I've had a 2 monitor cab running VP 9.9, pinmame 2.5, and pinballx 1.89 for some time now - no problems.
I tried to update to VP 10 and I had to install an updated version of pinmame for it to work.
here's the problem I now have.  Since I installed the new pinmame,  b2sserver.exe wont quit when I exit a table (mostly dmd tables I think but sometimes others)  in PinballX and the game's backglass stays frozen instead of going back to the screenshots and videos.  if I launch VP outside of pinballx b2sserver.exe closes fine when I exit so I think its something in pinballx causing this.
     - I've tried updating pinball to the most current version - same problem
The only way I've been able to solve this problem is to go back and use VP 9.9 and pinmame 2.5 which means I can't use VP10
I guess my question is there something I can add somewhere in Pinballx to kill the b2sserver.exe upon quitting a table or does anyone know why I may be having this problem?
HI there. First of all, you will need to upgrade to the latest version of PinballX. You noted running on v1.89 and we are now at 2.04. Please upgrade to the latest and provide copies of your pinballx.ini and log.txt files so the team can take a look.
If you do not know how or where to find these files, please click on the PinballX How to ask for help link in my signature for instructions on where to find the files and how to submit them for our review. Thanks!
Ok thanks a lot for your help. I've updated Pinballx and attached are the following
1) the first two files are running PinballX 2.12,  VPinball 9.9, and whatever old B2Sserver and Pinmame I had - taxi opens and closes fine as an example - no problems on any B2S tables
2) the second two files are running PinballX 2.12,  VPinball 9.92 and whatever new B2Sserver and VPinmame comes with the 9.92 install (I also now need these to get VP10 to work on my machine) - B2S backglasses now stay open on exiting the table when I am using PinballX - if I exit Pinball X I can see B2sserve is still open in my toolbar
I didn't bother to go through the adjusting of the monitor sizes etc. in 2) to match 1) until I can get 2) to exit properly
thanks a bunch!
backglass works 2.12 and 9.9 (old pinmame and b2s) ini.ini
backglass works 2.12 and 9.9 (old pinmame and b2s) log.txt
backglass sticks 2.12 and 9.92 (new pinmame and b2s) ini.ini
backglass sticks 2.12 and 9.92 (new pinmame and b2s) log.txt
sorted out the problem on my own.  some combination of installing pindmd and resetting all the tables to cabinet mode in pinmame did the trick...
