Hi guys.
I can't figure this one out. I'm having a new problem with a single VP table (South Park). For some reason when I exit out of the table and return to the main PBX screen the B2S backglass will not close. Even after I completely close PBX and return to my desktop, the backglass remains. This is an issue with PBX because the backglass WILL close correctly if I play this table directly from VP.
There used to be a kill B2S script somewhere that could be run through PBX, but I can't find it. I've been searching. I already have every exe set to run as admin. And I've also verified that all of the DLL's are unblocked. The truth is I haven't been playing much VP for a while. I've been focusing on VPX. So I can't say how long this has been going on. I'm assuming something changed in PBX in one of the updates. What's really strange though is that South Park is the only offending table. I'm running PBX 2.12 by the way.
Please help.
Junky
Can you provide copies of your pinballx.ini and your VP ..xml file that contains this table? Thanks.
I make no promises as I don't run the software yet, but I am sure our other members will be able to find something to offer an explanation.
I'm thinking that table is dB2S, so nothing to kill.
Is there another version of the dB2S you can try?
Also, I usually use hidebackglass=False. May not make any difference here, though.
Solved. But I have no idea how...
I tried 2 different direct.b2s backglasses that I found. Neither would close from PBX.
So then I tried re-downloading the ooplayer 1.3 table. Problem solved. I don't get it. I literally changed NOTHING. Just another copy of the same table and BAM, all fixed. WTF!!
I appreciate your input guys.
Junky
