When I open a table in Pinball X, the DMD will appear for a moment, and then vanish.  When I check in Regedit the VPinmame settings, the X coordinate of the DMD has jumped 4000 pixels.  If I reset the coordinates to what is in the default configuration, the table will work in Visual Pinball but once opened again is Pinball X, it will do this again.  How can I fix this?
Probably should post your ini and log to get better support.
Besure you are running PinballX and Visual Pinball as administrator. You should just make a habit of doing that with any pinball-related executables.
IMO, if you are using built-in VPM support to display the DMD during preview I'd say disable that and use videos.
We need your log.txt file as well. Also, please verify per Carny_Priest's post that you are running PinballX and the Visual Pinball exe (s) as administrator. Thanks.
6 hours ago, kruuth said:
Anything?
Patience, Grasshopper. One of our monks will review the files and respond with suggestions when they return from the real world.
