I am running the latest PinballX build on Windows 8. When scrolling through tables, if the executable is not set to run as an administrator, PinballX seems to lose focus and not recognise keyboard or button inputs. I need to alt tab back to get it to respond. I am using b2s backglassed in the front end and I suspect that they are stealing focus when loaded on scrolling to the next table. If I run PinballX as an administrator this issue disappears, but then table preview videos stall when scrolling. A video will play for the first table with a video, then when you scroll forward the next video won't play. Returning to the previous table video, it also no longer plays.
I am stumped. Thanks in advance.
  • Replies 76
  • Created
  • Last Reply
Top Posters In This Topic
  • 4 weeks later...
Im still experiencing this problem. Same issue with the videos. Will only load the first video for my selected table, then all tables after with videos display the initial tables video. Please help
We will need your support files, pinballx.ini and log.txt. Click the link in my signature for PinballX How to ask for Help for instructions on how to find the files and how to provide them to us. Also, what codecs are you using?
Thanks for that information. As of version 2.04 the Shark007 Codecs are not required and LAV codecs are all that is needed. You can continue to use Shark007. There is a link here for LAV if you wish to uninstall Shark007 and use these instead. I know that I have seen a slight increase in video loading speed since upgrading PinballX to the latest version and using LAV only.
Actually sorry, that's my mistake. Definately running the LAV codecs. reinstalled them yesterday before posting the info. Brain fart. Sorry for the incorrect info
LAV filters only installed v 0.66
Log Contents
PinballX Support File Data
19:42:12.5 12/4/2015: PinballX - Version 2.05
19:42:12.5 12/4/2015: Windows 8.1 Pro N 64-bit (7.8GB)
19:42:12.5 12/4/2015: Loading Settings
19:42:12.5 12/4/2015: Initialize Component
19:42:12.6 12/4/2015: Initialize Display
19:42:13.7 12/4/2015: Start with windows is set so waiting 5 seconds. Boot Time = 12/4/2015 7:41:50 PM
19:42:21.9 12/4/2015: Loading PlugIns
19:42:22.1 12/4/2015: Created DirectX BackGlass Window
19:42:22.1 12/4/2015: Created DirectX DMD Window
19:42:22.2 12/4/2015: Hiding Cursor
19:42:22.3 12/4/2015: Hiding Taskbar
19:42:22.3 12/4/2015: CPU: Intel® Core i5-4460 CPU @ 3.20GHz
19:42:22.3 12/4/2015: GPU 1: NVIDIA GeForce GTX 750 Ti
19:42:22.3 12/4/2015: GPU 2: Intel® HD Graphics 4600
19:42:22.4 12/4/2015: Displays: 3
19:42:22.4 12/4/2015: Load Game List
19:42:22.4 12/4/2015: Loading Database: Pinball FX2
19:42:22.4 12/4/2015: Loading Database: Visual Pinball
19:42:22.4 12/4/2015: Loading Database: Visual Pinball 10
19:42:22.4 12/4/2015: Loading Database: Visual Pinball Physmod5
19:42:22.5 12/4/2015: Finding and matching artwork and videos
19:42:23.1 12/4/2015: Loading Game Statistics and Scores
19:42:23.2 12/4/2015: Main display running full screen windowed.
19:42:23.2 12/4/2015: Loading Surfaces
19:42:23.3 12/4/2015: Finished Loading Surfaces
19:42:23.3 12/4/2015: Initialize Audio
19:42:23.5 12/4/2015: Set Keyboard Controls
19:42:23.5 12/4/2015: Initialize Joystick
19:42:23.6 12/4/2015: 1 Joystick Attached
19:42:23.6 12/4/2015: Started
19:42:56.5 12/4/2015: Exiting
19:42:56.5 12/4/2015: Showing Taskbar
19:42:56.5 12/4/2015: Unhiding Mouse Cursor
19:42:56.5 12/4/2015: Disposing Plugins
19:42:56.5 12/4/2015: Saving Settings
19:42:56.5 12/4/2015: Bye
Pinballx.ini
[Display]
Monitor=1
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ff0000ff
FullScreenWindowed=True
[backGlass]
monitor=0
x=0
y=0
width=1920
height=1080
UseB2S=True
[DMD]
monitor=2
x=100
y=370
width=1100
height=320
AutoPositionPinMAME=False
UsePinMAME=True
[FileSystem]
EnableFileMatching=True
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
WheelOverlay=1
EnableDefaultFilters=False
[Audio]
StreamVolume=90
SampleVolume=70
PlaySoundInVideos=True
[startup]
playsound=False
playvideo=False
StartWithWindows=Yes
[KeyCodes]
quit=69
left=160
right=161
select=49
rotate=82
pageleft=162
pageright=163
exitemulator=69
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Draper Pinball
Line2=Green Button to Select Table
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball991.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[system_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Executable=steam.exe
Parameters=-applaunch 226980 "[TABLEFILE]"
Process=Pinball FX2.exe
WaitFor=-1
[internal]
lastwheelcachematchsize=-1123
lastselected=Congo (Williams 1995)Congo (Williams 1995)VisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
lastwheelcachematchsize2=259928
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=6
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=2
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=1396,1080
WindowLocation=406,0
[GameListManager]
onlinemode=false
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[system_2]
Name=Visual Pinball 10
SystemType=1
Executable=vpinballx.exe
LaunchBeforeEnabled=False
[system_3]
Name=Visual Pinball Physmod5
SystemType=1
Executable=vpinball-physmod5-accelmod-8-20-2014.exe
[system_4]
Name=
WorkingPath=
TablePath=
Executable=
Parameters=
According to the log.txt file, you are a version behind. The current version is 2.06. While the changes in 2.06 are not that many, I usually recommend that users ensure they are on the latest build prior to troubleshooting.
You may also want to ensure that you are running all apps (PinballX, B2S, Visual Pinball, etc.) as Administrator.
That said, it is possible that the issue is not PinballX directly, but something off in the B2S settings. I do not run this (yet) so maybe one or two of our other forum experts can chime in to review your files and assist.
I had read somewhere way in the past that having joystick settings in pinballx can screw it up so I have never had them in pinballX because I remove them when I first installed it so I don't know if that will solve your problem. But it's something to try...
Also try Turning off the b2s backglassed for the front end And Try videos
thanks for the help so far. I have updated to 2.06, no change. Removed joystick settings, no change. turned of D2BS and PINDMD in front end, no change. every app is running as administrator. I have tried windows XP SP3 compatibility mode also for Pinball X. No Change.
First 2 videos work, then every table after that a still of the 2nd video is displayed. Going to a table that has an image, displ;ays correctly, but next video preview is still a static of the last table video.
Hopefully you changed PinballX back from compatibiltiy with Win XP. Can you submit updated pinballx.ini and log.txt files (we really need to see the log.txt file from when the error is occuring if at all possible).
PinballX running as administrator, no compatability mode settings.
Log shows no errors
12:15:27.1 12/5/2015: PinballX - Version 2.06
12:15:27.2 12/5/2015: Windows 8.1 Pro N 64-bit (7.8GB)
12:15:27.2 12/5/2015: Loading Settings
12:15:27.2 12/5/2015: Initialize Component
12:15:27.2 12/5/2015: Initialize Display
12:15:28.3 12/5/2015: Loading PlugIns
12:15:28.4 12/5/2015: Created DirectX BackGlass Window
12:15:28.5 12/5/2015: Hiding Cursor
12:15:28.5 12/5/2015: Hiding Taskbar
12:15:28.5 12/5/2015: CPU: Intel® Core i5-4460 CPU @ 3.20GHz
12:15:28.5 12/5/2015: GPU 1: NVIDIA GeForce GTX 750 Ti
12:15:28.5 12/5/2015: GPU 2: Intel® HD Graphics 4600
12:15:28.5 12/5/2015: Displays: 3
12:15:28.5 12/5/2015: Load Game List
12:15:28.6 12/5/2015: Loading Database: Pinball FX2
12:15:28.6 12/5/2015: Loading Database: Visual Pinball
12:15:28.6 12/5/2015: Loading Database: Visual Pinball 10
12:15:28.6 12/5/2015: Loading Database: Visual Pinball Physmod5
12:15:28.6 12/5/2015: Finding and matching artwork and videos
12:15:29.2 12/5/2015: Loading Game Statistics and Scores
12:15:29.4 12/5/2015: Main display running full screen windowed.
12:15:29.5 12/5/2015: Loading Surfaces
12:15:29.6 12/5/2015: Finished Loading Surfaces
12:15:29.6 12/5/2015: Initialize Audio
12:15:29.7 12/5/2015: Set Keyboard Controls
12:15:29.7 12/5/2015: Initialize Joystick
12:15:29.7 12/5/2015: 1 Joystick Attached
12:15:29.7 12/5/2015: Started
12:16:18.3 12/5/2015: Exiting
12:16:18.3 12/5/2015: Showing Taskbar
12:16:18.3 12/5/2015: Unhiding Mouse Cursor
12:16:18.3 12/5/2015: Disposing Plugins
12:16:18.3 12/5/2015: Saving Settings
12:16:18.3 12/5/2015: Bye
PinballX.ini
[Display]
Monitor=1
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
MenuColor=ff0000ff
[backGlass]
monitor=0
x=0
y=0
width=1920
height=1080
UseB2S=False
[DMD]
Enabled=False
monitor=2
x=100
y=370
width=1100
height=320
UsePinMAME=True
[FileSystem]
[interface]
ShowSystem=True
ShowRatings=True
WheelOverlay=1
[Audio]
StreamVolume=90
SampleVolume=70
[startup]
playsound=False
playvideo=False
[KeyCodes]
quit=69
left=160
right=161
select=49
rotate=82
pageleft=162
pageright=163
exitemulator=69
ingame=80
screenshot=83
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=
left=
right=
select=
rotate=
pageleft=
pageright=
exitemulator=
ingame=
instructions=
[Text]
[FuturePinball]
Enabled=False
[VisualPinball]
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[system_1]
Name=MAME
Enabled=False
TablePath=C:\
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
WaitFor=-1
[internal]
lastselected=Medieval Madness (Williams 1997) VP10M_Madness_10_4_RELEASESystem_2
filter_year=
filter_company=
filter_custom=
filtername=Tables
[setupWizard]
RomPath1=C:\Roms
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=20
SearchText=
EmulatorIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=2
ShowPanel=True
FontSize=1
WindowState=2
[GameListManager]
onlinemode=false
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
[system_2]
SystemType=1
[system_3]
SystemType=1
[system_4]
Name=
WorkingPath=
TablePath=
Executable=
Parameters=
Tell us something about your GPUs. Per the log.txt file you are running two video cards - a NVIDIA GeForce GTX 750 Ti and a Intel® HD Graphics 4600 (assuming that this is onboard video). Which one is running the playfield videos?
Have you tried running all 2 from the nVidia GPU? If this works, it could be an issue with running the the backglass on a separate GPU.
I haven't tried that. ill need to pull the tv out the cab to get to the gpu ports. I doubt its a problem with which GPu is running the screens, but I will try
Did you disable the inboard GPU in BIOS when you switched to all displays on the card?
If so I am not sure what could be the cause. Are you using .mp4 videos, or a mix of formats?
There are quite a few mp4 videos. I wonder what happens if you were to replace some of the flv with mp4?
If the on board video isn't being used it probably wouldn't hurt to disable it if possible.
