David_87 Posted April 18, 2016 Posted April 18, 2016 Hi guys, yesterday I wanted to change the options in PinballX just to test the Pin2DMD... I changed from "Real DMD Enable Colour" from "No" to "yes", now everytime I start PinballX my Pin2DMD shows only one color (so far so good) and VP starts now without RGB. Now i wanted to change "Enable Colour" to "No" it doenst affect anything... still don't get RGB in PinballX or VP. I have to reset Pin2DMD and start VP over the .exe. I also looked into the PinballX.ini and deleted the colour for the DMD... nothing. Anyone got a solution?
Tom Speirs Posted April 20, 2016 Posted April 20, 2016 I don't have any ideas although I can tell you that PBX should have no effect on VP (PinMAME). So this does sound strange.
David_87 Posted April 22, 2016 Author Posted April 22, 2016 Now i got it to work somehow (reinstalled PinballX, deleted all registry files...). The PinballX Intro Video is still black & white, but it seems, that the video itself is also black and white... where can i find the colored one?
David_87 Posted April 22, 2016 Author Posted April 22, 2016 The PinballX Video which appears on the DMD for the tables which don't have a "separat video".
David_87 Posted April 22, 2016 Author Posted April 22, 2016 But in the past it was like here https://www.youtube.com/watch?v=sPoqPgcZswY Now its black and white... maybe i don't get it right now ;-)
Tom Speirs Posted April 22, 2016 Posted April 22, 2016 Its just because it is in color now. The video is basically recorded in the colors black and white so the color version is still black and white. Traditional mono DMDs however show white as RED. If someone wants to create a decent color alternative I will be happy to include it in the install.
David_87 Posted April 22, 2016 Author Posted April 22, 2016 Thank you Tom!!! Then I still don't understand why my PIN2DMD doenst show the color... "Enable Color" should be set to "NO" or?
Tom Speirs Posted April 22, 2016 Posted April 22, 2016 To use mono then color should be set to no. If it is set to yes then (the default DMD) will appear as black as white. How other stuff displays depends on what media you have or you have PinMAME setup. If that is not happening, I don't know right now.
gStAv Posted April 24, 2016 Posted April 24, 2016 maybe I should make a color video for PinballX Tom. I check if I have this project till on my HD
Tom Speirs Posted April 25, 2016 Posted April 25, 2016 That would obviously be much appreciated buddy. 1
gStAv Posted April 25, 2016 Posted April 25, 2016 found it.... maybe a bit outdated now, could do a new one maybe. Donn't have the time to try it on my cabs PIN2DMD though 128-32_pinball-x_intro_DMD_color01.avi 1
Tom Speirs Posted April 25, 2016 Posted April 25, 2016 PS: My PinDMD3 arrived today so if you wanted to make my week for the second time go ahead 1
Tom Speirs Posted April 25, 2016 Posted April 25, 2016 Looks like that will work perfectly. Thanks a mil! 1
gStAv Posted April 26, 2016 Posted April 26, 2016 thanks! Now there's at least some colors in there I try to get some time to do another one asap pal cheers
