I am not sure DOSBOX will work, as it is a standalone function. I will try and configure mine and let you know. Personally, I have found it to have quite a few glitches, so I would be surprised if it works.
Hard to say becouse the games uses differents setups some games requries differents settings to work ...
the best you can do are goto thier home and read thier FAQS : http://dosbox.sourceforge.net/
and read how to use it :)
and when you understand how to setup Dosbox on its own i would be more than happy to help you setting it up for GameEx....
Night
I agree with Night..you have to really go through it step by step, and I found that it works differently with each program, so it does take a bit of tweaking. I would start with one game, and make sure you have that down before you get too adventurous!
