[RESOLVED] Gamex.ini goes blank sometimes since Background process
Hello.
I'm on Windows 10 & i have issue with Gameex. For 3 times now, the Gameex.ini has gone blank and lost my config! (now i backup this file!!)
I think it appears since Gameex has a background process.
Sometimes, if i exit Gameex, and restart it, it doesn't launch the second time, (process is still running)
I'm obliged to kill the process and then restart it
It appears only if i already have launch Gamex at least one time
I have disabled lua so i don't think it is about rights (was on Windows 7 before)
Strange issue..
Here is my backed up Gameex.ini :
GameEx.ini
Ok i think i've found the problem
I've updated Alcohol52 to latest version and the problem disapeared
The old version seems to have problem on W10 with virtual drive
So it wasn't Gamex
Thanks !
