I am using the emulator "UNZ (0.5 L30)" to emulate the "FM TOWNS MARTY" system.
When I start the game the menu bar remains active. I saw that the "F12" button on this emulator controls two functions:
1st) controls the capture and release the mouse.
2nd) makes the menu bar disappear.
explaining:
When I just start a game I need to press the "F12" twice to turn the emulator without the menu bar. Reason: When tightening once the emulator screen goes black and the mouse appears.
And when the second time I press the mouse disappears along with the menu bar, and the game's image back.
Conclusion I need some command line to give an order to the "F12" button is sent twice.
Can anyone tell me how to do this? :huh:
FM TOWNS MARTY.ini
GameEx.ini
This is definitely not an emulator that I run, but I would recommend taking a look at the Keys To Send and Wait Before Keys settings found on the Advanced Emulator Setup screen in the Setup Wizard. Stuff like this is basically what those settings are designed for. F12 is a "special key" and as such it needs a special notation (described here), so I think it would look like {F12}{F12}. I'd play around with those settings to see if they work for you. Good luck!
There is that damned Advanced Emulator Configuration again! B)
Ha, yeah. Tangential to the topic, but I've always thought it was a potential source of confusion that we have an Advanced Emulator Setup screen, a selection of Advanced Emulator Configs, and an Advanced Config Editor. It all sounds very ... advanced. ^_^
