Hi,
As of today when i try to start gameex, the programm will not load any of my config files. No emulators themes or any thing ive set up in hours of tinkering arround will not load. I didnt change anything like driveletters ect. Ive cleaned my registry yesterday, but ive done this many times before and it didnt screw up anything.
Help please i dot want to set up all my emus and configs again :-(
The exact same thing happened to me last week. I launched Gameex and it loaded a default theme....I thought that's weird. Upon looking further I noticed the time stamp on the config file was that morning and it was basically empty. After panicking I saw that Gameex backups the config file. I appeared to have a file date of 2 weeks earlier. I overwrote the empty one with that one and all is fine. Look in dir where your config file is and you will see a backup. I thought it was just me or my computer that screwed up because I was having issues with Windows 10 at the same time.
  On 1/8/2016 at 10:17 AM, smackm said:
Hi,
If restoring the config file does not fix the issue as noted by bclinton, please provide copies of your gameex.ini and log.txt files for us to review (this should be done anytime you are reporting a problem).
Click on the GameEx How to ask for help link in my signature for instructions on where to locate these files and how to submit them for review.
