Problems with SSF and GameEx - Windows 10
Hi GBBBS. It may be prudent to open a separate thread to report your issue and provide your gameex.ini and log.txt files.
If you have read this thread from the start, you will see that this issue is not quite the same for several users that have reported a problem with this emulator.
Thanks!
i have the same same problem :( any news to get his work ?
GBBBS are you also using Windows 7? I believe most of the other people with issues with SSF were using Windows 10.
Yes i use winows 10.
but outside of gameex work ssf without problem. maybe gameex have the problem ? it quit automaticly ?
I went ahead and split these posts into a new topic since it is apparent that requests to start a separate thread and provide the requested support files are being ignored.
Please provide the requested files and post them here if you are still having the issue after throughly reviewing this thread with information on how one other user resolved their issue with regards to Windows 10. Thank you.
