i can't seem to get the pinmame dmd on the 3rd lcd monitor it keep appearing on playfield monitor , in pbx my monitors are set 1 playfield , 2 backglass , 3 lcd dmd monitor , also in pbx setup window/full screen is set to full screen , use pinmame in frontend is set yes ,fullscreen windowed set as yes, dmd is enabled setting also enable also my dmd postions are set like in vpinmame , if i choose windowed mode i can see the dmd on playfield monitor what can be the problem ?
pinballx.ini , log.txt , picture of displaysettings are attached
PinballX.ini
post-26522-0-47247800-1456055926_thumb.j
Have you tried taking the positioning (X and Y) settings out of the DMD within PinballX Setup Wizard, saved the settings and relaunched PinballX?
