path: D:\GameEx\Assets\Genesis\Titles
22:27:57.8  4/20/2016:  Validating: Emulator_7: Box Art Path: D:\GameEx\Assets\Genesis\Boxes
22:27:57.8  4/20/2016:  Validating: Emulator_7: Cart Art Path: D:\GameEx\Assets\Genesis\Cartridges
22:27:57.8  4/20/2016:  Validating: Emulator_7: Manual Path: D:\GameEx\Assets\Genesis\Manuals
22:27:57.8  4/20/2016:  Validating: Emulator_8: Snap Path: D:\GameEx\Assets\Sega Master System\Snaps
22:27:57.8  4/20/2016:  Validating: Emulator_8: Control Panel Path: D:\GameEx\Assets\Sega Master System\Controls
22:27:57.8  4/20/2016:  Validating: Emulator_8: Database: [Console] Sega Master System
22:27:57.8  4/20/2016:  Validating: Emulator_8: Title Snap Path: D:\GameEx\Assets\Sega Master System\Titles
22:27:57.8  4/20/2016:  Validating: Emulator_8: Box Art Path: D:\GameEx\Assets\Sega Master System\Boxes
22:27:57.8  4/20/2016:  Validating: Emulator_8: Cart Art Path: D:\GameEx\Assets\Sega Master System\Cartridges
22:27:57.8  4/20/2016:  Validating: Emulator_8: Manual Path: D:\GameEx\Assets\Sega Master System\Manuals
22:27:57.8  4/20/2016:  Validating: Emulator_9: Snap Path: D:\GameEx\Assets\Nintendo N64\Snaps
22:27:57.8  4/20/2016:  Validating: Emulator_9: Control Panel Path: D:\GameEx\Assets\Nintendo N64\Controls
22:27:57.8  4/20/2016:  Validating: Emulator_9: Database: [Console] Nintendo N64
22:27:57.8  4/20/2016:  Validating: Emulator_9: Title Snap Path: D:\GameEx\Assets\Nintendo N64\Titles
22:27:57.8  4/20/2016:  Validating: Emulator_9: Box Art Path: D:\GameEx\Assets\Nintendo N64\Boxes
22:27:57.8  4/20/2016:  Validating: Emulator_9: Cart Art Path: D:\GameEx\Assets\Nintendo N64\Cartridges
22:27:57.8  4/20/2016:  Validating: Emulator_9: Manual Path: D:\GameEx\Assets\Nintendo N64\Manuals
22:27:57.8  4/20/2016:  Validating: Emulator_10: Snap Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Snaps
22:27:57.9  4/20/2016:  Validating: Emulator_10: Control Panel Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Controls
22:27:57.9  4/20/2016:  Validating: Emulator_10: Database: [Handheld] Nintendo Game Boy Advance
22:27:57.9  4/20/2016:  Validating: Emulator_10: Title Snap Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Titles
22:27:57.9  4/20/2016:  Validating: Emulator_10: Box Art Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Boxes
22:27:57.9  4/20/2016:  Validating: Emulator_10: Cart Art Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Cartridges
22:27:57.9  4/20/2016:  Validating: Emulator_10: Manual Path: D:\GameEx\Assets\Nintendo Game Boy Advance\Manuals
22:27:58.0  4/20/2016:  Restoring Emulator from Cache: 1
22:27:58.2  4/20/2016:  Restoring Emulator Database From Cache: 1
22:27:58.2  4/20/2016:  Restoring Emulator from Cache: 2
22:27:58.3  4/20/2016:  Restoring Emulator Database From Cache: 2
22:27:58.3  4/20/2016:  Restoring Emulator from Cache: 3
22:27:58.4  4/20/2016:  Restoring Emulator Database From Cache: 3
22:27:58.4  4/20/2016:  Restoring Emulator from Cache: 4
22:27:58.5  4/20/2016:  Restoring Emulator Database From Cache: 4
22:27:58.5  4/20/2016:  Restoring Emulator from Cache: 5
22:27:58.6  4/20/2016:  Restoring Emulator from Cache: 6
22:27:58.6  4/20/2016:  Restoring Emulator Database From Cache: 6
22:27:58.7  4/20/2016:  Restoring Emulator from Cache: 7
22:27:58.8  4/20/2016:  Restoring Emulator Database From Cache: 7
22:27:58.9  4/20/2016:  Restoring Emulator from Cache: 8
22:27:58.9  4/20/2016:  Restoring Emulator Database From Cache: 8
22:27:59.0  4/20/2016:  Restoring Emulator from Cache: 9
22:27:59.1  4/20/2016:  Restoring Emulator Database From Cache: 9
22:27:59.3  4/20/2016:  DBCache Diff: 12/16/2014 5:14:36 PM     -    12/16/2014 5:14:36 PM
22:27:59.4  4/20/2016:  Not Restoring Emulator Database From Cache: 10
22:28:20.7  4/20/2016:  Running: cmd.exe /c D: Project64.exe "D:\Emulators\\Nintendo N64\Roms\Castlevania.zip"
22:28:20.8  4/20/2016:  Shutting down display
22:30:00.2  4/20/2016:  Writing Stats
22:30:00.3  4/20/2016:  Plugin: Game Exit
22:30:00.3  4/20/2016:  Plugin: Process Commands
22:30:00.3  4/20/2016:  Refreshing Keyboard
22:30:00.4  4/20/2016:  Initialising Audio
22:30:00.5  4/20/2016:  Relaunching HideOS
22:30:00.7  4/20/2016:  Restoring Window
22:30:00.7  4/20/2016:  Reinitializing Graphics System
22:30:01.5  4/20/2016:  Reloading Game Info Page
22:30:01.5  4/20/2016:  Returning to GameEx
22:30:13.1  4/20/2016:  Exiting GameEx!
22:30:13.1  4/20/2016:  Disposing all videos
22:30:13.1  4/20/2016:  Deleting temporary Karaoke videos
22:30:13.1  4/20/2016:  Disposing Image List
22:30:13.1  4/20/2016:  Disposing Fonts
22:30:13.1  4/20/2016:  Disposing Surfaces
22:30:13.3  4/20/2016:  Saving Settings
22:30:13.3  4/20/2016:  Shutting down Bass
22:30:13.5  4/20/2016:  Closing HideOS.exe
22:30:13.7  4/20/2016:  Disposing Plugins
22:30:13.7  4/20/2016:  Closing database connection
22:30:13.7  4/20/2016:  Checking for applications to Launch On Exit
22:30:13.7  4/20/2016:  Bye
Yeah I have already tried all that including the one you mentioned as well as one that was already on the list named Project 64 V6 which looked about the same content as the   [Mapping Off] Exit (Alt+F4) file. I even did my own config file with the  %{F4} command which is supposed to send a alt+F4 keystroke but no luck. Its as if the advanced config file doesnt get allowed through but if I just hit the alt+F4 keys it works as it should and exits back to GameEx.
Well I think I have found a solution to my problem by having a similar issue with another emulator. I am not sure if this is a Windows 10 issue or something else. It would seem that applications, emulators, programs, etc. that use the {Alt+F4} method for exiting the program instead of {escape} makes GameEx think that the program is still running which is correct. Which in my case just made the program minimize instead of exiting like most emulators. So what I had to do after thinking about it was to go into the GameEx wizard then go to Input settings then scroll down to Global Exit and select yes for enable global escape key exit which was off by default for me anyways. Now Project64 exits back to the GameEx screen as it should. I am sure this is one of the reasons this options was put into GameEx just took me awhile to find so I thought this may save somebody some trouble.
