Hi!!
I'm trying to use Xpadder plugin and it's not working correctly.
Getting an error and not launching.
Attached my log file.
Thanks in advance!!!
He nailed it! :)
4 hours ago, Draco1962 said:
Do you have Xpadder set to Run as administrator?
Hi Draco,
Yes, I have it because I realized that if not, Visual Pinball not recognize Xpadder when I launch it as normal user....
Is this the problem?
Edit: Uncheked the run as administrador option. Now Future Pinball works well, but Visual Pinball not recognizes Xppader...
Hi!!!
I don't know hoy to solve this problem... If I check the "run as an administrator" on Xpadder exe, Gameex can't load it, and if not Visual Pinball don't recognize the Xpadder program and keys don't work. This problem only occurs on Visual Pinball... Future Pinball works fine with or without the "run as an administrator" check...
Any suggestions?
Thanks in advance.
Put it somewhere else that doesn't require elevated permissions, like the root of your C:/ drive.
Hi Adultery!!
Finally solved the problem launching GameEx as administrator. Now I can launch Xpadder as administrator too, and Visual Pinball works fine with this configuration, also Future Pinball.
Have a good weekend friends!!!
Thanks a lot!!!
